Old 09-29-2014, 11:39 PM   #1
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Timing Chain Cover Leak
Has anyone seen oil leaking from this spot? It's on the driver's side of the engine.
alexand3r is offline   Reply With Quote
Old 09-29-2014, 11:57 PM   #2
phrosty
Is that the CPS plug?
phrosty is offline   Reply With Quote
Old 09-30-2014, 09:26 AM   #3
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Crank Position Sensor? Not sure, it's at the far end of the block on the driver's side. This is a view from underneath the car, btw.
It seems to be coming from the 12mm bolt that's right beside that plug.
Old 09-30-2014, 12:13 PM   #4
Dezoris
Dezoris's Avatar
If I am looking at this picture right its probably the timing chain cover pissing oil.
The Following User Says Thank You to Dezoris For This Useful Post:
naor223 (03-02-2021)
Old 09-30-2014, 01:20 PM   #5
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
My bad, I should have been more specific on the location. I can see how it would look like that, though.
This is at the back of the engine. The head of that 12mm bolt is toward the front of the car.
I was just underneath the car checking the torque on my header bolts when I looked to the left and saw this.
Old 09-30-2014, 01:45 PM   #6
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Then again, maybe I'm smoking crack and my memory is failing me... that definitely looks like the CPS according to the exploded diagram - in which case it would seem that the timing chain cover is indeed pissing oil.
Old 09-30-2014, 01:55 PM   #7
Dezoris
Dezoris's Avatar
Well this is where it looks like to me feel free to update it, if I am wrong.
If its right looks like timing chain cover.
Other thing too is make sure its not wet under your oil filter plate. (Just make sure its not dripping oil from top.)
I dont know your situation if you have oil cooler or someone changes your oil but some idiots can take off filter and spill oil all over and it will drip down.
Old 09-30-2014, 02:01 PM   #8
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I'm seeping oil from that exact same spot.
F1point4 is offline   Reply With Quote
Old 09-30-2014, 02:04 PM   #9
F1point4
Photo Specialist
F1point4's Avatar
here is some more info
http://www.ft86club.com/forums/showthread.php?t=73941
http://www.ft86club.com/forums/showthread.php?p=1617278
http://www.ft86club.com/forums/showt...ing+cover+leak
The Following User Says Thank You to F1point4 For This Useful Post:
alexand3r (09-30-2014)
Old 09-30-2014, 02:08 PM   #10
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Just went out to check, you are exactly right. I don't know why, but I really thought it was farther back on the engine. Thanks for your help.
I'll take it into the dealer and have them fix it, need a new throw out bearing anyway. At 18,000 miles, this is not good.
Updated thread title for ease of search.
Old 09-30-2014, 02:12 PM   #11
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Thanks for the info, I didn't realize this was a widespread problem.
Old 09-13-2015, 06:49 PM   #12
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Resurrection post. I guess I'm relieved to see I am not alone. But very discouraged to see that it looks like a waste of time to get fixed if its just going to start leaking again...
Currently getting an EFR6758 installed when this was discovered. So annoyed. I'm guessing at this point I wont be able to even attempt to have this repaired under warranty. I'm currently at 38k.
What would you guys recommend I do at this point? I don't want to pull the motor myself unless I'm dropping in a built one.
xkalelx is offline   Reply With Quote
Old 09-14-2015, 01:04 PM   #13
tracerit
Drives: '13 SSM BRZ Limited 6MT
wouldn't this be covered under the 5 years/60,000 mile warranty?
tracerit is offline   Reply With Quote
Old 09-14-2015, 01:06 PM   #14
xkalelx
xkalelx's Avatar
That's what I would think but I'm actively voiding my warranty with this turbo build. Wish I would have done a thorough inspection prior to this.
New strange noise? kALMIGHTY Issues | Warranty | Recalls / TSB 45 05-02-2014 01:52 AM
NOW THIS IS JUST STRANGE White64Goat BRZ First-Gen (2012+) — General Topics 37 03-11-2013 09:26 PM
A Very Strange Way to Sell a Car jpit BRZ First-Gen (2012+) — General Topics 4 11-14-2012 11:44 PM
Strange Quirks Aznek Scion FR-S / Toyota 86 GT86 General Forum 30 08-15-2012 09:40 AM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
