Old 09-16-2014, 10:35 PM   #1
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Should I be concerned
Hey Guys, I need some opinions on this. I bought a perrin crank pulley and just installed it following Perrins guidelines and the DIY guide on this forum. I torqued the bolt down to 33 ft/lbs and inspected the pulley to ensure it was sitting flush when I realized that the bolt wasnt completely centered in the opening for it in the pulley. I took the bolt out, re-seated the pulley, and torued down to 33 ft/lbs and it looked the same. It is alligned properly and all the components behind it are in place. What do you think? Should I be worried??
GotBRZ1691 is offline   Reply With Quote
Old 09-16-2014, 10:36 PM   #2
GotBRZ1691
GotBRZ1691's Avatar
I did my best to take good pictures but it was kind of hard. It is not off by alot, maybe a mm or two. May be me freaking out being OCD and tired, but I do not want my car to sh!t the bed on the way to work tomorrow morning....
Old 09-16-2014, 10:47 PM   #3
Candlejack
Ignorance Intolerant
Candlejack's Avatar
Drives: '13 WRB BRZ Limited
Turn the engine on and watch it spin. Watch for wobble.
Candlejack is offline   Reply With Quote
The Following User Says Thank You to Candlejack For This Useful Post:
GotBRZ1691 (09-17-2014)
Old 09-16-2014, 10:53 PM   #4
SCharged
Drives: asphalt fr-s
You should replace that bolt every time you pull it out. The bolt actually stretches when torqued.
SCharged is offline   Reply With Quote
The Following User Says Thank You to SCharged For This Useful Post:
Old 09-16-2014, 11:10 PM   #5
GotBRZ1691
GotBRZ1691's Avatar
I havent read about anyone replacing it yet? I probs should look into it. It took a lot of force to get it off. I don't think perrin says to get a new one but I'll double check.
Old 09-16-2014, 11:27 PM   #6
John92
Drives: White scion frs
Like @Candlejack said turn the engine on and check for abnormal wobble. You should re-torque it after about 50 miles to ensure everything is good.
John92 is offline   Reply With Quote
The Following User Says Thank You to John92 For This Useful Post:
Old 09-17-2014, 12:15 AM   #7
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Yikes, 33 is to low. As far as I remember should be 90 something for crank pulley bolt.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
The Following User Says Thank You to zoth For This Useful Post:
Old 09-17-2014, 12:17 AM   #8
zoth
zoth's Avatar
Yeap as per DIY 94, hope you did not run your car yet :-(
http://www.ft86club.com/forums/showt...=perrin+pulley
The Following 2 Users Say Thank You to zoth For This Useful Post:
GotBRZ1691 (09-17-2014), JohnJuan (09-17-2014)
Old 09-17-2014, 01:33 AM   #9
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
all bolts stretch ever so slightly when properly torqued, that's what creates and maintains your clamp load. no need to replace unless specified. now if you over torque and the bolt is yielded(stretched beyond elastic region) then it will begin to neck then ultimately fail.
garfull is offline   Reply With Quote
The Following User Says Thank You to garfull For This Useful Post:
Old 09-17-2014, 10:08 AM   #10
GotBRZ1691
GotBRZ1691's Avatar
Sorry guys should have clarified more. Directions say torque to 33 to check alignment then do a final torquing to 94.
It has been torque to 94 ft/lbs with a brand new torque wrench, ANNNDDDDD there is an issue....
It is ever so slightly spattering oil on my exhause manifold because you can smell it. The pulley was clean and is oily now with some black particles on it, which i am assuming is the belt...
My auto tensions is bouncing ever so slightly, but I do not know if this behavior is normal.
I guess the best route of action would be to overnight a bolt, and reinstall with that.
Would it be worth my while to back the bolt out, re seat the O-ring again, and re-torque the bolt I am using? Or would that only stress the bolt further? I have all the tools on me and can easily do. I will most likely have my car towed home anyways.
Old 09-17-2014, 10:10 AM   #11
zoth
zoth's Avatar
Did you replace the o-ring?
Sent from my SM-N900T using Tapatalk
Old 09-17-2014, 10:16 AM   #12
GotBRZ1691
GotBRZ1691's Avatar
[ame="http://www.youtube.com/watch?v=csYmda3dGVY"]FR-S & BRZ High Pressure Fuel Pump Cricket Noise - YouTube[/ame]
According to this the tensioner is suppose to bob a little bit, which make sense in a way, so alignment of the crank pulley which is good.
So one of two things come to mind. The Oil seal O-ring unseated when I pushed the pulley into place - or- the bolt faced to much force and has twisted.
Old 09-17-2014, 10:17 AM   #13
GotBRZ1691
GotBRZ1691's Avatar
I did not replace it with a new O-ring but I did put it back into the space it belongs... It was kind of easy to disturb it so it might have slipped out.
Old 09-17-2014, 10:19 AM   #14
zoth
zoth's Avatar
I believe it's just one those things that you can't reuse anymore or risk having issues. If you going to get a new bolt, get a couple of the orings.
Should I be concerned with coolant and oil level? B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-28-2014 01:03 AM
Kenwood DDX370 concerned/question Sniper2606 Electronics | Audio | NAV | Infotainment 3 01-10-2014 09:48 AM
Concerned with reliability... should I be? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 37 07-01-2013 08:02 AM
wanted white but concerned about paint VENOM~ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 09-05-2012 05:38 PM
