Old 05-22-2014, 05:20 PM   #29
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
My FRS died on the side of the road today. EFI/IGN fuse blown and popped instantly when a new one was inserted so I suspected a short circuit somewhere but couldn't locate it on the side of the road. I had it towed back to my shop.
Thanks for the post I'll look over my injector wires and see if anything is shorted out.
Element Tuning is offline   Reply With Quote
Old 05-30-2014, 07:07 PM   #30
Element Tuning
Coil pack #3 has a hole melted in it. Defective I would imagine as I couldn't find a short in any wiring.
The Following User Says Thank You to Element Tuning For This Useful Post:
Target70 (05-30-2014)
Old 09-28-2014, 02:18 PM   #31
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
My car died smack dab in the middle of an autocross course! Better than side of the road. Same 15A EFI Control fuse blowing issue as OP. Had it towed to the dealer (thank goodness for AAA saving me money on that) and will hear back sometime tomorrow. Very unlikely I'll manage any kind of warranty work on this as I've heavily modded the car, but I'll post what I find out.
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 09-29-2014, 01:54 AM   #32
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Happened on mine today, and because of this thread I fixed it.
Injector on cylinder number 3 is the issue. Hits on the metal plate. Just remove the three ecu bolts, and the two 12mm bolts that hold the bracket. The red wire will show skin, and the back plate you will see where it was rubbing. Repaired it with electrical tape over the insulation after inspecting the rest of it and cyl 1. Added a thin rubber seal o avoid metal contact just in case but I doubt it. Replaced the 15amp ign(CTL) fuse, installed the terminals and wala.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
The Following User Says Thank You to *KID* For This Useful Post:
Tcoat (10-01-2014)
Old 09-30-2014, 09:53 PM   #33
BRZnut
Drives: BRZ DGM Limited
any chance of posting a picture of where this rubbing wire is??
Old 10-04-2014, 09:14 AM   #34
BRZnut
Hey..do you guys think we should all check this area and do something to protect the wire now? What side are we talking about anyway...passenger?
Old 01-24-2018, 09:16 PM   #35
ultramarinefrs
Drives: CBR 600 RR
2013 FRS with 60K miles on it died after replacing the battery
[QUOTE=Tt3Sheppard;778003]Turning onto the street in front of my work and across the street from the Toyota dealer my car decided to die. Basically the engine stayed on but would not accelerate. Lights on the dash were abs, traction, battery, and oil light. No check engine light though. Car would not start back up again either.
This exact same thing just happened to me, if I boost the car, it will run fine for a few minutes and than it will stall again. Tt3Sheppard, what resolved your problem? I am out of warranty on my car and can't afford major work to be done. Hoping for DIY on this.
My car had been sitting parked for 3 weeks, I had to replace the battery when I returned. The battery light stayed on after changing the battery, drove fine for maybe 15 miles than the exact same scenario as described by Tt3Sheppard.
Help Please.
ultramarinefrs is offline   Reply With Quote
The Following User Says Thank You to ultramarinefrs For This Useful Post:
Tt3Sheppard (01-24-2018)
Old 01-24-2018, 09:20 PM   #36
[quote=ultramarinefrs;3033288]
Help Please.
Check your battery cable connections. You may have to pull them again and clean them. If that doesn't do it you may be looking at an alternator issue.
BirdTRD (01-25-2018), humfrz (01-25-2018), Spuds (01-25-2018), Tt3Sheppard (01-24-2018)
Old 01-25-2018, 08:36 PM   #37
ultramarinefrs
Drives: CBR 600 RR
Status update;
The mechanic who diagnosed my car confirmed it was the alternator. I will pick up the car tomorrow morning, will update everyone with the details.
The Following 2 Users Say Thank You to ultramarinefrs For This Useful Post:
ScoobsMcGee (01-25-2018), Tcoat (01-25-2018)
Old 01-25-2018, 09:34 PM   #38
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Originally Posted by ultramarinefrs View Post
Status update;
Work can suck the energy out of all of us. Your car was just being empathetic.
The Following 2 Users Say Thank You to ScoobsMcGee For This Useful Post:
Cole (01-26-2018), Tcoat (01-26-2018)
Old 01-25-2018, 11:45 PM   #39
@Tcoat nailed that one ........
Old 01-26-2018, 01:00 AM   #40
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
knowledge is power...
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
The Following User Says Thank You to Ghost of Akina For This Useful Post:
humfrz (01-26-2018)
Old 01-26-2018, 07:05 AM   #41
Your basic electrical issue trouble shooting hierarchy.
1) Power source - Need power to begin with. Battery had been changed already.
2) Connections and wiring - Having power is no good if it cant flow. In the case of the battery power needs to flow in and out.
3) Components/equipment - If you have power and it flows then the issue is with a component. Start with the component that that ensures your power and work forward from there.
humfrz (01-26-2018)
Old 01-26-2018, 11:34 AM   #42
That is so old school ........ the modern technique is just to replace parts till the car works right again .....
Tcoat (01-26-2018)
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 03:14 AM
Anybody rockin Work Kiwami 18x8.5 +38 in the front? serial gixxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-06-2012 07:59 PM
I just died inside. DIG1992 BRZ Photos, Videos, Wallpapers, Gallery Forum 62 07-02-2012 08:51 PM
My DD died today any suggestions? LeavingNormal Other Vehicles & General Automotive Discussions 14 05-27-2012 09:18 PM
Are 17" wheels too big? Might work 16's work a little better? rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-10-2012 10:09 PM
