Old 09-17-2014, 03:42 PM   #701
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Originally Posted by chas3wba0 View Post
YES. Been noticing this as well on Stage 1 91oct, only when I try to do a moderate launch from stop in 1st. Never noticed it before flashing 2.0
I have the same problem. It makes trying to pull out in traffic down right scary.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 09-17-2014, 04:01 PM   #702
chas3wba0
chas3wba0's Avatar
Drives: Yes
Oddly enough, I don't have this problem running Stage 2, 91oct, v2.06.
I have the FT86speedfactory catted UEL header, btw
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 09-17-2014, 04:29 PM   #703
zdr93523
zdr93523's Avatar
I'm on stage 2 EL 91.
www.makesmodels.com
www.camautomag.com
Old 09-17-2014, 05:25 PM   #704
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I've tried the 2.0 beta version of the STG2 91 tune for a couple of weeks and it was pretty friggin good. didn't notice any hesitation. Although the stg2 tunes can really benefit from a MAF scale tweaking.
Old 09-17-2014, 06:03 PM   #705
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
True, Maf scaling was very important
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-17-2014, 06:09 PM   #706
zdr93523
zdr93523's Avatar
I think the tune is great other than whatever is causing the hesitation. It only occurs when attempting to accelerate rapidly from a stop. It feels like the gas pedal is dead and doesn't accelerate despite the throttle angle. I found this problem trying to make a left turn across 55mph traffic. Had I left less of a gap, I would have been T-boned for sure since the car decided not to respond to the throttle input.
www.makesmodels.com
www.camautomag.com
Old 09-17-2014, 11:55 PM   #707
solidONE
solidONE's Avatar
Do you think you can catch it in a log? Maybe it can shed some light if you logged both the throttle angle and the throttle position along with some other crucial sensor data. Also, I've read people complaining of a dead pedal after they reflash, but it goes away after they put some miles on it.
Old 09-18-2014, 12:09 AM   #708
zdr93523
zdr93523's Avatar
I doubt it. I can try but it doesn't happen every time.
I am weeks or months after the flash. I may just try to reflash. This should be easy... What changed with 2.0x that
would cause this? @shiv.
www.makesmodels.com
www.camautomag.com
Old 09-18-2014, 12:17 PM   #709
lucid215
i know that @shiv and @steve99 have mentioned that if you are low rpms in 1st and try to floor it, the car will hesitate due to knock. even on stock rom these cars are knock prone in ver low rpms if you floor it or give it alot of throttle. try searching for it in this thread
lucid215 is offline   Reply With Quote
Old 09-18-2014, 12:21 PM   #710
lucid215
http://www.ft86club.com/forums/showp...&postcount=377
Old 09-18-2014, 02:25 PM   #711
zdr93523
zdr93523's Avatar
Originally Posted by lucid215 View Post
Thanks. It sounds like high load, low gear, 17x9 245 (heavy wheels). I'm going to look into some MAF scaling. I had about 4.7 down low.
www.makesmodels.com
www.camautomag.com
Old 10-01-2014, 03:50 PM   #712
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Can anyone clarify two points for me?
  • If I am running 93/94 but with 10% Ethanol (screw you, Iowa), should I run the 91 or 93 stg 1 tune?
  • If I have a 2.5" Perrin Intake, should I use the Perrin-provided MAF scaling (as I did when running 1.59), or does @Shiv@Openflash's substantial modifications to the MAF scaling in 2.X mean I should use the defaults?
  • No matter what the answer is above, its still a good ideea to do manual MAF scaling to tweak the above values?
Thanks
milhouse is offline   Reply With Quote
Old 10-01-2014, 04:17 PM   #713
tomaszjanczak
Drives: Silver Subaru BRZ
Thanks
Sorry don't have much experience with the MAF scaling but for your first question, I got a lot of knock running the 93 oct stage 1 tune with 93 octane fuel (also 10% ethanol). Now I am running 91oct tune with 93 oct fuel and have no problems with knock and honestly, the car feels much faster and smoother on the 91oct tune. The easiest solution would be to just data log using the 93 tune and see if it knocks because if you use the 94 fuel, that might be good enough.
tomaszjanczak is offline   Reply With Quote
Old 10-01-2014, 04:55 PM   #714
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I also run 91 stage 2 uel tune on 93 gas and only get a random occasional knock in my logs. Great gas mileage, feels powerful, all around awesome tune. Its worth sacrificing 2-3 hp for a healthy motor IMO.
B-R-Z is offline   Reply With Quote
The Following User Says Thank You to B-R-Z For This Useful Post:
OrangeGuitar (10-01-2014)
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
