#43 | |
Drives: 2013 Scion FRS
It was 4 different pieces. I just walked into a Parker Hose store and told them what I needed. 3/8 barb on one side, 1/2 barb on the other, 1/8 pipe thread hole in the middle.
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#44 |
Drives: Scion FR-S
Cool. Nothing like that here but I'll look for the equivalent at home depot. Otherwise I'll end up on the interwebs
#45 |
Drives: '14 Hot Lava FR-S w/Flappy Paddles
#46 |
Drives: Scion FR-S
The cutout is on my to-do list when I put in the cooler. Just used a dremmel?
@nlowell I'd also love to know the filter that you used |
#47 | |
#48 | |
This was the same (or very similar) filter that Kraftwerks sent in their kit so I figured if its working there...
#49 |
Drives: Scion FR-S
Awesome. Looking at either that or a remote mount version. That way I could swap filters more easily
#50 | |
You know you want it.
Drives: '13 FR-S
I love the idea, however would adding a radiator, some sort of bypass valve, and a filter lower pressures too much or does it really not have that much of an impact? I don't really know much about hydraulics outside of firehose. I am really interested in the capability of adequately cooling the transmission and being able to filter the fluid as well.
The Following User _________ Stay_Puft(09-13-2014) Says Thank You to MmmHamSandwich For This Useful Post: |
#51 |
Just completed my first session at buttonwillow - 75 degrees ambient (still early) - pushing the car pretty hard and the temps held mostly steady ~210-215 but I had a peak of 239. The cooler is definitely working. The true test will be when it gets 100 degrees in the afternoon...
#52 |
Automatic Transmission Fluid Cooler. ??
Second run - 25 minutes - 90 degrees - bested my laptime by 7 seconds (still lots to go). Engine oil temp hit 245, transmission temp was 215 half way through and 230 at the end. I'm happy with that. A little worried about oil temp and that is with a decent cooler.
#53 |
fugh
#54 |
Drives: Scion FR-S
Any idea why?
#55 |
Oh man! That's not good!
#56 |
Don't do what I did kids *roll eyes*
| Automatic Transmission Fluid Change | jmaryt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 169 | 08-26-2018 07:55 PM |
| Automatic Transmission Cooler | RYU | Engine, Exhaust, Transmission | 9 | 11-14-2013 02:15 PM |
| Automatic Transmission Cooler | KGFRS86 | Engine, Exhaust, Transmission | 14 | 08-26-2013 08:55 PM |
| Automatic Transmission Cooler, necessary for autoX and Track? | BRZPDX | Engine, Exhaust, Transmission | 4 | 07-11-2013 07:13 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
