Old 09-05-2012, 06:12 PM   #1
Stav
Stav's Avatar
Drives: 13' FR-S Argento,74' Alfa GTV
JRP FR-S suspension tech in PAS Magazine! Part 1
Hi guys,
Here is part 1 of the JRP FR-S build up, here you will see I added all the suspension bits from KW,Cusco and Whiteline. Part #2 will be the Magnaflow and exhaust, Part #3 will be audio upgrades, part #4 Wheels/Tires and forced induction.
Thanks for looking hope it helps others.
Stav is offline   Reply With Quote
Old 09-05-2012, 07:30 PM   #2
Nardi330
Nardi330's Avatar
Drives: 86
thanks for sharing.
is there a reason why you would fit Whiteline rear upper arm camber bush when you are fitting Cusco rear lower arm? i thought the Cusco arm is adjustible for camber already? why need them both together?
cheers
Nardi330 is offline   Reply With Quote
Old 09-06-2012, 01:25 AM   #3
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
I was wondering the same thing, but have two thoughts on it. Maybe to set the initial camber through the bushings, then be able to do fine or quick adjustments for track/street use, and the other would be to just get rid of those super gummy bushings lol. I was literally able to flex all the bushings with my hand moving the arms. They are super soft!!
Also I can't imagine this would affect anything being that it is in the rear, but maybe to help dial in scrub radius, or at least how far the rear wheels stick out in the back of the car.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 09-06-2012, 02:10 AM   #4
Nardi330
Nardi330's Avatar
Drives: 86
Thanks,
Rick
thanks for your reply. seems logical.
if you are replacing the bushing for a harder ones, might as well get the camber adjustible ones for extra function.
Old 09-06-2012, 03:01 PM   #5
Stav
Stav's Avatar
Pretty much exactlly why we changed booth, a) simply more fine tune adjustment as the rear tire was a little bigger than I wanted 265 vs a 255 and the bushing upgrade.
Thank you
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 02:56 PM
MotoIQ: Tech Look at FR-S Underside - Suspension, Chassis, Brakes, Differential oneday Suspension | Chassis | Brakes -- Sponsored by 949 Racing 93 09-22-2017 10:47 AM
JRP FR-S featured in PAS magazine part 1 Stav Canada Classifieds 4 09-07-2012 06:44 PM
