#5531 |
Drives: 13 BRZ Limited, 2000 Impreza Sport
Same belt, The tensioner has plenty of range, belt will still be tight on a smaller pulley.
Innovate powered- Corn fed- FBM tuned
#5532 | |
Drives: Asphalt 2013 FR-S
From the Delicious Tuning thread: - JDL Equal and Unequal Length - Tomei Equal and Unequal Length - Nameless Header - PPE Equal Length Header http://www.ft86club.com/forums/showp...&postcount=841 http://www.ft86club.com/forums/showp...&postcount=847
#5533 |
Senior Addict
Drives: 86 GT
Apologies if this has already been answered (too many pages to read), but anyone here using the non-IC kit, under high temp conditions? Such as ambient temps of around 100-110F? With 91 octane fuel? Would appreciate some feedback....
I see so many guys in here running the non-IC kits, but this isn't an option for us in Australia as they only sell the intercooled versions. I've been advised that non-IC isn't suitable for our market, but I wanted to explore this further. |
#5534 | |
Drives: 86
I only have the non-intercooled kit for couple of months now and I live in Saudi Arabia which I assume is very hot. I noticed a drop in power once the intake temp climp above 100F as the tune start to pull timing once the intake temp increase. So usually I dont go full throttle in these temps. I try to keep my full throttle injoyment for early morning drives when temp is around 80 F and saving to get the intercooler ASAP. I only got the non intercooled because I was offered a very good price from a local dealer to take it from his shelf. Sent from my iPhone using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#5535 | |
Super 86
Drives: Red 86 GTS
It would be alright in the Perth winter like coldest of winter, summer no chance at all the heat soak with the IC kit is just manageable on the track. On the street it would be alright but if you wanted to have fun it would pull timing etc pretty quick.
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
#5536 |
Drives: 2014 WRB BRZ
#5537 |
Drives: GT 86
Yes same belt for 75mm and 69mm pulley's .
#5538 | |
Senior Addict
Drives: 86 GT
#5539 | |
Drives: 86
I felt that while testing the accelleration againest my freind car. The more we do it, the more he get close to me. like I am loosing a bit of power every time. Sent from my iPhone using Tapatalk
#5540 |
Drives: 2013 SWP BRZ
I have to go back and edit my post, but I just wanted to make a quick note of whoever decides to use the brass fittings I had posted a while back for the elbows on the back of hte supercharger to use a 5/16 barb NOT a 1/4 barb for the evap line.
#5541 |
Drives: '13 Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
@Fizz I'm currently running the non-IC kit on 91oct here in California. I definitely noticed the heatsoak during daily driving this past summer with 100-110F weather. Stop and go traffic also really sucked. Under normal temps (70-90F) it runs fine but I feel that the intercooler is necessary for consistent power and less heatsoak. Still not as bad as a turbo setup though... esp. w/o the proper cooling/supporting mods on the track. Hope this helps. Why do you say the non-IC is not suitable for your market?
@poorsche Running the JDL UEL right now and definitely noticed more power down low and in the midrange. I was also considering the Revworks UEL and Nameless header but got a good deal on the JDL with matching OP & FP. I'm looking to get a dyno tune once I get the IC & 69mm pulley on and will report back with data. Last edited by J.C.; 10-21-2014 at 01:18 PM. |
#5542 | |
Drives: 2017 Camaro 1SS
#5543 | |
Drives: Raven FR-S
That's exactly why
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#5544 |
Yeah mine gets hot as hell with 75mm pulley, damn near burned my hand on it
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
