Old 09-16-2014, 03:00 PM   #1
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
Steering issue under braking !
I have been noticing this issue for quite a long while. Whenever I try to trail braking into a turn, the steering felt like it is locking up and I need a lot of force to crank the steering before I can turn. The incident gets more worse when the car goes down hill. So in order to avoid it, after I brake, I have to get on the throttle quick and then the steering will not lock up.
Does anyone here experiencing the same issue ?
AJ PwR is offline   Reply With Quote
The Following 2 Users Say Thank You to AJ PwR For This Useful Post:
spdfreak (10-05-2015), YodrOne (09-21-2014)
Old 09-16-2014, 03:50 PM   #2
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
This has happened to me once or twice at auto x.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 09-16-2014, 04:16 PM   #3
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
You might be rubbing the tires hard like I did at ORP one time..
Have you ever checked your inner fender well? Tire and wheel size? and more importantly how much is your car lowered? are you the owner of that white BRZ with the wing? if you are I remember hearing a lot of tire rubbing at your RMP video so that might be your issue
I set my damper settings to the 2 click (from the stiffest) and raised my car about half an inch ( used to be 1.5" drop now it's about 1" all around), it solved the issue (it used to be 6-7 click from the stiffest) and having +35mm offset also helped I think..
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
rallysrt (09-29-2015)
Old 09-16-2014, 04:17 PM   #4
wparsons
wparsons's Avatar
Does the same thing happen if you enter the corner slower, but under the same braking force? If the front end is pushing it can really stiffen up steering effort.
flickr
Old 09-16-2014, 04:26 PM   #5
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
http://www.ft86club.com/forums/showt...t=Peddle+dance
I think this may be up your alley...
Subaru STI :
Old 09-16-2014, 06:17 PM   #6
BRZZZZZZZZZZ
Car Nut
Ive had it happen with both just traction control off, and doing the pedal dance.
The Following 2 Users Say Thank You to BRZZZZZZZZZZ For This Useful Post:
Kimsey47 (09-16-2014), SubiePig (10-13-2014)
Old 09-16-2014, 06:23 PM   #7
CSG Mike
CSG Mike's Avatar
You can muscle past it, but you can fix it by correcting your suspension geometry in the front.
Will Rob be driving your car at SLB this year?
Old 09-16-2014, 06:49 PM   #8
AJ PwR
AJ PwR's Avatar
Thanks everyone !
Couple years back, I had this issue already and I thought my car was too low. My car had about 1.5" drop and was running 235/40/18. It was hitting against the frame above the tire so I raised it about 0.5, lesser problems
This year I was running 265/35/18 problem still there and the recent track days I am running 245/35/18 (I have more wheel gap) , I have about 5 inches clearance between the tire and frame. I need to get on the accelerator sooner so when the weight transfers to the back, the problem goes away but this is not cool that I couldn't trail brake.
I did the pedal dancing so TRACTION is OFF at all times.
Here's what I am running at the front !
- RCA
- coil-overs with 8k springs
- front sway
- all bushings replaced
- roll center tie rods
I have not decide to come or not but if I do Rob will be driving !
The Following User Says Thank You to AJ PwR For This Useful Post:
Old 09-16-2014, 08:51 PM   #9
Kimsey47
Kimsey47's Avatar
Worth a shot since I didn't see it mentioned previously!
Subaru STI :
Old 09-16-2014, 11:34 PM   #10
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Yeah I've had that problem since day one on slicks. The electric power steering is overheating and it basically turns off your steering assist momentarily (or the entire corner).
Element Tuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
dradernh (09-16-2014), Scargod (09-14-2022)
Old 09-16-2014, 11:46 PM   #11
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
What do you think will minimize or eliminate this?
dradernh is offline   Reply With Quote
Old 09-17-2014, 08:39 AM   #12
Element Tuning
I've started to build a liquid cooler for the steering motor but in have yet to install or test it. I got really sidetracked with making the motor relaible at high power. Since I've been able to drive through it I've just dealt with it.
Certain tracks it's worse than others and it's trail braking after a long sweeper that does it for me.
We may do something with the Hydra EMS if the cooler doesn't work that would allow us to tune the power steering to reduce the normal force which should in turn hopefully keep it from overheating so easily.
Thanks,
Phil Grabow
The Following User Says Thank You to Element Tuning For This Useful Post:
dradernh (09-17-2014)
Old 09-17-2014, 09:41 AM   #13
dradernh
Thanks,
Phil Grabow
Good to know. Thanks.
I'll be at the Glen next week in a student's FR-S and will keep an eye out for it when we trail in to T6.
Old 09-17-2014, 12:23 PM   #14
CSG Mike
CSG Mike's Avatar
This doesn't make sense to me; I've driven cars without power steering, and it doesn't have this type of effect.
I've noticed that front geometry has a large impact on how this phenomenon kicks in...
How were you able to determine that it's the electric power steering momentarily deactivating? It's not something we've ever logged or even put a sensor on, since we eliminated the issue on our cars.
rattling when braking Latiii Issues | Warranty | Recalls / TSB 14 08-07-2014 12:16 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 01:19 AM
Braking Issue In Mid Drift imravenit Tracking / Autocross / HPDE / Drifting 12 02-12-2013 03:16 AM
