Old 09-16-2014, 10:54 AM   #1
Drakelee117
Drives: Subaru BRZ 2015
Need a plan for an SC mod? Details inside
So I've been doing some research, and I decided that I am getting an SC mod at the end of this year. Here are my goals and I could really use some suggestions.
Budget:under 6K in total, tax, shipping, installing etc.
Now: Stock 2015 limited BRZ, 6MT
Goal 260 WHP, the more the merrier as long as it's under the budget and reliable.
I am thinking about a supercharger kits probably vortech, performance wheels and tires for now. I don't know much about the clutch or pulleys, but if it meets my need, why not?
No suspension or exhaust unless it's absolutely necessary. I am concerned about the legal issues with emission and noise. Also I like the way the suspension feels right now, I don't want a super modified street racer.
To sum up, four basic principles, reliable, legal, under the budget and not too flamboyant. I am sure which brands to choose except for the SC, so anything would be helpful.
Drakelee117 is offline   Reply With Quote
Old 09-16-2014, 11:06 AM   #2
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
So far I'm having a great time with the vortech kit. No problems whatsoever yet. I'm making 270whp with the stock pulley and fuel system. I do have full exhaust mods though, so 260whp with the stock exhaust system would be doable for sure.
If you are doing the install, you could make budget.
Tye300 is offline   Reply With Quote
Old 09-16-2014, 11:12 AM   #3
s2d4
s2d4's Avatar
Area under the curve.
The Following 3 Users Say Thank You to s2d4 For This Useful Post:
Freeman (09-16-2014), jjkerr626 (09-16-2014), ScionOfHorus (09-16-2014)
Old 09-16-2014, 11:13 AM   #4
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
For $6K USD, you're either a) going to do the install yourself or b) find a used kit.
Good luck though. Don't be discouraged, and the best recommendation is, although you budget $6K, have $8K ready.
Jyn is offline   Reply With Quote
The Following User Says Thank You to Jyn For This Useful Post:
SkAsphalt (09-16-2014)
Old 09-16-2014, 11:20 AM   #5
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
4600 for a shipped SC, and @ 80 an hour for an 8 hour job is still under 6k.
Even at 170 an hour you are still under 6k
-Jack Burton
Old 09-16-2014, 11:41 AM   #6
Jyn
Noob
Jyn's Avatar
From installs and experiences first-hand and that I've read in the past, I've become a bit of a pessimistic estimator. You're right though, it's definitely possible to come in at the 6K mark.
Old 09-16-2014, 11:45 AM   #7
tahdizzle
So elite I'm 1338
If its not his main source of transportation, then a self install would be the way to go anyway. in my opinion.
-Jack Burton
Old 09-16-2014, 11:54 AM   #8
FR-S Matt
Realistically if you do your own work, you can have a full Kraftwerks kit for a hair under $4000 and that does include an oil cooler.
If you want to do it right though:
Oil Cooler
Catch Cans
Radiator
Those 3 are what I think should be required for any FI build regardless of what you use the car for in that order. ~$1100 for those parts. I'm talking about dual catch cans as well in that price.
Tuning is the other part that has to be taken care of which involves a license, cable if you want your own, and tuning time. All that together is probably about 800-900 depending on who you use.
If you can manage to squeeze all that in and do things yourself outside of the tuning, you will be around your 6k budget. The install itself will almost be $1000 if you have someone do it, but SC's are cake to install compared to turbos.
Old 09-16-2014, 12:13 PM   #9
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Oil Cooler
Catch Cans
Radiator
I think the radiator really depends on location, of all the FI guys around here (many of whom track their cars) only one has an aftermarket radiator. No one has any problems with overheating.
Decay107 is offline   Reply With Quote
Old 09-16-2014, 12:48 PM   #10
FR-S Matt
It's very low priority as the stock cooling system is actually really decent. I see 103 degree temps every summer, so I just budgeted it in.
I think the aftermarket fans are actually more beneficial in situations like traffic. I'll probably invest in the FBM fan shroud for my Mishimoto radiator.
@Dezoris also tested aftermarket radiator cooling on the track and the most noticeable difference was the rate at which the temps recovered, which was faster, not necessarily cooler running.
Old 09-16-2014, 12:50 PM   #11
JoonPrime
Drives: 2015 Limited series all white brz
ive been doing my research like you, deciding what to go with and i can tell you with (i think) confidence that unless youre installing on your own, you wont meet a budget of under $6000.... ive got 2 local shops im looking at (one on this forum) to get my stuff done, but regardless of who i go with, i think im looking at 7-8.5k because of installation :O
im just not tech savvy/brave enough to attempt on my own...and unless youve got an excellent friend/dad i wouldnt try either. no point in blowing up your first car cuz you accidently put wire b on a or something ...
tl;dr, i really like phantom and jackracing numbers. personally as a daily driver with no intent of tracking every single weekend, i found them more then suitable and easily managed, at least what ive read. but let me know what u go with! i like hearing as many testimonies as possible!
JoonPrime is offline   Reply With Quote
Old 09-16-2014, 12:52 PM   #12
FR-S Matt
Vortech is a much more difficult install as it requires some shaving down near the A/C compressor. I've read through the manual and that kind of turned me away from the kit. It still is a great kit though.
The Rotrex kits though are super super easy to install. With basic mechanical skill and tools, you can have this installed yourself. The most important part for Rotrex is priming the charger and ensuring no oil leaks. Once you've covered your grounds on that, smooth sailings.
Old 09-16-2014, 01:02 PM   #13
tahdizzle
So elite I'm 1338
I have no idea how you even figure 8k for a supercharger and installation. Unless they are charging you 3k for installation. If that is the case then you fail as a consumer.
-Jack Burton
Old 09-16-2014, 01:04 PM   #14
xwd
Definitely go with one of the Rotrex kits. Vortech is pretty poor under the curve, it's like using a really laggy turbo.
How long do you plan to keep it? PPX BRZ First-Gen (2012+) — General Topics 66 04-18-2014 12:08 AM
I have a plan but I need a sensei MonkeyBoy Scion FR-S / Toyota 86 GT86 General Forum 26 12-12-2013 06:56 AM
When do you plan to get your BRZ? switchlanez BRZ First-Gen (2012+) — General Topics 33 08-16-2013 01:25 PM
XTR Performance BANNED?!?!? - Found out why, Details inside 20FRS13 User/Vendor/Sponsor Reviews, Feedback, Comments 2 01-04-2013 01:01 PM
Battle plan for 200+ whp n/a - Tuners welcome inside seven Engine, Exhaust, Transmission 94 12-26-2012 10:50 AM
