Old 09-14-2014, 09:15 AM   #155
Dipstik-sportech
Dipstik-sportech's Avatar
Originally Posted by Cu0ngsayz View Post
Without going under the car. How can you tell if the axle is broken? Is there a loud humming noise
It won't move
Old 09-14-2014, 09:57 AM   #156
brianhj
Drives: 2017 Camaro 1SS
This thread has the worst title ever
brianhj is offline   Reply With Quote
Old 09-14-2014, 12:02 PM   #157
charged86
charged86's Avatar
because canada
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 09-14-2014, 12:03 PM   #158
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
You'll hear a loud click coming from the broken axle whenever you load it. So when you move from a stop, sudden acceleration, acceleration after a gear change, etc. Sometimes coming off load too, such as in deceleration.
- The Ancient BRZ Sacrament
by Zaku
Old 09-14-2014, 12:19 PM   #159
Dipstik-sportech
Technically it's not broken at that point, it breaking.
Old 09-14-2014, 12:30 PM   #160
Guff
Guff's Avatar
Drives: BRZ LZR
True. But that's all you need for warranty!
by Zaku
Old 09-14-2014, 02:20 PM   #161
stonenewt
Drives: BMW 120d
Originally Posted by OmarGC View Post
Powered by Max differ and subframe risers. Welding requires.
Are you talking about these?
If it's clicking surely the cage has failed but not has not got to the point of catastrophically failed.
stonenewt is offline   Reply With Quote
Old 09-14-2014, 02:38 PM   #162
Dipstik-sportech
Mine clicked forever before it actually snapped.
Old 09-14-2014, 03:13 PM   #163
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Got my broken axle out - same thing as everyone else - snapped the cage in two pieces.
Definitely happened b/c of power AND axle angle, as i hit a dip in the road while accelerating. Ugh. At least I have a spare.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 09-14-2014, 07:52 PM   #164
Cu0ngsayz
Drives: 2013 WRB BRZ
Anyone knows what causes the humming noise when driving? My tires are fine so I know that's not the cause.
Cu0ngsayz is offline   Reply With Quote
Old 09-14-2014, 08:02 PM   #165
Dipstik-sportech
Wheel bearing
Old 12-24-2014, 01:33 AM   #166
stockysnail
Just the tip
stockysnail's Avatar
Car: BRZ '13 (878th made)
Miles: 36500 (happened around 10k miles ago I'm guessing
Use: Daily with 3 track days and 3 autox per year. One drag race with 4 pulls
Suspension: RCE yellow w/ Koni yellow ~1" lower
Power: 250WHP/200WTQ
Forced Induction: Yes, PD supercharger (Innovate intercooled with 70mm pulley)
Axle broke story: Rear drivers side, probably cv joint next to wheel. Just started making a faint click one day randomly. Got a little worse over time. Replaced the axle nut and it went away for about a week. Started clicking again. Tracked the car multiple times and autox with click noise. So far nothing bad has happened. I've taken it to 5 dealers in my area and all of them won't touch my car since it has 'aftermarket suspension components' on it. I even put the stock springs/shocks back on, removed the rear diffuser, and put the rear sway bar back on and still got that story from them. I don't really want to replace the axle with another stock axle if this many people are having issues, so I may just drive it until it breaks and then get the drive shaft shop axles instead even though they cost twice the amount. Although maybe I shouldn't drive it until it breaks because if it breaks on the track while breaking going 120mph, that may not end well.
Old 12-27-2014, 10:15 AM   #167
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I have that same suspension setup. Had the clicking last year was replaced under warranty. Not sure why you have issues.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 12-27-2014, 10:20 AM   #168
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Am I the only one to break the same axel twice?
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
