Old 10-07-2014, 03:29 AM   #309
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Seems like it was an arbitrary value for stg1, then they refined it for stg2 and forgot to go back and update stg1. What does it feel like hitting it on stg1?
-14.88 on stg2 looks like this:
http://datazap.me/u/wayne/206-stg2-u...3&zoom=512-522
Old 10-07-2014, 06:24 AM   #310
steve99
Drives: FT86
good pick-up mate
I dont run into limiter much but dont remember it being savage will try it tomorrow just checked my G rom and it -14. unless their is something different man/auto that we dont see in defined tables. might be why it was not in auto rom standard.
Old 10-07-2014, 08:45 AM   #311
Wayno
Wayno's Avatar
good pick-up mate
I just tried -0.12 on the same map as I had -14.88. The difference in the graphs is subtle but what you feel is night and day. -0.12 is really smooth, just stops pulling. -14.88 makes you feel the power fall away sharply.
-14.88 on stg2 -25 deg in 0.2 sec:
-0.12 on stg2 -25 deg in 0.3 sec:
http://datazap.me/u/wayne/206-stg2-u...4&zoom=480-489
Old 10-07-2014, 09:14 PM   #312
steve99
Drives: FT86
Hi @Wayno just tried out limiter with -14 in the 7600rpm row and seems fine on manual rom, soft limit just stops revving at 7600 no jerk no face in dash tried 2nd and 3rd all seems ok. ? maybe some interaction/difference with auto ??.
Did you rescale axis on base timing B to 7600 7450 rpm for last two rows ?
Old 10-07-2014, 09:23 PM   #313
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
There shouldn't be a soft rev limit (last rpm row with low/negative advance in Ignition Advance B table) in 6AT ROMs. If there is, it's a mistake on my part. If this is the case, which exact tune file has this error?
Shiv@Openflash is offline   Reply With Quote
Old 10-07-2014, 09:26 PM   #314
Wayno
Wayno's Avatar
No, I'm not saying there's any error. All the D/I OTS roms just hit the harsh fuel cut at 7600rpm and throw you forward in the seat. I'm just talking about C/G roms having different timing retard between stg1 and stg2.
Old 10-07-2014, 09:45 PM   #315
Shiv@Openflash
Drives: 2013 FRS
The Stg 1 and 2 maps were calibrated at different times and I was testing different soft rev limit settings. One will be softer than the other. Just pick which one you prefer and edit the last row in the Timing B table accordingly.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Wayno (10-07-2014)
Old 10-07-2014, 10:12 PM   #316
Wayno
Wayno's Avatar
Cool
Old 10-09-2014, 01:01 AM   #317
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
ummm my iam is back to 1 from 0.91
does everything look okay?
http://www.datazap.me/u/flippy/frs-9...a=1-8-10-11-12
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
Old 10-09-2014, 01:14 AM   #318
Shiv@Openflash
Drives: 2013 FRS
From what is shown in the logs, looks fine to me.
flippy (10-09-2014)
Old 10-09-2014, 08:19 AM   #319
flippy
flippy's Avatar
thanks shiv you're the best =)
Ps I don't mean to be a grammar Nazi but you have a typo in your sig. Should be "you" instead of "your".
The Following User Says Thank You to flippy For This Useful Post:
chas3wba0 (10-10-2014)
Old 10-10-2014, 12:20 AM   #320
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Just checked the website and saw that the v2.062 OTS maps are available for download.
menikmati is offline   Reply With Quote
Old 10-10-2014, 06:28 AM   #321
chas3wba0
chas3wba0's Avatar
Drives: Yes
OFT OTS v2.062 is now available for download. The only change (as documented the change log) is added support for ZA1JD00D calibration ID. No mapping changes otherwise. So unless you have a ZA1JD00D ROM and are waiting for tune file support, there is no need to download this latest release
Cheers,
Shiv
herp derp
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 10-10-2014, 08:12 AM   #322
FloridaBRZ
Drives: 2013 Subaru BRZ Limited 6sp DGM
With the new update, has anything changed as far as stages? I just have a drop in filter and a Tomei UEL Header. Should I still use Stage 2 UEL? I use 93 octane if that matters at all.
FloridaBRZ is offline   Reply With Quote
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 09:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 08:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 12:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 03:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 09:02 PM
