Old 08-26-2014, 11:25 PM   #29
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Originally Posted by jmelgar23 View Post
I have the same problem as OP. I didn't notice until after I got tints done tho. Does anyone know if I can still get the window replaced under warranty even if I have tinted windows?
For sure, go to the dealer, the problem is not linked with your tint anyway...
o= FR-S =o
Mikepage is offline   Reply With Quote
The Following User Says Thank You to Mikepage For This Useful Post:
jmelgar23 (08-27-2014)
Old 08-29-2014, 10:38 PM   #30
Mikepage
Mikepage's Avatar
Scratches on Outside of Driver's Window
My window, where they replaced the parts, started to cry when raining now... Do you have an idea why? Do you suggest to go back to the dealer?
o= FR-S =o
Old 08-30-2014, 02:10 AM   #31
Flako
Drives: Asphalt scion frs
I have huge scratches on mine , the dealer just said tough luck dirt that got in the stripping caused it....
Flako is offline   Reply With Quote
Old 08-30-2014, 06:46 PM   #32
Mikepage
Mikepage's Avatar
Go back and try again or check with an another dealer.... They are wrong and they told me the same thing before replacing everything in the door...
You can also show them the thread here.
o= FR-S =o
Flako (08-30-2014)
Old 10-14-2014, 05:50 PM   #33
tinma
Drives: '13 BRZ
had my TSB done today...they replaced my windows but would not replace the tint that they sold the car to me with....so now I have to pay tint out of my pocket
tinma is offline   Reply With Quote
The Following User Says Thank You to tinma For This Useful Post:
Dipstik-sportech (10-20-2014)
Old 10-20-2014, 06:57 PM   #34
jmelgar23
Drives: 2013 SWP BRZ Limited
Didn't know they had a TSB out for this! Still need to take my car to the dealership! lol
jmelgar23 is offline   Reply With Quote
Old 10-20-2014, 08:34 PM   #35
navanodd
Drives: 2013 BRZ Sport-tech WRB
I'm excited to see that Subaru Canada has the TSB out. I'll head to the dealer this week. I always see TSBs but usually don't get confirmation that its (a) Subaru, and (b) Canada.
navanodd is offline   Reply With Quote
Old 10-20-2014, 09:23 PM   #36
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Had both of my windows replaced under warranty due to the belt molds scratching them all to pieces. Dealer covered tint as well...probably due to the fact we were in progress of buying a new venza for the wife.
Triumphrider is offline   Reply With Quote
Old 10-22-2014, 09:39 AM   #37
tinma
Drives: '13 BRZ
after getting the TSB done...my window now makes a horrible screeching noise when wet (worse than before the TSB)...will be letting the dealership know sometime this week
Old 10-22-2014, 09:54 AM   #38
Mikepage
Mikepage's Avatar
I got that trouble also after dealer installed new windows...
I know how to fix it like the dealer fix it for me in 5 minutes...
You just need to put some grease into the new rail.
Exempt for the driver side, If you remove the door trim, on the left side into the door you will see the rail, where a little wheel roll when you move the window up and down...add some grease on both rails, the upper and the lower...Problem fixed!
o= FR-S =o
tinma (10-22-2014)
Old 10-29-2017, 12:14 AM   #39
BaatLuk
Drives: Evo X
Anyone with 2015+ FRS/BRZ/86 have this issue?
BaatLuk is offline   Reply With Quote
Old 10-29-2017, 12:59 AM   #40
Do you have them? It should not be an issue with the updated weather stripping and guides
Old 10-30-2017, 07:52 PM   #41
BaatLuk
Drives: Evo X
No but there is a small indentation (about 1-2 cm long but you can feel it with your finger) on the driver side glass. I already took it back to the dealer but of course they blamed it on me saying that happened after I took delivery of the car (only had 600 miles at the time). If you look at the location (middle of the glass, near the side mirror) and size of indentation, it looks more like a defect from the factory. It's extremely unlikely for someone or something to make contact with the glass to cause such a small indentation (not a bigger scratch or crack). I don't know whether I should fight it or let it go. Car is brand new and I've never experienced anything like this before even on much older cars.
Old 10-30-2017, 07:59 PM   #42
Very possible it did happen by something hitting it. If it is that small I would not even worry about it. If it gets worse then take it back again otherwise it isn't hurting anything.
BaatLuk (10-30-2017)
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Anyone with an auto, have scratches on the Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 26 03-31-2013 01:17 PM
minor scratches..... jazztennor Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 02-06-2013 01:01 AM
scratches - best way to handle them Vladror AFRICA 6 02-03-2013 05:05 PM
Scratches on my Cluster. Superhatch BRZ First-Gen (2012+) — General Topics 5 08-21-2012 08:50 AM
