Old 09-25-2014, 07:18 AM   #15
atledreier
Drives: GT86 DGM
Wow, that header is a what you need! :-)
atledreier is offline   Reply With Quote
The Following User Says Thank You to atledreier For This Useful Post:
Circuit Motorsports (09-26-2014)
Old 09-25-2014, 08:43 AM   #16
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
I have both 93 octane and E85 tunes loaded from Bob with absolutely zero issues in the 10 months since they were installed. Bob tuned my car direct, street in the morning and dyno in the late afternoon, 93 one day and E85 the next. Considering the amount of hours involved, the cost minus the dyno rental was a bargain. My car made 205 whp on E85 which translates to 130 mph terminal speed at Roebling versus the 119 stock.
It may be time to come in and get some of the new features added especially if we can eliminate the 30 second 1500 rpm startups!
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
Old 09-25-2014, 11:24 AM   #17
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@Circuit Motorsports I asked in the other tracking/autocross thread but figured here would be more appropriate.....are the gains shown above from the rally car's dyno typical of what can be expected with the nameless header & tune (plus other exhaust bits)??
That's a very impressive gain there especially the torque. Would that tune be applicable to a daily street driven car with same header?
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Calum (09-25-2014)
Old 09-26-2014, 10:37 AM   #18
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Thanks! Has it really been that long? Time goes by so fast! Glad it is still running well for you.
We definitely need to get your tune updated. I've developed and added lots of new features since your tune, including a new cold-start function that is much quieter than stock! Email coming your way soon!
Circuit Motorsports is offline   Reply With Quote
Old 09-26-2014, 10:45 AM   #19
Circuit Motorsports
I really don't have enough data on the nameless header to declare these results typical. The Nameless Performance dyno charts do show massive torque gains in the same area and seem to support the results.
The exhaust on the rally car is not typical of a street driven car in that the exhaust is only the header with a straight pipe -- nearly 0 restrictions. As restrictions in the exhaust are added, I would expect the gains to reduce a bit, but I believe you can still expect a huge torque gain right in the stock torque dip area, and the general torque and power curves to be similar.
My tune with this header would absolutely be applicable to a daily driven street car.
- Bob
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
Fizz (09-26-2014)
Old 11-01-2014, 05:27 PM   #20
Circuit Motorsports
Sneak Peak - GT86 TR
Here's a sneak peak of a Toyota Racing factory race-prepped GT86 (TR 86) we'll be tuning soon, located in New Zealand. This is one of only 20 built. It will soon have some power modifications and other customizations added. See more at http://www.toyota.co.nz/our-range/86...cations/tr-86/
Targa New Zealand Race Thread with Photos and Video: http://www.ft86club.com/forums/showthread.php?t=78490
- Bob
Old 11-22-2014, 09:05 PM   #21
Circuit Motorsports
200whp with PTuning Header Setup
We recently tuned this BRZ with a PTuning Header, making peak 200whp on 93 octane fuel for a 40whp peak gain (Stock BRZ/FRS's run at 160whp/138wtq on this dyno)!
Setup:
2013 BRZ 6MT
  • PTuning EL header
  • Nameless Performance 2.5" Catted Overpipe/Downpipe
  • Perrin 2.5" Resonated Cat-Back Exhaust
  • TRD panel filter
  • 93 Octane Pump Gas
I would have been surprised by the existence of the torque dip had I not seen the dyno charts from PTuning as most aftermarket headers I've tuned remove the dip. But, like the stock header, I was able to minimize the dip with the tune to the point that the dip is not felt at all running through that area at part or full throttle.
Great mid to top-end power, and very smooth!
Tuned with EcuTek RaceRom by Circuit Motorsports
- Tuned by Bob
The Following 4 Users Say Thank You to Circuit Motorsports For This Useful Post:
acro (12-02-2014), slava (11-22-2014), Trefoil (11-22-2014), Wepeel (11-23-2014)
Old 12-01-2014, 06:50 PM   #22
Circuit Motorsports
The Circuit Motorsports Tuned GT86 (TR 86) finished 3rd in class in the Targa New Zealand Race. Results and Information with photos and video have been added here: http://www.ft86club.com/forums/showthread.php?t=78490
- Bob
DeliciousTuning (12-01-2014)
Old 12-18-2014, 04:57 AM   #23
GT86_PRAGUE
Drives: GT86
GT86_PRAGUE is offline   Reply With Quote
Old 02-20-2015, 01:10 PM   #24
Circuit Motorsports
Dialing in the Nameless Perforance 4-2-1 Header - 201whp
BRZ - 201whp with Nameless Performance 4-2-1 Header Setup - Circuit Motorsports, Orlando FL
We dialed in the cam tuning for the Nameless 4-2-1 header, making peak 201whp on 93 octane fuel for a 41whp peak gain (Stock BRZ/FRS's run at 160whp/138wtq on this dyno)! Huge torque gains in the stock torque dip area (3400-4800rpm). This area becomes a torque bubble instead of a dip with these headers.
Setup:
2013 BRZ 6MT
  • Perri CAI (standard size, not the BigMAF)
  • Nameless Performance 4-2-1 Long-Tube Header, coated
  • Tomei Over-Pipe
  • Tomei Front-Pipe
  • Tomei 60s cat-back
- Tuned by Bob
Circuit Motorsports is a Performance Shop in Orlando, FL. We are an authorized EcuTek Master Tuner and perform both E-tunes and dyno tunes. We are a one-stop shop with everything you need from OEM style maintenance to complete builds with performance parts sales, installs and tuning.
Trefoil (10-23-2015)
Old 02-20-2015, 01:35 PM   #25
Koa
daaaaaaaayyymn
The Following User Says Thank You to Koa For This Useful Post:
Circuit Motorsports (02-20-2015)
Old 02-23-2015, 09:48 AM   #26
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Seems like Bob's going to be tuning my ride lol.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
Circuit Motorsports (02-23-2015)
Old 02-23-2015, 10:20 AM   #27
Circuit Motorsports
You have a PM! Looking forward to your tune!
- Bob
Old 03-16-2015, 10:47 PM   #28
Circuit Motorsports
FR-S - Kraftwerks C30 Stock Exhaust - 263whp/234wtq
It's been a while since posting any updates, so thought I'd share the results of a couple of supercharged 86s we dyno tuned recently.
This one was a treat since we rarely get an automatic with forced induction in the shop to tune! Pulls hard, smooth, and strong. We were able to tune it to work seamlessly with the automatic transmission. Shifting in automatic mode was smooth with no issues.
2014 FR-S Automatic
  • Kraftwerks C30 with stock pulley
  • Omni-Power 3bar Map Sensor
  • Stock Exhaust
  • Stock Fuel System
  • 93-octane gas
Tuned on a Mustang dyno - stock FRS puts down 160whp/138wtq on this dyno.
- Tuned by Bob
JonAvalon (03-16-2015)
*** CMS TUNING l Stage1 l Stage2 l E85 l SC l Turbo l FlexFuel l Custom Circuit Motorsports Engine, Exhaust, Bolt-Ons 581 04-12-2016 11:03 AM
Circuit Motorsports Tuning - EcuTek/RaceRom - New and Improved! Circuit Motorsports Software Tuning 7 05-20-2014 03:26 PM
Circuit Motorsports schtebie User/Vendor/Sponsor Reviews, Feedback, Comments 70 03-04-2014 01:59 PM
Circuit Motorsports Bu-Tang User/Vendor/Sponsor Reviews, Feedback, Comments 0 05-24-2013 07:08 PM
Circuit Motorsports SEMA 2012 Coverage - New Whiteline Products + Com-C Update! Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-08-2012 09:00 PM
