Old 10-19-2014, 04:33 AM   #15
rx3
I know this is an old thread, but have you meanwhile found a shorter seatbelt buckle?
I'm having a similar issue with an aftermarket seat and unless there are any shorter belt buckles which fit, I'm planning to purchase a second driver belt buckle, shorten it and drill another hole in it. In this case that hole can be much smaller (still same screw diameter) so the strength of the belt buckle won't be affected to a significant extend.
rx3 is offline   Reply With Quote
Old 10-19-2014, 05:06 AM   #16
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
If the passenger one is shorter why not try swapping the drivers one and the passengers one or can they not be swapped?
If that works then buy another passenger one rather than another drivers one.
nzer is offline   Reply With Quote
Old 10-19-2014, 05:23 AM   #17
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by Kostamojen View Post
I tried swapping the driver and passenger side buckles, but the wiring is completely different and not compatible
Edit:
Actually, nevermind.
That may not apply to him since he has an aftermarket seat.
Old 10-20-2014, 03:29 PM   #18
rx3
No you're correct this problem applies to me too, since I'm also using the original seatbelt including buckle (but as the OP mentioned you cannot swap them - besides I might need it to be shorter anyway).
I'm using this Recaro pole position seat and want to get the buckle (or at least some sort of belt buckle extension of it through that hole - like here: http://www.motor-talk.de/bilder/recaro-pole-position-im-signum-g8899635/recaro-pole-position-abe-2-i203074131.html )
Old 08-25-2016, 10:02 PM   #19
Gliderx
Drives: 2014 BRZ Limited
Reviving an old thread.
I have Recaro Pole Position in my car and bought myself a 10" seat belt extender and looped it through the seat opening. I may switch it up and hard mount the extendo itself. I thought I share.
Gliderx is offline   Reply With Quote
New FRS driver side headlight $200 retrosmiths Exterior Parts (Aero, Lighting, Etc.) 2 08-04-2013 01:06 AM
WTB: smoked side marker (driver side) vincent201089 Exterior Parts (Aero, Lighting, Etc.) 2 07-29-2013 05:29 AM
WTB BRZ driver side headlight zex Canada Classifieds 0 07-21-2013 06:19 PM
FS: BRZ HEADLIGHT (Driver Side $375) FRS2000 Exterior Parts (Aero, Lighting, Etc.) 0 06-10-2013 12:43 AM
4 pin connector driver side charley026 Cosmetic Modification (Interior/Exterior/Lighting) 0 03-30-2013 02:27 PM
