Old 10-18-2014, 12:17 PM   #2549
hayupak
Drives: A Nissan
18x9.5 +38
235/40/18
Lowered on RSR super down springs
Will this fit or will it cause rubbing on the front suspension?
What other tire setup can I use? 245/40 or 245/35
hayupak is offline   Reply With Quote
Old 10-18-2014, 02:58 PM   #2550
Vancityfrs
Drives: Whiteout frs
18x9.5 +23 with 11mm conversion spacer, not sure tire sizing yet.
lowered 2" on coils.
going to be looking to run about 3.5 degrees camber in front and about 2 or so in the rear
Cheers
Vancityfrs is offline   Reply With Quote
Old 10-18-2014, 05:21 PM   #2551
Krovi
Krovi's Avatar
Drives: '14 Midnight Purple FR-S
Cheers
18x9.5 +40 is pretty much flush with a bit of camber.
At +12 offset your wheels will be sticking out like an inch if you can even fit them.
'14 MIDNIGHT PURPLE FR-S 『フェイリス』
Follow me on Instagram @overlim.it
Krovi is offline   Reply With Quote
Old 10-18-2014, 06:39 PM   #2552
Vancityfrs
Thanks for the reply, I'm new to 86 fitment
Old 10-20-2014, 08:51 AM   #2553
mikkeluo
Drives: 2013 Toyota 86 ZN6 GTS
Hey guys,
I'm planning on getting Work Emotion D9R rims in 18 x 8.5 +38, running them on 245/35/18 tyres. I will also be lowering my 86 by 25mm (0.98inches).
I live in Australia, and legislation states that wheels must not stick out of the wheel guards.
So my question is whether or not the aforementioned setup will be legal, ie. will the wheels sit inside the guards?
Cheers everyone
Michael
mikkeluo is offline   Reply With Quote
Old 10-20-2014, 08:59 AM   #2554
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by mikkeluo View Post
Hey guys,
Cheers everyone
Michael
This is a good wheel size and offset.
Also, with the lowering, you will gain negative camber which will help pull the top of wheel/tire in.
I'm not sure what you mean by "the guards", but the top of tire will be inside the top of the wheel opening in the fender. If that's how they measure it, you should be quite alright.
My sig below shows my wheels on 245/35R18 and they just fit. Technically, yours should be inboard by an extra 6-10mm (outside of wheel).
Slick is offline   Reply With Quote
Old 10-20-2014, 09:04 AM   #2555
mikkeluo
Thanks so much for your reply, mate! Loving your set up
Old 10-23-2014, 02:48 PM   #2556
pf330ci
pf330ci's Avatar
Hey everyone, I picked up some Enkei RPF1's in 18x8 +45 offset. I am thinking of doing 245/40/18 tires with H&R Super Sport springs, which should yield a 1.2" drop in the front and a 1.4" drop in the rear. Will 245/40/18's be ok with this?
pf330ci is offline   Reply With Quote
Old 10-24-2014, 09:07 AM   #2557
jn86
Drives: white gt86
Hey guys, similar to mikkeluo's post from above with the Australian laws,
would there be any issues at all with 18x8.5 +40 all round lowered on eibach pro kit?
225/40/18 rubber
Eg. Clearance, rubbing etc?
jn86 is offline   Reply With Quote
Old 10-29-2014, 07:18 PM   #2558
jxl00
Drives: scion frs 2014
Hi, does 18x9.5 +35 square with 245/35 fit with no rubbing on stock everthing (no modding)
jxl00 is offline   Reply With Quote
Old 10-30-2014, 03:06 PM   #2559
Leonardo
Country Boy 4 Life
Leonardo's Avatar
With out camber adjustment and a drop, you will poke in the front quite a bit.
225/40/18 rubber
You are golden! Those specs are great!
Wheels are great! Tires are too tall.
These are better sizes, 225/40 or 245/35. Your speedo will be off with the 245/40 and the tire is heavier.
Old 11-03-2014, 01:49 PM   #2560
nnorris7413
Hey guys, I was just offered a set of winter wheels from a Subaru Legacy. The wheels are 16x7 w/ a 50 mm offset and a 5x100 bolt pattern. Those should fit just fine. But the tires are 205/65R16. I see that the recommended size for our cars is 205/55R16. Will the 205/65 fit alright without any issues? Thanks.
nnorris7413 is offline   Reply With Quote
Old 11-04-2014, 01:35 PM   #2561
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Here is a link to a tire calculator. http://www.discounttire.com/dtcs/infoTireMath.do
This is how everyone checks the specs on tires.
And no the tires won't work optimally, they are way too tall. You will be going 70 when your speedo says 65. That's way more than the suggested +/- 3% variance. about 7.1%
Old 11-05-2014, 12:55 AM   #2562
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
I'm considering picking up a staggered wheel setup:
18x8.5 +45 w/ 235/35 R18s up front
18x9.5 +45 w/ 255/35 R18s in the rear (maybe, otherwise I'll just square the rear with the fronts.)
I'm still on stock suspension, will almost certainly be dropped in the future. But doubtful it will be more than an inch.
Everything I'm reading seems to tell me that I should not have clearance issues with this setup on stock. I'm certain I won't once I'm lowered a tad. Can anybody confirm?
Edit: Seems I was kind of answered a few pages back:
Sorry guys, unless you're on coilovers or stock suspension, nope. They will fit on the rear but not up front unless you add a spacer.
Check the wheel directory and have a look at others here:
http://www.ft86club.com/forums/showthread.php?t=35463
http://www.ft86club.com/forums/showthread.php?t=63268
Either run staggered F8.5 +45/R9.5 +45
or
go square with an offset closer to +35 to +38
or
add 10mm spacers to the front
or
go with another wheel option
Looks like my research seemed to lead me to the first option here.
Thanks for all the answers I see you handing out here @Slick. It's appriciated!
Jar is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
