Old 03-26-2014, 04:42 PM   #15
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
Originally Posted by Kauf View Post
I have 2 vertical scratches on my drivers side window about an inch or so apart. Nice to know it can be fixed under warranty, but still a hassle. Hope the fix lasts. (Not the greatest quality pic, but it shows the scratches.)
I just noticed recently my window seal is now getting squished by the window when it's rolled up (at the top.) It wasn't doing this before. I was aware of it happening to these cars because my friend had it happening on his FRS. I'm assuming the felt fell off the guides like the poster above. I wonder if the weather seal issue is caused by this issue?
My weather stripping was doing the same thing and water would slowly leak in where it was being pinched. They replaced the driver side weather stripping under warranty though.
speedracer38 is offline   Reply With Quote
Old 03-26-2014, 05:29 PM   #16
Wyattkb
Drives: 2014 Whiteout FRS
I just noticed this the other day when my windows where dirty it would leave those lines. It has not scratched the window or anything. I simply wiped it away, but now I will take a closer look. I am going to be really mad if it scratches my 3m Crystalline tint.
Wyattkb is offline   Reply With Quote
Old 03-26-2014, 11:30 PM   #17
Jayde
Jayde's Avatar
Mine are on the outside of the window, so it doesn't affect my tint, but if the window needs to be replaced, I'll have to get it re-tinted anyway.
Going to the dealer tomorrow to have the service manager look at it and go from there. Might as well have him do all the other TSBs with this car if it's going in.
Jayde is offline   Reply With Quote
Old 03-28-2014, 11:57 PM   #18
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
I have scratch like this also driver side...
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 03-29-2014, 12:43 AM   #19
Ec1990
Drives: '14 BRZ
It's usually from small pieces of rock and such that get stuck in the weatherstripping.
Ec1990 is offline   Reply With Quote
Old 03-29-2014, 01:20 AM   #20
evan
Drives: fr-s
totalled
evan is offline   Reply With Quote
Old 03-29-2014, 12:09 PM   #21
Muskokan
Drives: white Sport-tech
mine are super noticable because of the 5% tint, already got the window freezing tsb done that installed new weather stripping and possibly those guide things? they didnt replace my window though.
Muskokan is offline   Reply With Quote
Old 05-01-2014, 06:16 PM   #22
Mikepage
Mikepage's Avatar
Scratches on Outside of Driver's Window
I come back from the dealer and they will replace my driver windows and the guide into the door, everything under warranty of course
o= FR-S =o
The Following User Says Thank You to Mikepage For This Useful Post:
tomkozski (05-02-2014)
Old 05-04-2014, 11:13 PM   #23
connorlug
Drives: #1553 10 Series FRS
tsb info:
S-SB-0009-14
Outside Door Weatherstrip - Multiple Concerns
Some 2013 – 2014 model year FR-S vehicles may exhibit multiple concerns from the Outer
Weatherstrip (belt molding).
The cross section of the weatherstrip has been revised to limit the amount of water passing into
the door. If the felt attached to the window stabilizers/guides accumulate water, the vehicle may
also make noise from the stabilizers/guides during window operation. In some cases, the felt on
the stabilizers/guides may freeze to the window or detach from the plastic backing and damage
the window.
Symptoms may include:
• Noise coming from the weatherstrip during window operation, especially when wet.
• Loosening of the weatherstrip from the door.
• Inversion of the weatherstrip during window operation.
• Noise from the stabilizers/guides during window operation.
• Scratches on the glass from worn stabilizers.
This bulletin applies to vehicles produced BEFORE the Production Change Effective VIN
shown below.
MODEL PRODUCTION CHANGE EFFECTIVE VIN
FR-S JF1ZNAA1#E8705465
connorlug is offline   Reply With Quote
The Following 3 Users Say Thank You to connorlug For This Useful Post:
eurominican (05-07-2015), jmelgar23 (10-20-2014), Mikepage (05-05-2014)
Old 06-12-2014, 01:42 PM   #24
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Originally Posted by connorlug View Post
tsb info:
S-SB-0009-14
the window.
shown below.
Do you have the official TSB for this? I can't find this online or on the forums
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
The Following User Says Thank You to Tt3Sheppard For This Useful Post:
SnapOv3st3r (07-09-2014)
Old 08-05-2014, 10:49 AM   #25
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Any update from people who had the TSB performed? Lasting results?
1Cor10:23 is offline   Reply With Quote
Old 08-25-2014, 04:16 PM   #26
hur1ey02
hur1ey02's Avatar
Bump.
Has anyone had the follow up on this? I've had this issue since day 1, but haven't noticed any scratches.. I can only imagine that they are on the way. I'm getting ready to go out of warranty so I'm having my dealer address this before then. Any advice? Does anyone have a copy of the official TSB?
Amanda - 2013 Scion FRS (Raven)
hur1ey02 is offline   Reply With Quote
Old 08-25-2014, 04:30 PM   #27
stevemp5
Drives: scion fr-s
This is mine... dealer change it with the tsb!
stevemp5 is offline   Reply With Quote
The Following User Says Thank You to stevemp5 For This Useful Post:
hur1ey02 (09-05-2014)
Old 08-26-2014, 11:42 AM   #28
jmelgar23
Drives: 2013 SWP BRZ Limited
I have the same problem as OP. I didn't notice until after I got tints done tho. Does anyone know if I can still get the window replaced under warranty even if I have tinted windows?
jmelgar23 is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Anyone with an auto, have scratches on the Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 26 03-31-2013 12:17 PM
minor scratches..... jazztennor Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 02-06-2013 12:01 AM
scratches - best way to handle them Vladror AFRICA 6 02-03-2013 04:05 PM
Scratches on my Cluster. Superhatch BRZ First-Gen (2012+) — General Topics 5 08-21-2012 07:50 AM
