#631 |
noob and expert
Drives: None :(
Cool thanks
For me, there is no glide in pulse and glide :p |
#632 | |
Drives: FT86
not all codes trigger the CEL LIGHT though only the more serious ones If its an ongoing problem code will trigger again after its cleared. Although it is possible to disable cel codes by changing parameters in the ECU rom like P0420 cat efficiency code when you run catless headers. |
#633 | |
Ridge Racerrrrrrrrr
Or even a Moto E. Either way. the phones cost less than 140 dollars straight out.
#634 |
Drives: 2014 Scion FR-S
#635 | |
Ridge Racerrrrrrrrr
No information on what the deck can do as a stereo..I assume it requires amps?
#636 |
SLO NO MO
#637 |
#638 |
Because Racecar
Drives: 2013 Lightning Red Subaru BRZ
I'm using one of the FT86 Layouts and I have a gauge on the main screen that doesn't work. Can anyone tell me what it is? Its the one labelled EXTPID on the left below.
#639 | |
Drives: 2015 Series.Blue
Oil temp. Also, does anyone know where the theme files are located for torque for a phone without a memory card? I've been unable to find them on my Nexus 4... |
#640 |
Drives: 2013 Scion FRS
@Poodles on whatever file viewer program you are using make sure to select ( show hidden files ) in the settings and then look for .torque and you should find it
#641 | |
Tried that, no dice
#642 |
Ahh ok sorry
#643 |
Drives: Toyota Gt86
Hey guys i need a little help. I have torque pro ob my smartphone and the obd2 bluetooth in the car, i added the custom pid and all works, exept the oil temp. Anyone can help me? Maybe i have jumped a command or something?
#644 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
| Tags |
| android, app, boost, gauges, torque |
| Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 04:53 PM |
| Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-22-2012 11:05 PM |
| Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 04:14 PM |
| Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 01:15 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 08:23 PM |
