Old 09-18-2014, 10:51 PM   #15
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Post
Anyone tried MotylGear 75W-80 https://www.motul.com/system/product...pdf?1328624012
Vis@40°C 58.8
Vis@100°C 10.1
VI 160
or Redline MT-85 http://www.redlineoil.com/product.aspx?pid=140
Vis@40°C 64.3
Vis@100°C 12
VI 172
The long term effects of running something as thin as Pentosin/ATF has to be detrimental to the integrity of the gearbox when the factory spec is 75W-90 surely.
SXE10 is offline   Reply With Quote
Old 09-19-2014, 01:05 AM   #16
imom
Drives: BRZ sold
Vis@40°C 58.8
Vis@100°C 10.1
VI 160
Vis@40°C 64.3
Vis@100°C 12
VI 172
MTL was slightly better than stock. I don't recommend it... and unless you track, I wouldn't recommend Motul either since it's thicker than MTL. Pentosin was best for me.
Saying Pentosin is too thin... well it's stock for my previous car Z4M and most BMWs. Too thick is no good either unless you heat up the gears such as track applications...so mean time the gears aren't lubricated well and have hard time shifting. For most folks...I say go with Pentosin.
imom is offline   Reply With Quote
Old 09-19-2014, 08:05 AM   #17
surcy
Drives: 2014 BRZ Limited
I have been using the Pentosin MTL for 1000 miles and it is night and day better than stock fluid--all gear changes smooth and consistent.
surcy is offline   Reply With Quote
Old 09-21-2014, 11:44 AM   #18
Ferrari
Ferrari's Avatar
Drives: Taking the bus
Update: I changed transmission fluid to Pentosin MTF2. The gear changes are much better when cold. It's not exactly smooth when fully warmed up, but I probably need to give it some time. It's ok so far.
Ferrari is offline   Reply With Quote
Old 09-21-2014, 12:44 PM   #19
viscositosis.rex
Drives: Currently 2018 Taco
The thin fluids don't shear. There is no risk-just more efficient shifting.
viscositosis.rex is offline   Reply With Quote
Old 09-21-2014, 01:02 PM   #20
roddy
roddy's Avatar
Drives: '13 Ultramarine
Give it a week or so...
Old 12-09-2014, 03:43 PM   #21
Ferrari
Ferrari's Avatar
Update: I've been running Pentosin MTF2 in my transmission for the past 10K Km. Initially it wasn't that smooth and didn't like it too much, but once the transmission and fluid got some kilometers on them, things just smoothed out. Now it's very smooth when warmed up, and very driveable when cold. I recommend...
Old 12-09-2014, 06:22 PM   #22
cywinr
Drives: DGM BRZ MT
Originally Posted by Calum View Post
Motul sucks in the cold. Absolutely terrible, as I'm presently finding out. I'm gonna have to see about pentosin.
How cold? Is -10 still ok?
cywinr is offline   Reply With Quote
Old 12-09-2014, 06:44 PM   #23
Ferrari
Ferrari's Avatar
I had problems with it when it was +10*C. At -10*C you probably can't use 2nd gear until the transmission warms up.
The Following 2 Users Say Thank You to Ferrari For This Useful Post:
Calum (12-09-2014), cywinr (12-09-2014)
Old 12-09-2014, 06:47 PM   #24
Calum
That Guy
Drives: 2013 asphalt FRS MT
It was about +10 and when the transmission was cold it was almost undrivable.
I switched to a 50-50 mix of redline mt-90 and mt-85. It worked well. The car is in storage now so I didn't test it in sub zero temps. I wouldn't mind trying straight mt-85, but it'll be a while before I'm changing the fluid again.
The Following User Says Thank You to Calum For This Useful Post:
cywinr (12-09-2014)
Old 12-09-2014, 07:43 PM   #25
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
yay
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 12-09-2014, 08:23 PM   #26
cywinr
Drives: DGM BRZ MT
Wow... that's unacceptable! And I have 4 quarts of Motul 300 sitting here right now...
Old 12-09-2014, 09:38 PM   #27
Calum
That Guy
Throw them on the forsale board, see if someone in Seattle or something will buy them.
It's funny, I've heard nothing but good about Motul, but this one experience hasn't been very positive. More than likely though, that's not the fault of Motul. They just make an oil that fits the spec Toyota & Subaru stamped on the transmission. Gem was likely correct to go to a lower viscosity fluid. Due to local availability though, I'm probably going to stick with redline. I've had very good experiences with their stuff in the past.
Old 01-25-2015, 12:57 AM   #28
Chanpion
Drives: 13 FRS Satin
@Ferrari Have you been out in -20ish weather yet? Curious. I'm guessing there are not as many twin owners as you go to colder places.
It's was averaging -25 a few weeks ago for me and I wouldn't mind having a working 1st and 2nd gear.
Chanpion is offline   Reply With Quote
So for The Transmission Fluid... Just To Make Sure JamesBond000 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 09-12-2014 05:33 PM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 07-03-2014 08:06 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 02:09 PM
