#29 |
Drives: FR-S 10 Series
#30 |
I wonder if a thick coat of clear plasti dip is durable enough for rust proofing? Clear so you don't have that gross black tar under the car and plasti dip so you can undo it if you need to.
#31 | |
Drives: 2013 BRZ Sport-tech WRB
From what I've read on here about people trying to work on the car after being through a winter or two, I'd recommend it. I didn't end up getting mine rustproofed last winter as I bought the car while I was just about to get into December exams in school and afterward it already had been through plenty of salt. I do plan on rustproofing this year. I think I'm going to go with Corrosion Free. Their website lists the dealers for it and if you can't find an independent shop you can get it done at Crappy Tire. I haven't read anything bad about the product and it is clear and does not drip like Krown or Rust-Check. It isn't like the dealer wax rustproofings that are supposedly good for the life of the car, it's supposed to still be think enough to get into the nooks and crannies of the panels, but viscous enough not to drip everywhere. Take a search in the Canada subforum, there have been plenty of rustproofing discussions. |
#32 | |
Drives: 2015 FR-S
Slip angle (i.e. the difference between the intended direction of a rolling tire with traction and the actual direction in degrees from straight ahead) is important for dry road handling. Tires with smaller slip angles are more responsive to steering input, while tires with larger slip angles are slower to react and more forgiving near the edge. But once you start to skid, slip angle is irrelevant - you're just a bunch of mass sliding across a surface against which you have only kinetic friction to oppose your momentum. And the more mass you have, the more momentum you have - so it's harder to pull out of it. ABS prevents skidding in a straight line - it does nothing for lateral skids. |
#33 | |
Drives: 2015 FR-S
No matter how heavy the vehicle, it's not going to displace all the snow between it and the ground beneath. The snow under the contact patch is compacted, but the tires are still against snow and not road surface no matter how heavy the car, unless the snow's thin enough to be completely displaced by the tread blocks. A Crown Vic has a lot more ground clearance than an FT86, so it can start and track in much deeper snow. When the white stuff reaches the spoiler lip, my car won't go because it becomes a snow plow (a function for which it was clearly not designed). Mass is a benefit for starting traction, but it's a drawback for stopping and cornering. Every article and all state driving manuals tell you the same thing: "Many 4x4 vehicles are heavier than passenger vehicles and actually may take longer to stop"(a quote from the Massachusetts "Safe Driving Winter Tips" section on their DOT website). I drove a '67 Mini Cooper (1300 pounds) all year in Boston on the stock Dunlop SP-41s, and it easily blew through any amount of snow that didn't high-center it. My 350Z was fine in snow with winter tires, as was my '82 Fiat 2000 spider, my '75 Honda Civic, my '85 Mustang GT, my Z3 coupe, etc etc etc. If I had a problem starting on deep snow (which happens from time to time), I used the little shovel I carry in the car to clear tracks from rear to front tires and 10' in front. Once I get started, it's no problem to keep moving (and in the right direction, too). |
#34 | |
And what's with all the old beetle worship? They sucked in the snow.
#35 | |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
#36 | |
Drives: 2015 FR-S
We routinely used studs in those days, and they were really great. I put studded snows on my wife's '74 Buick Apollo (rebadged Chevy Nova) with a 350 (4 barrel, huge duals, real limited slip) and it would climb walls. I'm debating having my Altimax Arctics studded before I put them on next month, but I still remember how unpleasant studs were on dry road. |
#37 |
Drives: BRZ DGM Limited
Even with all season tires (which was fine on every other car I've had in this area) the BRZ sucks in the snow. I suspect since it has small low profile tires there just isn't enough rubber to get enough grip in snow and ice conditions. My car would slide to the side when stopped in front of my house because of the crown in the road!
#38 |
Drives: FR-S 6MT
Last winter we had a couple inches of snow and some ice here in the SE.
I wanted to take the FRS out to see how it handled in the snow.. I backed out of the garage and got stuck on a slight incline! This is on the stock tires.. Which are worthless in the white stuff.. My bimmer is the same way with summer performance tires.. I Leave them parked and stay home.. |
#39 |
WOOOHOOO a 3 month vacation for me then!!!!!!!
So you are saying I would be screwed after this:
#40 |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
I do the same thing in every RWD car I've owned. Taller, narrower snow tire, and drive like a grandma...who likes to hoon about when nobody's around.
#41 |
Drives: 2013 Scion FRS
Don't do what I did and chance it on a performance summer tires....
This is the outcome! [ame="https://www.youtube.com/watch?v=KRFS5gijwQg&list=UUczUWJF4pRfo-6-8RbcS4kQ&index=2"]I sure need some winter tires on my FRS.. - YouTube[/ame] Luckily I did no damage the packed snow on the side of the road cushioned the impact.
#42 |
AIM4APX
Drives: 2013 WRB BRZ Limited
I drove in two large snowstorms last year. One locally, and one while driving from southern Ohio to southern Wisconsin. I had on snow-sport tires and won't suggest anyone use them in anything but light snowfalls regardless of the car, but it wasn't a life changing event. I just had to drive carefully and allow for the conditions. I'll be running a full snow tire this year and can report back after that.
With that said our car isn't worthless in the snow. This is the first winter thread where I've heard people mention that the car can't drive in over 2" of snow (lol...really?) Our clearance isn't that different in stock trim compared to any of the smaller BMW coupes and those are driven all over Europe and the US in RWD configuration in the winter. Yes they are a couple hundred pounds heaver, but I can't imagine that's the only factor that makes them dive-able in the snow. That extra 250 lbs isn't over the rear wheels anyway. I've personally driven at highway speeds, slow speeds, icy conditions, fresh snow, packed snow etc and I think the car is totally usable in the winter. My experience was on snow sports which were OK at the start of the season, and nearly useless at the end of the season. Get a 205/50/17 full snow tire, throw 50lbs of sand in the trunk (if you're really worried) and away you go.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
| quick question about this car in snow | andrewmay9 | CANADA | 32 | 01-03-2015 04:11 PM |
| Buying FR-S. Quick Questions. | maverpl | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 03-28-2014 11:25 PM |
| Quick Release or Quick Lock Steering Wheel and Theft defense too? | 1086 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-24-2014 04:50 PM |
| Few quick BeSpoke questions | NOMNOM | Electronics | Audio | NAV | Infotainment | 0 | 04-17-2013 01:39 AM |
| Few quick set up questions | Im_SPEED | Tracking / Autocross / HPDE / Drifting | 14 | 08-23-2012 03:28 PM |
