#113 |
Club Member
Drives: 2014 Asphalt FR-S Monogram 6MT
Can someone please chime in on the Redline MT-90 75W-90 GL4 and Redline Shockproof mixed together? Is this good, bad, safe, ok to use for both diff and trans?? How is this compared to Gear 300?
#114 |
Drives: GT86
I switched out for the Motul300 this weekend.
Before I switched, it took about 3-5 mins of driving before shifting into 2nd became smooth. So far (on a cold start) the very first shift into second is a bit rougher, 2nd shift is decent and the rest are nice and smooth. This seem normal for some of you other guys? that noise of the first shift into second make me cringe everytime |
#115 | |
Drives: '13 BRZ Ltd WRB
| The Following User Says Thank You to 2point0 For This Useful Post: | Crosscharge (07-16-2014) |
#116 |
Drives: Scion FR-S
Can anyone comment on how often the trans/diff fluid should be changed? I changed about 14k miles ago and will be jacking up my car soon to finish my exhaust setup, is it worth changing diff/trans fluid at the same time or is it still too soon?
#117 |
I don't know offhand, but you can look up the maintenance schedule for your car. It's on Subaru's website somewhere. Just do a Google search for your year. Someone has probably uploaded it here, too.
| The Following User Says Thank You to 2point0 For This Useful Post: | kodyo (07-23-2014) |
#118 | |
I love peanut butter
Drives: 2013 SWP BRZ Limited
P=Perform I=Inspect
| The Following 5 Users Say Thank You to B-R-Z For This Useful Post: | akahenry (03-08-2015), eurominican (01-01-2015), kodyo (07-23-2014), Teseo (10-11-2014), YouShallKnow (05-06-2015) |
#119 |
Senior Addict
Drives: 86 GT
You probably don't really need to, but since you'll have easy access to it already might as well change at least the diff fluid. It's an easy and affordable maintenance that I'd do on a yearly basis anyway. Your trans fluid can stay on for awhile more.
| The Following User Says Thank You to Fizz For This Useful Post: | kodyo (07-23-2014) |
#120 |
Drives: Scion FR-S
Thanks for the replies. I have a spreadsheet going of all my maintenance and thought mine only said inspect on both the trans/diff, so wasn't sure when to replace.
How does one inspect the diff/trans fluid anyways? |
#121 |
First, make sure the car is level. Each has a fill/inspect plug and a drain plug. The fill/inspect plug is higher up, the level of fluid should be right at or just below the bottom of the hole. It's a pain to check if you don't have tiny fingers. You can always just add a smidge until it starts coming back out, then you know it's full.
If replacing, always remove the top plug first, that way the air can rush in when you remove the bottom one. You'll get a steady stream instead of a gulp-gulp-splash-splash. Filling is a pain. The Motul bottles have necks on them (doesn't look like it, but it pops out of the bottle) and they say you can fill with just that, but it's not easy to get the bottle high enough to actually pour while under the car. Rig up a hose so you don't have to be underneath, your back will thank you.
#122 | |
Drive From Home
Drives: BRZ STI Performance
I got mine at the Toyota dealer, the Subaru part seems to have a more blue sheen to it on the metal, the Toyota part is just straight silver. Unless I'm seeing things. |
#123 |
Drives: Strangely.
I put Motul 300LS in my '14 Monogram with like 320 miles on the odometer, didn't notice any difference. If anything it's now a tiny bit worse. Nowhere near as bad as my '13 BRZ was, though...
Maybe the later-production transmission came with better fluid? Or did I use the wrong fluid? |
#124 | |
Drives: WRB BRZ Series.Blue
Not necessary for our Torsen, and I'm under the impression that it's probably not good if not bad for the tranny. |
#125 |
Drives: 2015 Halo FR-S
Great DIY write up. Made it a lot easier for me to actually start doing DIY maintenance to my 86. Thank you!
#126 |
| Tags |
| differential, diy, fluid, transmission |
| Transmission fluid swap? | flawedchemical | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 48 | 09-12-2014 03:23 PM |
| What Differential fluid is in your BRZ/FRS? | ft86Fan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 11-12-2012 09:57 PM |
| Anyone change transmission lube yet? | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 08-21-2012 06:47 AM |
| FR-S quick reference and warranty / maintenance guide is up | pkny | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 06-21-2012 12:33 AM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 08:54 PM |
