Old 09-28-2014, 07:06 PM   #631
noob and expert
Drives: None :(
Cool thanks
For me, there is no glide in pulse and glide :p
??? is offline   Reply With Quote
Old 09-30-2014, 08:45 AM   #632
steve99
Drives: FT86
Originally Posted by Live View Post
So, just to ask, not too terribly familiar with how the ECU stores fault codes, but is there any way of retrieving previously cleared fault codes? This would be nice to do when in the market for another car, just to see if there might be some nasty engine codes that a previous owner has cleared before trying to sell the car. Just thought I'd ask to be sure.
With a lot of cars once you clear the code reset ecu , re flash or remove battery codes are gone this is true for brz/86.
not all codes trigger the CEL LIGHT though only the more serious ones
If its an ongoing problem code will trigger again after its cleared.
Although it is possible to disable cel codes by changing parameters in the ECU rom like P0420 cat efficiency code when you run catless headers.
Old 09-30-2014, 10:04 AM   #633
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by ??? View Post
say you have an iphone, is there an alternative that is very similar to this?
Buy a Moto G just for your car. That is what I did
Or even a Moto E. Either way. the phones cost less than 140 dollars straight out.
Old 09-30-2014, 10:36 AM   #634
DC2R
Drives: 2014 Scion FR-S
Buy a Ca-Fi. Free shipping right now so you save $50
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 09-30-2014, 11:27 AM   #635
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
$530 USD vs $100-140 CDN.....
No information on what the deck can do as a stereo..I assume it requires amps?
Old 09-30-2014, 12:50 PM   #636
Foobar
SLO NO MO
Foobar's Avatar
Can use the stock amp. Plug and play for the most part.
Old 09-30-2014, 10:13 PM   #637
DC2R
It does everything and more. Pretty much plug and play
Old 10-02-2014, 09:55 PM   #638
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
I'm using one of the FT86 Layouts and I have a gauge on the main screen that doesn't work. Can anyone tell me what it is? Its the one labelled EXTPID on the left below.
milhouse is offline   Reply With Quote
Old 10-02-2014, 10:24 PM   #639
Poodles
Drives: 2015 Series.Blue
Oil temp.
Also, does anyone know where the theme files are located for torque for a phone without a memory card? I've been unable to find them on my Nexus 4...
Old 10-10-2014, 12:58 PM   #640
Silent_Dan
Drives: 2013 Scion FRS
@Poodles on whatever file viewer program you are using make sure to select ( show hidden files ) in the settings and then look for .torque and you should find it
Silent_Dan is offline   Reply With Quote
Old 10-10-2014, 05:51 PM   #641
Poodles
Tried that, no dice
Old 10-10-2014, 05:54 PM   #642
Silent_Dan
Ahh ok sorry
Old 11-07-2014, 01:59 AM   #643
Junkwipe
Drives: Toyota Gt86
Hey guys i need a little help. I have torque pro ob my smartphone and the obd2 bluetooth in the car, i added the custom pid and all works, exept the oil temp. Anyone can help me? Maybe i have jumped a command or something?
Junkwipe is offline   Reply With Quote
Old 11-07-2014, 08:48 AM   #644
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Post a screen shot of the PID config
B-R-Z is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
