Old 09-24-2014, 11:00 PM   #281
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by smellslikecurry View Post
Irrelevant - I had to disconnect my battery for a few hours today. I'm assuming the tune is still loaded in the ECU but will it have to relearn anything? Any precautions i should be taking? I'm on the e85 tune.
Nope. The tune is still there. All you did was effectively reset learning so expect your idle to a bit a little more lumpy until it re-learns. Same with throttle response (initial dead spot) until it re-learns too.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
smellslikecurry (09-25-2014)
Old 09-24-2014, 11:16 PM   #282
tmichel
tmichel's Avatar
Drives: Sonic Blue 2014 GT86
Forgive my ignorance but is there an E85 tune to run on a stock car G series can't seem to find it in either 1.59 or 2.06 ??
tmichel is offline   Reply With Quote
Old 09-24-2014, 11:22 PM   #283
Shiv@Openflash
Drives: 2013 FRS
They are there
Old 09-24-2014, 11:29 PM   #284
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by Shiv@Openflash View Post
They are there
Shiv, I think this proves how little doco the OFT has. The first night I had mine I tried upgrading the dev file, with generated tunes still on the tablet. Then I was up until 3am trying to fix it. I blew one of my erases in the process because I was trying everything. Finally uninstalling openflash manager fixed it. Even if there was just a wiki we could maintain it would be better than than answering the same questions over and over because the answers only exist in 6 month old threads, for previous versions.
The Following User Says Thank You to Wayno For This Useful Post:
chas3wba0 (09-25-2014)
Old 09-24-2014, 11:33 PM   #285
Turdinator
Señor Member
Turdinator's Avatar
They are there and you will love them. Check steve99's thread on it. You use the Stg2 EL 85 map.
1974 TA22 Celica
2013 86 GT
Old 09-24-2014, 11:33 PM   #286
Shiv@Openflash
Drives: 2013 FRS
I think that is a great idea. I have never maintained a wiki before though. I can certainly contribute though
Old 09-25-2014, 01:01 AM   #287
tmichel
tmichel's Avatar
Thanks guys wasn't sure if the EL 85 was the right one . I appreciate all the info on here but some of it just goes way over my head . PS wayno took me many hours to work out how to add a tune as well. Still get lost in how Rom Raider works (which is probably a good thing could do some real damage there).
Old 09-25-2014, 01:11 AM   #288
steve99
Drives: FT86
Have a read of OFT TIPS link below
OFT Tips http://www.ft86club.com/forums/showthread.php?t=71157
when you have that sorted
E85 on stock car
http://www.ft86club.com/forums/showthread.php?t=67310
read here
http://www.ft86club.com/forums/showthread.php?t=74754
then the rest of the links below you should be sorted by then
tmichel (09-25-2014)
Old 09-26-2014, 01:02 AM   #289
cookiesowns
Drives: WRB BRZ Series.Blue
Logging functionality is all done through firmware updates (through OpenFlash Manager), not map files. I assume you have updated your OFT recently (in the last week)? If so, what values are you seeing for Adv Mult and KC?
Yes. OFT is all up to date. I see nothing for adv multiplier, but I see some odd values for KC.
The values will start going up as I put more load, and the values stay consistent.
Please note that this OFT was converted from being registered to a N54 platform. I have the OFT cleared, with the FT86 upgrade template, and fully up to date.
cookiesowns is offline   Reply With Quote
Old 09-29-2014, 12:17 PM   #290
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
I cant seem to find anything about this, either i suck at searching or I am just over thinking things.
It was mentioned that we NEED to use the new XML files for the 2.x maps to work but i did not see any way to specify designate them to be used? Does the program just know to look beside the tune folder for the XML or is there a step that I am missing to update my 1.x tune to 2.x tune
G-Man is offline   Reply With Quote
Old 09-29-2014, 12:41 PM   #291
cnk
Drives: '13 DGM BRZ Limited
You only need the XML files for editing. If you're just trying to load the new maps into your oft, just upload them as usual.
The Following User Says Thank You to cnk For This Useful Post:
G-Man (09-29-2014)
Old 10-02-2014, 11:04 PM   #292
nunonuna
nunonuna's Avatar
Can someone please check mine??
OTS 2.06 stage 1 93 oct
http://www.datazap.me/u/fa20frs/ots-...2&zoom=880-998
Thanks~
nunonuna is offline   Reply With Quote
Old 10-04-2014, 09:23 AM   #293
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Hey guys! I got mine yesterday. The first thing I did was plug it in to OFM and let it do its thing. (I assume it was updating).
After that I flashed the Stage 1 tune onto my car. It feels great, but at 3900 to about 4400 RPM I get a ticking noise. Is this normal? I remember another user had this on his supercharged FRS, but it was a Perrin tune, IIRC.
Other than the AVC tick, the car feels brand new and incredible. Should I have updated the tablet after I read my car's tune?
Bobblehead is offline   Reply With Quote
Old 10-04-2014, 05:31 PM   #294
steve99
Drives: FT86
The growl or change in induction noise is normal around 4000 rpm
you will need to download and apply the new template file via opeen flash manager software or you logging will not work instruction on open flash download page
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Bobblehead (10-04-2014), veck (10-05-2014)
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 09:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 08:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 12:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 03:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 09:02 PM
