Old 09-28-2014, 10:57 PM   #43
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Originally Posted by snidd111 View Post
Just got myself a transmission temp gauge to go with all this when I put it in. Was that T connector essy to find?
It was 4 different pieces. I just walked into a Parker Hose store and told them what I needed. 3/8 barb on one side, 1/2 barb on the other, 1/8 pipe thread hole in the middle.
nlowell is offline   Reply With Quote
The Following 2 Users Say Thank You to nlowell For This Useful Post:
snidd111 (09-28-2014), Tristor (04-30-2018)
Old 09-28-2014, 10:58 PM   #44
snidd111
snidd111's Avatar
Drives: Scion FR-S
Cool. Nothing like that here but I'll look for the equivalent at home depot. Otherwise I'll end up on the interwebs
snidd111 is offline   Reply With Quote
Old 10-01-2014, 08:53 PM   #45
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Hey guys, I did not make it out to the track last night due to a few different factors. We'll just have to do it next week.
In the meantime, here are the pictures requested for the airflow modifications:
Vented Fender Liner:
"T" pattern cutout:
Sithspawn is offline   Reply With Quote
The Following 3 Users Say Thank You to Sithspawn For This Useful Post:
MmmHamSandwich (10-02-2014), myd_lyf_crysys (10-02-2014), Tye300 (10-04-2014)
Old 10-01-2014, 09:00 PM   #46
snidd111
snidd111's Avatar
Drives: Scion FR-S
The cutout is on my to-do list when I put in the cooler. Just used a dremmel?
@nlowell
I'd also love to know the filter that you used
Old 10-01-2014, 09:05 PM   #47
Sithspawn
@nlowell
Yes, a Dremel with an endmill attachment. We are going to setup a special attachment so that we can get cleaner cuts. That way, it would look like it came that way from the factory.
Old 10-01-2014, 10:14 PM   #48
nlowell
nlowell's Avatar
@nlowell
[ame="http://www.amazon.com/gp/product/B0014BCFC0/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1"]Wix 58964 In-line Transmission Filter[/ame]
This was the same (or very similar) filter that Kraftwerks sent in their kit so I figured if its working there...
The Following 3 Users Say Thank You to nlowell For This Useful Post:
MmmHamSandwich (10-02-2014), snidd111 (10-01-2014), Tristor (04-30-2018)
Old 10-01-2014, 10:35 PM   #49
snidd111
snidd111's Avatar
Drives: Scion FR-S
Awesome. Looking at either that or a remote mount version. That way I could swap filters more easily
Old 10-02-2014, 01:04 PM   #50
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Oh yes, yes of course. A filter!
I love the idea, however would adding a radiator, some sort of bypass valve, and a filter lower pressures too much or does it really not have that much of an impact?
I don't really know much about hydraulics outside of firehose.
I am really interested in the capability of adequately cooling the transmission and being able to filter the fluid as well.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 10-04-2014, 02:13 PM   #51
nlowell
nlowell's Avatar
Just completed my first session at buttonwillow - 75 degrees ambient (still early) - pushing the car pretty hard and the temps held mostly steady ~210-215 but I had a peak of 239. The cooler is definitely working. The true test will be when it gets 100 degrees in the afternoon...
The Following 4 Users Say Thank You to nlowell For This Useful Post:
Sithspawn (10-04-2014), snidd111 (10-04-2014), Tristor (04-30-2018), Tye300 (10-04-2014)
Old 10-04-2014, 04:21 PM   #52
nlowell
nlowell's Avatar
Automatic Transmission Fluid Cooler. ??
Second run - 25 minutes - 90 degrees - bested my laptime by 7 seconds (still lots to go). Engine oil temp hit 245, transmission temp was 215 half way through and 230 at the end. I'm happy with that. A little worried about oil temp and that is with a decent cooler.
Sithspawn (10-04-2014), Tristor (04-30-2018), Tye300 (10-04-2014)
Old 10-04-2014, 07:00 PM   #53
nlowell
nlowell's Avatar
Size:  225.5 KB Looks like a cooler line blew... Luckily it was right as I was parking in the pits...
fugh
The Following User Says Thank You to nlowell For This Useful Post:
Old 10-04-2014, 07:03 PM   #54
snidd111
snidd111's Avatar
Drives: Scion FR-S
Any idea why?
Old 10-04-2014, 07:28 PM   #55
Sithspawn
Oh man! That's not good!
Old 10-04-2014, 09:05 PM   #56
nlowell
nlowell's Avatar
Size:  199.2 KBwell, I'm an idiot. I was so used to air line splices I didn't think twice when installing the ATF cooler. It melted a hole right in the fitting. Luckily the race shop here had a metal fitting and I brought my fluid pump and a quart of fluid. I might have lost a little more than a quart but I'm hoping it'll be fine until I get home and drop the pan for my new valve body upgrade.
Don't do what I did kids *roll eyes*
Tristor (04-30-2018), Tye300 (10-05-2014)
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 08:55 PM
Automatic Transmission Cooler RYU Engine, Exhaust, Transmission 9 11-14-2013 03:15 PM
Automatic Transmission Cooler KGFRS86 Engine, Exhaust, Transmission 14 08-26-2013 09:55 PM
Automatic Transmission Cooler, necessary for autoX and Track? BRZPDX Engine, Exhaust, Transmission 4 07-11-2013 08:13 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
