Old 10-09-2014, 05:48 PM   #1
JoonPrime
Drives: 2015 Limited series all white brz
strange fluttering sound at high rpm for SC
Hey you guys a question for you as its got me a little worried.
-ive recently gone FI with a kraftwerks SC courtesy of the gentlemen at r/t tuning. I absolutely LOVE it and couldnt think of ever going back, in fact i wanted to get it custom tuned for 93 gas + a header if my bankroll allowed later on.
but the important matter at hand.....and the reason its got me a bit worried is that its only started happening since yesterday. when im driving a bit above the 4500-6000ish rpms, the engines starts to make this weird sound, like a tag fluttering in the window !
is this something to be worried about? i knew going FI had some..possible repercussions..but with the tune so weak i figure my car would have to last longer then just over a few hundreds of miles!
couple notes of my driving habits:
1) most of the driving was done on the highway between 2.7k-3.5k cruising.
2) the only times the car was really punished were for periods less then a minute. (redline from 1-3 and then stopped)
3) the hundreds of miles is closer to around 1200 miles.
is there something i can do to check for damage? should i be very concerned?? thanks in advance guys!
JoonPrime is offline   Reply With Quote
Old 10-09-2014, 07:57 PM   #2
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Not sure what you mean by tag fluttering. But Fluttering is caused by compressed air rushing back down to the blower when you let go of the gas pedal. Pretty much normal IMHO if it's not to much and only happens at the higher RPM's close to redline and letting go of the gas.
FYI: we don't have BOV we have a BPV
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 10-09-2014, 10:45 PM   #3
CSG Mike
CSG Mike's Avatar
Can you record a video of the noise? If you can hear it windows up, then it should be crystal clear on a phone video.
Old 10-10-2014, 12:07 PM   #4
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Any other mods done to the car?
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Freeman is offline   Reply With Quote
Old 10-10-2014, 03:17 PM   #5
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Are you partial throttle in those RPM ranges or full WOT?
If you're at a partial throttle value in an area of the band that is seeing boost, the BPV will open to release pressure and could sound as if it were 'fluttering.' If you're WOT, you should not hear any release until you've shifted and the BPV opens to relieve pressure during that suspension of load between shifts.
KraftWerks is offline   Reply With Quote
Random fluttering/flapping sound when coming to a stop retrosmiths Issues | Warranty | Recalls / TSB 24 10-08-2014 04:13 PM
Yet another strange interior sound. DCStorm Issues | Warranty | Recalls / TSB 5 10-25-2013 12:05 PM
Strange Sound From Noise Tube bkneal Issues | Warranty | Recalls / TSB 6 11-01-2012 05:17 PM
Strange sound coming from my car on idle bcmakesiteasy Engine, Exhaust, Transmission 2 10-05-2012 07:16 PM
Strange sound coming from gas tank? nocurfew Engine, Exhaust, Transmission 6 07-31-2012 03:37 PM
