#15 | |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
#16 | ||
Drives: 2022 BRZ Limited
Like I said I had the same issue with 235/40/17 NT01s and those are about .3" smaller then the OEM diameter but having 1.5" drop and softer damper settings were the reasons in my case so, I would be surprised if you didn't rub with those sizes for most tires 235/40/18 means about 25.4-25.5" overall diameter about .7-.8 " taller than the OEM diameter and 265/35/18 is still about .5-.6" taller 245/35/18 is ideal since it's the closest so the OEM size (just like the 245/40/17) so it probably happens because you either need:
at the last track day at RMP I was also trail braking and did the "pedal dance" I wanted to try the softer settings (6-7 clicks from the stiffest) and it immediately started rubbing then using (1-2) clicks fixed that for me FYI, I have 9k swift springs all around and don't use any roll center kit, sway bar or LCA.. I feel that I could've got 11-12k instead Quote:
| The Following User Says Thank You to glamcem For This Useful Post: | rallysrt (09-29-2015) |
#18 |
Drives: 2013 Scion FRS
Unfortunately I've experienced the same thing. For me it's most pronounced coming into turn 7 (the downhill before the straight) at Lime Rock. The suspension is compressed to the max at the same time that you're taking a fast right-hander.
I'm running RCE springs only, and use AD08R tires in 17/225. My guess is the tire is rubbing a bit against the spring, but I'm not seeing any significant evidence of this when removed. There's only about 5mm of clearance between the tire and the front spring so I've always assumed it could be taken care of with some 10mm hubcentric spacers (which I was about to get). Would love to hear if it's more than that. Definitely a little disconcerting when you have to saw your steering inputs to get into a corner with that condition manifesting itself. Here's what the corner looks like (towards the end, at the 55sec mark): [ame="https://www.youtube.com/watch?v=cIwKCFiqfV0&list=UU5kiQpIyiYEL7ZdAZH7R2jw"]Scion FRS @ PCA NNJR Lime Rock 9-10 April 2014 - YouTube[/ame]
The speed was correct, it was the corner that was too tight. |
#19 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
My experience has been that 5mm of tire to spring/coilover collar clearance is not an issue; however, that has been on other cars so YMMV. |
#21 |
Car Nut
Again I have had this issue a few times and my set up is not rubbing at all, so thats also out for me.
Its a mystery. |
#22 |
Drives: 86 GTS
So it isn't just me! Have experienced a strange steering feel on the same corner a few times. Its a big right hander, front left gets loaded up well with the lowest speed through the corner being 90+ mph. (Turn 1 at Phillip Island GP circuit in AUS)
To describe it would be that the steering rack pauses or clicks and you're almost without power steering for a split second. Then its all fine. Doesn't do it every lap or every session but only ever on the same corner at the same track. Only slightly lowered with about 2.5deg camber and decent rubber but there is no rubbing of any kind which would explain it. Have had multiple people go over the entire front end looking for loose bolts or faults and couldn't find anything so it remains a mystery. |
#23 |
Drives: 2013 BRZ Limited SWP 6MT
Back to the issue of overheating the rack, I remember reading something in the owners manual about the steering going stiff after extended "use" of the wheel. They equate it to a lot of quick side to side motion (I took that as fighting the wheel a whole lot) and it said to minimize quick motions and it will go back to normal. So maybe if you notice you're sawing at the wheel when it happens, try to be smoother and see if it goes away.
OVR-SCCA Course Design and SSSI |
#24 | |
Car Nut
#25 |
Drives: 2013 Black FR-S
#26 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | sw20kosh (10-07-2014) |
#27 |
Drives: Hydra EMS Powered FRS Raven Black
I had this problem with stock suspension and sway bars. It's the power steering motor overheat for me. It was brutal at Lime Rock and it's not that you can't muscle past it, it's just a problem with precisely calculating your steering input.
It's a knonw issue with this type of system but then again I was running 285 slicks and now 325s which I don't think many are. For sure check your end links but I had it stock also. |
| The Following User Says Thank You to Element Tuning For This Useful Post: | CSG Mike (10-12-2014) |
#28 |
| rattling when braking | Latiii | Issues | Warranty | Recalls / TSB | 14 | 08-07-2014 12:16 PM |
| Swapping steering wheels with a new tC steering wheel. | jonathan9573 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-20-2013 11:45 PM |
| Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 04:52 PM |
| Steering wheel issue | Khalis | Issues | Warranty | Recalls / TSB | 1 | 05-04-2013 01:19 AM |
| Braking Issue In Mid Drift | imravenit | Tracking / Autocross / HPDE / Drifting | 12 | 02-12-2013 03:16 AM |
