Old 06-26-2014, 09:49 PM   #1
retrosmiths
Drives: Scion FR-S Whiteout
Random fluttering/flapping sound when coming to a stop
I hear it once a month at most, sounds like some fluttering noise (maybe oil? see below) when slowing down to a stop on neutral. Noise does not change along with speed of the car, and only lasts at most 3 seconds.
The reason why I suspect it's the oil is when I follow the manual and put X amount of oil, I check the dipstick and it's actually on the upper hole. It did sound similar to a bubbling/frothing liquid.
What do you guys think?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 06-30-2014, 11:19 PM   #2
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
If it sounds a bit like some one making motor boating sounds...
then I have the same noise
The sound I hear appears during the last seconds of a full stop.
I had the hood open once with the motor running, and the noise appeared for a few seconds...the noise came from what looks like the brake line distribution box. At least that's what it appears to be..it is connected to the brake power assist and has four brake lines coming off of it. Its mounted under the hood on the drivers side front fender area.. this might be the source of the noise...
This car is a symphony of alarming/amusing,appearing and disappearing noises
Ernie L is offline   Reply With Quote
Old 07-06-2014, 09:34 PM   #3
retrosmiths
Yes, that motor-boating sound!
2013 Scion FR-S
Old 07-07-2014, 05:40 PM   #4
lastexile1987
lastexile1987's Avatar
Drives: Lightning Red '13 Limited BRZ
I seriously thought I read the title of this thread as "random fluttering/FAPPING sound when coming to a stop"
Couldn't stop laughing for a good minute lol
lastexile1987 is offline   Reply With Quote
Old 07-07-2014, 06:20 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
the fluttering sound is the bov...it does that sometimes.
JK
OP, is your foot on the clutch/neutral(jk, I just saw you said in neutral) when this happens? I've noticed it before, and it took a few times before I realized what it is...its the engine almost stalling and saving itself(about 2-3 seconds, as you described-by the time you go "wtf", it stops doing it). Try to check out your rpm's next time, I bet it dips below 500 when it does make the sound.
My car did this like a week after we bought it, and my wife was like, "great, our new car is broken already". Since the car doesn't do it too often, it took a while for me to figure it out. YMMV
Old 07-07-2014, 11:11 PM   #6
aristo
aristo's Avatar
Drives: BRZ SWP 14
Not sure what everyones idea of 'motor boat' sounds like so not sure if I am getting the same thing lol.. but I occasionally get a chatter or rattle like sound when shifted in to neutral coming to a stop and foot on break only.
It's not a fun sound to hear coming from the car so I reflexively clutch in when I hear it happen and it goes away within 1-2 seconds
I have the clutch height adjustment changed if that is perhaps a common factor possibility
nvm this is my problem: http://s421.photobucket.com/user/whs..._1331.mp4.html
http://www.ft86club.com/forums/showthread.php?t=12429
I'm guessing it's not the same thing op is talking about
aristo is offline   Reply With Quote
Old 07-08-2014, 12:52 AM   #7
retrosmiths
http://www.urbandictionary.com/defin...m=Motorboating
2013 Scion FR-S
Old 10-02-2014, 11:48 AM   #8
nfaj
Drives: 2015 BRZ limited 6MT
JK
Did u ever get the car checked out? My car does this too. I'm pretty sure it sounds like detonation
nfaj is offline   Reply With Quote
Old 10-02-2014, 12:17 PM   #9
continuecrushing
Nope, not detonation. Just the sound of the engine almost dying!
Since the rpms drop so much, it causes the engine to feel rough/jerky. I don't wanna say its "normal" but its no harm to the engine. Just feels weird, thats all. If you pick up an OFT, and run one of the base maps you shouldn't have an issue with this anymore.
Old 10-02-2014, 12:18 PM   #10
nfaj
Ok thanks .. I guess it's just chatter like its about to stall oh well lol
Old 10-02-2014, 01:02 PM   #11
continuecrushing
Yup!
Old 10-02-2014, 01:06 PM   #12
These boxer engines make some of the most bizarre noises I have ever heard come out of a car. Coupled with the fact the sound proofing almost does not exist and the engine and tranny are almost in your lap you get to hear things you would not in a "normal" car. I have completely given up with worrying about all the weird and wonderful things I hear from under that hood! Most of the sounds that are pretty much standard with this car would have had me getting one of my old V8s towed because I would refuse to drive it as there would have been something wrong!
Old 10-02-2014, 01:43 PM   #13
tyrantcf
Drives: '16 WRX, CBR1000RR
Theres another thread that I think describes this problem. Was your AC on? If so, the consensus seems to be that the flapping sound is caused by the AC condensor kicking on and lowering the rpms a little below normal idle. Not considered to be a real issue
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 10-02-2014, 02:00 PM   #14
nfaj
ill post a vid its uploading right now to confirm its the same sound. it doesn't happen all the time but when it does I'm like wtf. sounds like engine knock. yes it does happen with ac on but i haven't tried it w/o the ac.
Do you ever feel like an asshole for coming to a complete stop? Ozzman Off-Topic Lounge [WARNING: NO POLITICS] 53 01-20-2014 12:35 AM
Difficult to shift into first when coming to a stop ZackZ Scion FR-S / Toyota 86 GT86 General Forum 21 08-31-2013 12:05 PM
Shifter clicking when coming to a stop larryt1026 Issues | Warranty | Recalls / TSB 1 07-15-2013 07:34 PM
Fixed flapping, clanking sound coming from rear Cornerman Issues | Warranty | Recalls / TSB 2 08-16-2012 09:27 PM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 01:17 AM
