Old 09-28-2014, 12:50 AM   #1
PPX
Camber Measurement Device
Hello Forum members, please give some input and suggestions on how to implement a self leveling device to measure wheel camber accurately. The device will be self made.
PPX is offline   Reply With Quote
Old 09-28-2014, 01:56 AM   #2
stugray
Drives: 2013 GBS BRZ Limited
I use a craftsman 3 foot digital level.
It has magnets on it to hang on things.
I used those magnets to hold on steel 1/4" X 14" bars that I threaded some small bolts into.
The bolts stick out from the side of the level just enough for me to touch the rim on top & bottom.
It seems accurate to 1/10 degree.
Here's my son measuring
The Following 3 Users Say Thank You to stugray For This Useful Post:
Captain Snooze (09-28-2014), fstlane (09-28-2014), Racecomp Engineering (09-28-2014)
Old 09-28-2014, 02:22 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
That looks freakin' fantastic.
Ummm.... what car is that?
Old 09-28-2014, 07:02 AM   #4
wparsons
wparsons's Avatar
Nothing against Stugray's suggestion, but for that (or anything else) to be accurate you need a totally level floor for the car to rest on. If you can't get that first, don't bother looking further.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
JohnJuan (09-29-2014), mav1178 (09-29-2014), Wayno (09-28-2014)
Old 09-28-2014, 09:45 AM   #5
fstlane
fstlane's Avatar
Drives: BRZ Limited
Here's the one a made a while back that has served me well. It's also self leveling so just place it on the floor in front of behind the tire and press the zero button prior to taking the camber measurement.
http://www.ft86club.com/forums/showp...25&postcount=1
fstlane is offline   Reply With Quote
Old 09-28-2014, 11:39 AM   #6
stugray
It's my other 2.0L boxer engined track car (Porsche 914)
- OR you can use the same level to check the floor/car first and record the degrees out of level.
Nice! Great minds think alike....
The Following 2 Users Say Thank You to stugray For This Useful Post:
fstlane (09-28-2014), JohnJuan (09-29-2014)
Old 09-28-2014, 08:24 PM   #7
wparsons
wparsons's Avatar
That'll get you close, but with enough slope, the suspension will load differently than flat ground and will throw the measurements off slightly.
Now, it'll have to be more than a couple degree slope to do that, so if the ground is reasonably flat you can make it work.
flickr
Old 09-28-2014, 09:16 PM   #8
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
This! I gave up using levels and got the clearance from tire to strut equal.
Old 09-28-2014, 11:08 PM   #9
stugray
While we are on the subject of DIY alignment:
I always make sure to roll the car onto the slab and then make the measurements.
You dont want to try it after jacking the car up and setting it back down.
That will throw off your measurements.
The Following User Says Thank You to stugray For This Useful Post:
wparsons (09-29-2014)
Old 09-29-2014, 08:10 AM   #10
Thorpedo
The SquadWhisperer
Take measurement, mark where tires are, turn car around, measure again. If you get the same measurement on all 4 corners I think you must be fairly close.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 09-29-2014, 11:42 AM   #11
wparsons
wparsons's Avatar
^^ That works too!
I took measurements using my phone and a simple angle app in my garage after driving home from an alignment, and they were within 0.1* at all four corners. Close enough for me
It's also close enough for me to check very so often to make sure nothing has slipped, and takes no time at all.
flickr
Old 09-29-2014, 02:06 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
One way of "fixing" a floor that isn't flat is to use these:
http://www.bbxracing.com/
You can measure the stand locations and offset them just enough to get a "flat" floor for the car to be set on.
I've been drooling over these since 10 years ago or so when I first saw the top ALMS teams using these at the track. They set up the jig to compensate for a non-flat paddock.
-alex
Old 09-29-2014, 02:41 PM   #13
wparsons
wparsons's Avatar
*drooool* I would love a set of those, but there's no way I can justify the costs!
I could pay for like 15 proper alignments before breaking even.
flickr
TRD rear lip measurement Neza21 Cosmetic Modification (Interior/Exterior/Lighting) 8 04-09-2014 01:52 AM
HELP: Stock Exhaust Hanger measurement LeeMaster Cosmetic Modification (Interior/Exterior/Lighting) 4 01-12-2014 02:25 PM
Can you guys take a measurement of your steering wheel badge Xdragonxb0i BRZ First-Gen (2012+) — General Topics 4 03-05-2013 01:18 AM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
trunk measurement question sieeegel BRZ First-Gen (2012+) — General Topics 9 05-05-2012 12:27 PM
