#57 | |
Drives: FR-S 6MT
All the ones with issues seems to be the ones that have lowered theirs. I don't see that as an OEM issue.. Except that the stock axles aren't designed for more than stock loads, apparently. |
| The Following 2 Users Say Thank You to Mikem53 For This Useful Post: | Junique (09-03-2017), strat61caster (11-14-2013) |
#58 |
WUB WUB
Drives: 2013 Firestorm
i'm up 115 whp over stock, and while i haven't broken an axle yet, once i've got the clutch in, axles are going to be my next big purchase. want to prevent anything going boom
#59 | |
Shipping to Hawaii?...
Drives: '13 Asphalt FR-S
The angle at which the axle should be at from horizontal should be near horizontal. Also, they measured the height change from the wheel hub to diff and it should be no more than 1-2" (25.4 mm to 50.8 mm). These two lines are from the dealer over the phone. Gotto pay to play I guess. Diff risers and subframe risers along with new axles will just have to do for me.
~Matt
Efimia (asphalt FRS) |
| The Following User Says Thank You to markmatley For This Useful Post: | DAEMANO (01-02-2016) |
#60 | |
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#61 |
I've only seen the Driver's side break, unless in extreme use (e.g. drag racing with DR's, boost, etc)
#62 |
Drives: 2006 Toyota Camry
@sierra In your opinion could this also cause issues on stock suspension at stock height over time that is just sped up by the additional stresses of lowering keeping the axles pulled to their limit? Or should stock have enough length to stay safe even over bumps/etc?
#63 | |
Drives: 1990 BNR32 GTR
#64 |
Had Fortune Auto coilovers on at slightly higher than stock rear height levels. Camber was corrected to stock camber by PSM LCA's. Matched the bolt holes of the PSM LCA to the bolt holes of the stock LCA. Same length for no fuss install.
Essentially I took a very nice right hander off the freeway at about 40 mph, as soon as I straightened out and let off the throttle, I heard a snapping sound and immediately fast clunking noises. Pulled off the road, checked engine sound and it was fine. Shifted through all my gears fine. But when I tried to take off again, the clunking continued. Jacked my car up and found the drivers side axle at the diff was sagging and easily moveable. Knew it from there that my axle popped out and/or broke at the diff. Turns out it broke because I couldn't pop it back in. ![]() Basically ordered a new axle and diff risers to help. Hopefully...
~Matt
| The Following User Says Thank You to markmatley For This Useful Post: | strat61caster (01-30-2014) |
#65 |
[||]=(86)=[||]
Drives: 2017 Toyota 86
Ive broke my left and right ride axle. Check the first post...
| The Following User Says Thank You to trueno86power For This Useful Post: | CSG Mike (01-31-2014) |
#66 |
#67 |
[||]=(86)=[||]
Nop... Ive dropped the clutch too hard at 4500 rpm with glue on the track. Ive feel the high grip feeling and right after the axle was gone.
#68 |
Drives: 2014 FR-S in Mayonnaise
So has anybody found a solution for this? I'm looking at getting some BC Racing coils and slamming the whip soon. TIA.
#69 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Powered by Max differ and subframe risers. Welding requires.
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#70 |
Dammit. I wish I didn't have to weld anything. Too bad there are no solid metal inserts for the mounts parallel to the driveshaft that pops into the rear subframe. Could I use a subframe bracing bar in conjunction to the risers?
~Matt
| Tags |
| more money than brains, stance bro |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) General Topics | 48 | 08-09-2013 06:34 PM |
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 05:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
