Old 10-01-2014, 07:14 PM   #715
robhenry2990
robhenry2990's Avatar
Drives: 2013 Whiteout Fr-S 6MT
this may have been answered somewhere as I skipped a couple of pages but is the launch control an actual launch control (ie work with traction control and such to get the best launch) or is it more of a rev limit launch (2step)? thanks in advanced. hoping to have enough money saved to order OFT in the next 2 weeks.
robhenry2990 is offline   Reply With Quote
Old 10-01-2014, 08:12 PM   #716
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by milhouse View Post
Can anyone clarify two points for me?
  • If I am running 93/94 but with 10% Ethanol (screw you, Iowa), should I run the 91 or 93 stg 1 tune?
  • If I have a 2.5" Perrin Intake, should I use the Perrin-provided MAF scaling (as I did when running 1.59), or does @Shiv@Openflash's substantial modifications to the MAF scaling in 2.X mean I should use the defaults?
  • No matter what the answer is above, its still a good ideea to do manual MAF scaling to tweak the above values?
Thanks
Try the 93 and if it knocks reflash to the 91. Different cars and different fuels in different places will have different results. You won't know for sure unless you try it.
I would use the Perrin MAF scaling and then tweak it as per the MAF scaling thread.
It is really just a two step limiter. You could use the factory traction control but I suspect it will just shut off power and bog or you can just modulate the throttle yourself.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
robhenry2990 (10-02-2014)
Old 10-01-2014, 10:44 PM   #717
robhenry2990
Thanks that's exactly what I wanted and what I was expecting. But the genius that shiv is I wouldn't be surprised if he figured out a way to set it all up.
Old 10-02-2014, 02:21 AM   #718
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
Exclamation
alright i just got finished installing the borla uel headers and flashed the stg2 map...
i have a cel that cannot be read/cleared with the oft, it just says no error...
my cruise control no longer works... once i hit the cruise control button, the light comes on on the dash and stays lit... and it's orange, instead of green... i'm sure this has something to do with the launch control/ffs feature.
my frs is 6AT, btw.
any information to guide me in the right direction will be appreciated, thanks !
zAnSh1n is offline   Reply With Quote
Old 10-02-2014, 02:23 AM   #719
troek
troek's Avatar
Drives: 2012 Toyota 86
ATs have launch control??
troek is offline   Reply With Quote
Old 10-02-2014, 02:27 AM   #720
s2d4
s2d4's Avatar
Nope.
Old 10-02-2014, 02:34 AM   #721
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
i may have flashed the MT tune... if that's even possible.
are there 2 different ots stg2 uel 91oct maps ?
Old 10-02-2014, 02:34 AM   #722
troek
troek's Avatar
Did he somehow manage to flash the wrong map?
Old 10-02-2014, 02:45 AM   #723
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
i flashed "Stg 2 UEL B01D"
is this for a manual tranny?
Old 10-02-2014, 02:54 AM   #724
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
should i try flashing another file ?
700D, 900D, A00D, A01D, or B00D ?
im not sure what the differences are...
Old 10-02-2014, 03:00 AM   #725
troek
troek's Avatar
What is your original rom id. I didnt think oft allowed u to flash the wrong rom, but maybe it did
Old 10-02-2014, 04:48 AM   #726
steve99
Drives: FT86
Nope D roms are for Auto's
C series roms are for Manuals. in USA canada
If your in a different country then you need to falsh your own contries specific rom
You obviously don't have an Open flash tablet as it would not flash incorrect map as it compares with your original map stored in tablet.
What device did you flash with
Your car is definitely manual ?
What country are you in
When was your car made
do you have a copy of your original ROM (map ecu file)
if so post it up and I will tell you what your original rom was.
If your manual it certianly was not a D series ROM, you have flashed an Auto rom to a manual car.
If the OBD port is still responding and you canread your rom info your in with a chance of recovery.
If you can no longer interact with the OBD port and read ROM then it likely going to be a new ECU required
Old 10-02-2014, 05:05 AM   #727
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I'm not him (so I can't say for sure), but he bought an OFT from me so I'm assuming that's what he used.
Old 10-02-2014, 05:11 AM   #728
steve99
Drives: FT86
If he is using an OFT I don't know how he could have flashed a D rom into a manual car without resorting to a hex editor. Or he is just really confused
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
