Old 10-21-2014, 05:39 PM   #5545
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by xxscaxx View Post
I have to go back and edit my post, but I just wanted to make a quick note of whoever decides to use the brass fittings I had posted a while back for the elbows on the back of hte supercharger to use a 5/16 barb NOT a 1/4 barb for the evap line.
I bought the 1/4 barb lol.. damn
brianhj is offline   Reply With Quote
Old 10-21-2014, 06:08 PM   #5546
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Originally Posted by brianhj View Post
Just to clarify you're using 70mm with no intercooler? Why does everyone say not to use smaller puller without intercooler? Generates too much heat?
On e-85 my temps are just fine as long as I don't stand still for extended periods. I would likely have problems if I was on the track all day...but I'm not. I probably wouldn't run this setup on 91 octane.
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 10-21-2014, 06:10 PM   #5547
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
How are all y'alls coolant and oil temperatures on E85?
SprintexUSA is offline   Reply With Quote
Old 10-21-2014, 06:15 PM   #5548
poorsche
poorsche's Avatar
Coolant temp stays around 180-185 at cruise.
Old 10-21-2014, 06:17 PM   #5549
poorsche
poorsche's Avatar
No means to monitor oil temp, i just know it was staying in the safe operating range after half a day of dyno pulls and tuning.
Old 10-21-2014, 06:34 PM   #5550
FT86RGV
I had non IC e85 setup in south texas all summer and can only speak for daily driving. I didn't see anything of concern. Coolant temperature never moved once it settled and oil temperature only went up if I was really getting on it for a while.
FT86RGV is offline   Reply With Quote
Old 10-21-2014, 08:54 PM   #5551
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Is that because E85 burns cooler than petrol?
Fizz is offline   Reply With Quote
Old 10-21-2014, 09:34 PM   #5552
s2d4
s2d4's Avatar
Charge air also cools, less prone to heat soak.
Old 10-22-2014, 03:29 PM   #5553
xxscaxx
Drives: 2013 SWP BRZ
Yeah sorry about that. I did at first too because it was available locally. I ordered the 1/4" - 5/16 barb fitting off amazon. It fits WAY better. I was using a fuel line clamp tightened completely down on the 1/4" barb and I could still twist the line. 5/16 is the perfect size.
xxscaxx is offline   Reply With Quote
Old 10-22-2014, 03:31 PM   #5554
brianhj
Got a link?
Old 10-22-2014, 03:34 PM   #5555
xxscaxx
Got a link?
[ame="http://www.amazon.com/gp/product/B001ADWE78/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1"]1/4" npt - 5/16 Barb[/ame]
please note I used this in conjunction with a 1/4" street elbow.
Here is my original post that I added this info to.
http://www.ft86club.com/forums/showp...postcount=2284
Old 10-22-2014, 03:56 PM   #5556
brianhj
I bought these a couple weeks ago:
http://www.mcmaster.com/#4860k422/=u9krbh
Will those work with these?
[ame="http://www.amazon.com/gp/product/B001ADWE78/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1"]Amazon.com: Tru-Flate 21-133 5/16" Male Hose End Barb Type Hose Fitting: Industrial & Scientific[/ame]
Old 10-22-2014, 04:35 PM   #5557
SprintexUSA
Drives: 2014 FT86
Please note that British Standard Pipe (a.k.a. ISO thread) and National Pipe Thread are NOT the same thread pitch. BSP is what we use. NPT wil not thread in nicely and will likely leak.
The bolts used are metric, but the pipe fittings are BSP. All Sprintex systems are designed overseas, so you have to roll with this a little bit. NPT is really only popular in the US o' A. BSP / ISO is more common around the world. NPT is hard to find everywhere else except the USA.
The Following 2 Users Say Thank You to SprintexUSA For This Useful Post:
brianhj (10-22-2014), whataboutbob (10-22-2014)
Old 10-22-2014, 04:50 PM   #5558
brianhj
Thank you.. So my elbows will work I just don't know which barbs to use
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
