CANADA Canada
Old 04-28-2012, 11:11 AM   #15
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Originally Posted by MTD View Post
Personally, I dont think the offset plate looks good on any car. It ruins the symmetry of the front. Id run no plate or cover it with a dark tinted cover before an offset kit
Agree with you on the first part. Solution not so much, guaranteed police pullover here.
Sport-Tech is offline   Reply With Quote
Old 04-28-2012, 11:15 AM   #16
MTD
Drives: Hyundai
Yeah, no plates is just asking for trouble here in Ont. I've used the tinted covers on all my cars with no issues though.
MTD is offline   Reply With Quote
Old 04-28-2012, 11:20 AM   #17
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Originally Posted by Klinn View Post
Edit: Hmmm, another idea: depending on the vertical angle of the mesh, if a single flat bar can be slipped in behind it then use long bolts from the plate through the mesh to the flat bar. Basically clamping the plate to the plastic mesh with the plate on one side and the flat bar on the other.
Near the top, the mesh is right up against the black plastic liner behind it and when I tried to wiggle it it did not move. You'd have to seriously deform the mesh to get a bar behind it. Heavy-duty plastic ties similar to what used to bind wiring together might just slide behind the grill to hold the plate. Might look a bit cheap though and the cops may view it as a non-permanent attachment.
Dropping the plate lower so that you go through the open part of the mesh, your idea would probably work, but I think it would make the plate placement awkward, as well as block more of the air flow to the rad. Also the cops may not like such a low placement. I like what WoW did for the placement, it's perfect.
Old 04-28-2012, 11:23 AM   #18
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Not a look I personally like. And I assume you never go on the 407! They have chase cars going after those trying to skirt the license cameras.
Old 04-28-2012, 03:22 PM   #19
Klinn
Klinn's Avatar
Drives: '20 Pure Red BRZ, '20 Torch Red C8
Quite true, but license plates have bolt holes along the bottom too. So if the attachment bar was lined up with the bottom edge of the plate to clamp it to the mesh, maybe that would work. Not as elegant as 'hanging' from the top bolt holes, granted.
What I'm curious about is if there's any way to actually slide the backing bar in there, e.g if there's a gap behind the bottom edge of the fascia but in front of the radiator and you could slide it up into place.
Klinn is offline   Reply With Quote
Old 04-28-2012, 04:23 PM   #20
Turbowned
Turbowned's Avatar
I'll keep mine in the stock location, thank you very much. There's not enough surface area on the bumper cover to run an offset plate without it looking weird. Unlike my current car:
Old 04-28-2012, 06:16 PM   #21
#87
I usually post drunk
#87's Avatar
offset plates look really bad to me. If it bothers you so much just drive without it and pay the ticket if you ever get one. And covering the front grille is a bad idea for cooling if you are going to drive hard for any extended period of time.
#87 is offline   Reply With Quote
Old 04-28-2012, 06:38 PM   #22
Klinn
Klinn's Avatar
Those are some serious flares for an MR2!
Old 04-29-2012, 12:46 AM   #23
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
The bottom hole/bar arrangement should work, although I think you would also have to add transparent ties to the top holes to keep the plate from oscillating wildly in turbulence at speed.
IIRC, there should be no difficulty accessing the back part of the mesh below the bumper, you would have to go under the lip to get there but above that there is considerable space between the mesh and the rad.
One possible issue with the bottom hole mount though is the fact that the mesh is not perpendicular to the ground - it slants in toward the car at the bottom. If you only use the top holes and bolt/screw it into the plastic behind the mesh, the plate will be vertical; using your bottom-mount setup the plate will angle downwards - cops may not appreciate that.
Old 04-29-2012, 01:51 PM   #24
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
According to the Highway Traffic Act for Ontario, grill plate placement will be fine, and ties should be OK as no attachment method is specified - see discussion here:
http://www.ontariohighwaytrafficact.com/topic884.html
Old 05-04-2012, 02:37 PM   #25
Marloon
Drives: 2012 Hyundai Elantra GLS
did anyone come up with a decision yet?
I looked up plate decals - illegal D/T replication of government property.
Marloon is offline   Reply With Quote
Old 05-04-2012, 02:53 PM   #26
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
Drives: 2011 Subaru WRX
Yea, sounds about right . Brz or frs, im gonna use the stock location. Its not bad at all. Ill likely paint the black plate bracket body color to make it look cleaner
Past to Present
CoryUyede is offline   Reply With Quote
Old 05-04-2012, 03:53 PM   #27
Marloon
I'll keep it matte black to match the front grill.
Old 05-04-2012, 03:53 PM   #28
Marloon
GOD! I WANT MY CAR NOWWWWWWWWWWWW. WHERE DO I FREAKING SIGN!
License plate ideas Laika Off-Topic Lounge [WARNING: NO POLITICS] 142 06-13-2015 09:17 PM
License plate mounting ideas? csaba Scion FR-S / Toyota 86 GT86 General Forum 1 04-15-2012 10:58 PM
Delete driver01 Scion FR-S / Toyota 86 GT86 General Forum 17 03-28-2012 01:32 PM
Authenticity plate for the 86 armythug Scion FR-S / Toyota 86 GT86 General Forum 13 11-29-2011 02:06 PM
Do you live in a one plate or two plate state? SCIONIZED Scion FR-S / Toyota 86 GT86 General Forum 36 05-04-2011 05:13 AM
