Old 10-03-2014, 03:17 AM   #1
aphxero
Drives: 1978 toyota corona
Rear suspension/axle tech for non owners
Hi all,
I'm hoping we can have a discussion about the frs rear suspension in a non frs application.
I'm currently fitting this to a different car and need to decide what to do with the axle situation. The car is going to be running 15" wheels, it weighs 2500 lbs, has 300tq and will be used for drifting only.
Everything looks good to me except the axles. I can change to a hub with bigger splines and a bigger axle if need be but I don't want to.
Anyhow, I guess I'm mainly looking for people who have broken axles. My questions are:
Anyone here with similar specs doing similar things with the car?
At what point do the axles fail? Ho often do they break?
Thanks bros,
aphxero is offline   Reply With Quote
Old 10-03-2014, 06:40 AM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
DSS makes axles for this car. Otherwise I'm not much help to you.
Old 10-03-2014, 01:57 PM   #3
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I was told that even if the DSS, if the geometry is fucked due to slamming the car, it will still add significant strain on the axles that it can still break. Raising the diff may be a better option to solve the issue, rather than hoping for a stronger piece of metal will hold up with a fucked up angle.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 10-03-2014, 05:39 PM   #4
CSG David
CSG David's Avatar
Even with DSS, you can still possibly mess things up if you intend to mess it up. There's no way around it. Yes you can push the differential up, but based on funding, it's probably a pretty penny as well as illegal in some racing sanctions (hence why there is little support). I think Manji from the Aussie land is working on a solution.
Old 10-03-2014, 08:36 PM   #5
aphxero
Thanks all for the quick replies. I understand since my questions are basically irrelevant to you guys with FRS so it means a lot. If we can get any usable data out of this I'll share it here for sure.
I felt it relevant to mention it's not in an frs because of these reasons. I'm not bound by a sanctioning body so the plan is to put it high in the chassis to get everything level.
Upon inspection the outer spline ends look pretty small next to other toyota 8" axles. The CVs are tiny as well. This concerns me.
I've looked into the DSS axles but can't justify the costs. At this point I'm looking at adapting a stronger oem axle and hub or possibly making new uprights for it. This will probably be more economical especially if it's made from oem parts.
For gearbox we're using a J160. If at all possible I'd like the rear end to be stronger than the transmission.
Anyhow, assuming all the geometry is stock do these puny little axles even stand a chance? Opinions based on experience are much appreciated.
Thanks again,
Old 10-03-2014, 11:41 PM   #6
aphxero
Sorry for the long post but here's some pics from todays research.
Toyota bearing next to frs:
This is an older toyota axle next to FRS. Pretty much all years of 8" axles have the same inner and outer splines so there are many different axle lengths we can try out:
Basically we're working on a solution to adapt that bearing. Even if it requires new brakes it could be worth the effort. We also tried a few different side gear shafts from various toyotas and they all worked. Here's the diff with cressida shafts:
Not that it's relevant to the thread but here's some basic pics of the drivetrain. ST215 engine with EFR 6258 + SXE10 trans/oilpan/accessories and OS Giken TS2B clutch.
Old 10-03-2014, 11:48 PM   #7
gramicci101
Off Topic
What happened to the diff that came with the car? What does the FRS diff give you that the original didn't?
Old 10-03-2014, 11:50 PM   #8
aphxero
It's a 1978 Corona so lots of stuff
Old 10-03-2014, 11:51 PM   #9
gramicci101
Off Topic
Ah, fair enough. There's always room for an upgrade. I saw the car in back and thought it might have been that one.
Old 10-04-2014, 12:35 AM   #10
aphxero
Yeah I shouldn't have had it in the pic. I'd never drive a 240 lol. Been drifting 10 years and never thought about it once. I hate them
This whole thing came up because the other guys on my team have 70's cars. I like toyota so using FRS parts in a 70's thingy makes sense.
my current drift car:
My new drift car:
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 03:56 PM
NEED ASAP!! Rear CV axle 1 or 2 THA STI GUY Want-To-Buy Requests 0 08-27-2014 02:09 AM
Suspension Tech needed!! =D ToyoGT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 02-05-2014 10:27 PM
SUBARU BRZ 2012 R. Axle Beam Suspension Assembly [7753500] JPxM0Dz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-21-2012 12:21 PM
JRP FR-S suspension tech in PAS Magazine! Part 1 Stav Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 09-06-2012 04:01 PM
