Old 01-10-2014, 12:19 AM   #1
Sniper2606
Sniper2606's Avatar
Kenwood DDX370 concerned/question
I just bought this Kenwood ddx370 for my 13 brz from amazon $200 not bad.
[ame="http://www.amazon.com/Kenwood-DDX370-Double-monitor-receiver/dp/B00B7IPT6Y/ref=sr_1_1?ie=UTF8&qid=1389330874&sr=8-1&keywords=Kenwood+DDX370"]Amazon.com: Kenwood DDX370 Double Din monitor with DVD receiver: Car Electronics[/ame]
I am a bit concerned about the usb port on the car if still be functional or do i need to buy something in order to keep it working? the kenwood unit has a usb port on the back if that helps.
Also are the harness pretty much the same as the stock unit to make a easy plug and play install? or am i needing some type of aftermarket harness?
i really dont wanna pay $50 + for installation, seems easy enough just wanna make sure i do it correctly.
Thank in advance
P.s I will be selling the stock unit if anybody is interested
Sniper2606 is offline   Reply With Quote
Old 01-10-2014, 12:32 AM   #2
Chimera
Drives: FRS
I installed a 470 in my gfs car. Good unit. You will definitely be wanting after market harness adapters. There's a thread on how to keep the USB. With the 370 you are giving up bt?
Old 01-10-2014, 01:05 AM   #3
Sniper2606
Sniper2606's Avatar
Any clue on where i can get the exact harness adapter?
Not really big on the bt, i use my ipod with usb 100% of the time and the bt phone is crap IMO, maybe ill miss pandora on BT, but $87 just for bt seems a bit steep
Old 01-10-2014, 08:48 AM   #4
Chimera
Drives: FRS
Check out crutch field
Should I be concerned with coolant and oil level? B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-28-2014 12:03 AM
Concerned about front track increase affecting ackerman? diss7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-22-2013 11:42 AM
Concerned with reliability... should I be? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 37 07-01-2013 07:02 AM
wanted white but concerned about paint VENOM~ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 09-05-2012 04:38 PM
