Doborder, orthojoe
Old 07-16-2014, 10:20 AM   #113
chicagokid
Club Member
chicagokid's Avatar
Drives: 2014 Asphalt FR-S Monogram 6MT
Can someone please chime in on the Redline MT-90 75W-90 GL4 and Redline Shockproof mixed together? Is this good, bad, safe, ok to use for both diff and trans?? How is this compared to Gear 300?
chicagokid is offline   Reply With Quote
Old 07-16-2014, 08:30 PM   #114
Crosscharge
Crosscharge's Avatar
Drives: GT86
I switched out for the Motul300 this weekend.
Before I switched, it took about 3-5 mins of driving before shifting into 2nd became smooth.
So far (on a cold start) the very first shift into second is a bit rougher, 2nd shift is decent and the rest are nice and smooth.
This seem normal for some of you other guys? that noise of the first shift into second make me cringe everytime
Crosscharge is offline   Reply With Quote
Old 07-16-2014, 11:24 PM   #115
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I wouldn't say it makes a nasty noise, but my experience is similar otherwise. On cold days, I need to shift a few times for it to smooth out the 1-2 or 2-1 shift.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
Crosscharge (07-16-2014)
Old 07-23-2014, 08:59 PM   #116
kodyo
Drives: Scion FR-S
Can anyone comment on how often the trans/diff fluid should be changed? I changed about 14k miles ago and will be jacking up my car soon to finish my exhaust setup, is it worth changing diff/trans fluid at the same time or is it still too soon?
kodyo is offline   Reply With Quote
Old 07-23-2014, 09:20 PM   #117
2point0
2point0's Avatar
I don't know offhand, but you can look up the maintenance schedule for your car. It's on Subaru's website somewhere. Just do a Google search for your year. Someone has probably uploaded it here, too.
kodyo (07-23-2014)
Old 07-23-2014, 09:36 PM   #118
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
R=Replace
P=Perform
I=Inspect
B-R-Z is offline   Reply With Quote
The Following 5 Users Say Thank You to B-R-Z For This Useful Post:
akahenry (03-08-2015), eurominican (01-01-2015), kodyo (07-23-2014), Teseo (10-11-2014), YouShallKnow (05-06-2015)
Old 07-23-2014, 09:46 PM   #119
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
You probably don't really need to, but since you'll have easy access to it already might as well change at least the diff fluid. It's an easy and affordable maintenance that I'd do on a yearly basis anyway. Your trans fluid can stay on for awhile more.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
kodyo (07-23-2014)
Old 07-23-2014, 10:02 PM   #120
kodyo
Drives: Scion FR-S
Thanks for the replies. I have a spreadsheet going of all my maintenance and thought mine only said inspect on both the trans/diff, so wasn't sure when to replace.
How does one inspect the diff/trans fluid anyways?
Old 07-23-2014, 11:23 PM   #121
2point0
2point0's Avatar
First, make sure the car is level. Each has a fill/inspect plug and a drain plug. The fill/inspect plug is higher up, the level of fluid should be right at or just below the bottom of the hole. It's a pain to check if you don't have tiny fingers. You can always just add a smidge until it starts coming back out, then you know it's full.
If replacing, always remove the top plug first, that way the air can rush in when you remove the bottom one. You'll get a steady stream instead of a gulp-gulp-splash-splash.
Filling is a pain. The Motul bottles have necks on them (doesn't look like it, but it pops out of the bottle) and they say you can fill with just that, but it's not easy to get the bottle high enough to actually pour while under the car. Rig up a hose so you don't have to be underneath, your back will thank you.
kodyo (07-23-2014)
Old 08-13-2014, 12:56 PM   #122
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by mav1178 View Post
Before/after:
Just FYI washer(s) for rear diff are the same size/thickness. Cheaper of the two is part # 1215710010, just buy two of those.
-alex
Yea when I got home and opened the bag, I was wondering what the difference is between the fill and drain washers for the differential. Why two part numbers with Subaru tho?
I got mine at the Toyota dealer, the Subaru part seems to have a more blue sheen to it on the metal, the Toyota part is just straight silver. Unless I'm seeing things.
krayzie is offline   Reply With Quote
Old 08-17-2014, 06:41 PM   #123
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
I put Motul 300LS in my '14 Monogram with like 320 miles on the odometer, didn't notice any difference. If anything it's now a tiny bit worse. Nowhere near as bad as my '13 BRZ was, though...
Maybe the later-production transmission came with better fluid? Or did I use the wrong fluid?
NissanGuy is offline   Reply With Quote
Old 08-23-2014, 05:06 PM   #124
cookiesowns
Drives: WRB BRZ Series.Blue
The LS comes with additional additives? or friction modifiers for LSD's. I'm assuming clutch type.
Not necessary for our Torsen, and I'm under the impression that it's probably not good if not bad for the tranny.
cookiesowns is offline   Reply With Quote
Old 10-08-2014, 07:50 AM   #125
KrazieChryss
Drives: 2015 Halo FR-S
Great DIY write up. Made it a lot easier for me to actually start doing DIY maintenance to my 86. Thank you!
KrazieChryss is offline   Reply With Quote
Old 10-13-2014, 03:41 PM   #126
gutbomb
Originally Posted by B-R-Z View Post
R=Replace
P=Perform
I=Inspect
I know this post is from several months ago but where does this chart come from? I believe the section for inspecting the rear diff oil has the miles and kilometers backwards. Same for the A/C filter.
gutbomb is offline   Reply With Quote
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 03:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 09:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 06:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-21-2012 12:33 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
