CANADA Canada
Old 04-27-2012, 10:32 PM   #1
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
Drives: 2011 Subaru WRX
Plate Relocation kit preview (homemade)
Hey, this thread is for anyone considering the Plate Relocation kits that will be available. I figure alot of people are curious what it would look like.
Disclaimer : Yes, Its a BC plate, it's NOT mine, and i know it says Abbotsford Nissan..back off
This was a 5 minute photoshop, so deal with it
All plates are lined up to be DEAD CENTER over the TOW HOOK. Most kits have slide adjustment a few inches up/down left/right..so use your imagination please
BRZ
OEM location
BRZ Tow hook Location
FRS OEM LOCATION
FRS Tow Hook Location
Personally i think the FRS looks good with the offset plate..the BRZ im not so sure of.
Past to Present
CoryUyede is offline   Reply With Quote
Old 04-27-2012, 10:42 PM   #2
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
I think WingsofWar's chop he did at my request looks far better than offset.... the only issue is that doing this leaves your front bumper completely unprotected should someone tap you when parallel parking. (Of course the same is largely true for the offset method.)
Name:  lowered plate.jpg
Sport-Tech is offline   Reply With Quote
Old 04-27-2012, 10:59 PM   #3
Ikaros
Solar wind surfer
Ikaros's Avatar
Drives: 2013 FRS
The tow hook location looks weird for both the BRZ and FR-S cause their bumpers aren't flat, well the BRZ is kinda flat. I think the tow hook option only looks good on the EVO, cause it's much more flat.
Ikaros is offline   Reply With Quote
Old 04-27-2012, 11:28 PM   #4
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Attachment 6936
I understand this is a chop. IRL, how can this be done? I am thinking you need some kind of special screws/threads thing to penetrate the mesh and to the bumper, and that leads me to my next question.
what is the material for that mesh? I think some dealer was suggesting about tying the plate to the mesh instead of using a kit to locate the plate. I wonder, depends on the mesh material, if that is a viable solution.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 04-27-2012, 11:35 PM   #5
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
I gotta agree it looks weird on the side like that. Just doesn't look right on either front end. But going a little lower like on the brz so it's on the mesh seems like a better alternative.
LeavingNormal is offline   Reply With Quote
Old 04-28-2012, 12:17 AM   #6
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
^ Trouble is the BRZ has a somewhat smaller air intake area through the grill than the FR-S, and dropping the plate would cover a good proportion of it up, which could lead to heat issues on track days.
Old 04-28-2012, 12:18 AM   #7
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
My dealer said they could mount it there with ties. But looking at the FR-S in person, I think a more stable mount would be to screw it into the plastic bar behind the upper portion of the mesh.
Old 04-28-2012, 12:24 AM   #8
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
It might be a pain to Fasten it. You'll likely need to put a machine screw + nut on it, which means you need to reach the OTHER side. I have a feeling that black piece behind the upper mesh is very thin. Too thin for a self tapping screw likely.
Past to Present
Old 04-28-2012, 12:38 AM   #9
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Presumably it would be relatively easy to put one arm under the lip to hold a nut and then drive the bolt through it. Even if it's difficult, once the plate is on you are never going to be taking it off. Worst case, might have to do it on a lift at the dealer.
Old 04-28-2012, 12:58 AM   #10
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
yea, i know it's not really a big deal. Just wanted to warn you that's all.
Worst case Scenario the bumper has to come off altogether to get in that area. The 'actual' bumper is right behind that area and could easily be blocking "reach" access. i guess you'll find out?
Past to Present
Old 04-28-2012, 01:37 AM   #11
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
what about an offset plate using the tow hook hole but have it offset yet again, not centered on the tow hook hole. Maybe bring it a bit towards the center of the car.
mattles is offline   Reply With Quote
Old 04-28-2012, 01:40 AM   #12
OrbitalEllipses
Drives: Attitude
I was hoping an offset plate would look better, but unfortunately it doesn't seem that way. A front plate simply ruins the BRZ.
Old 04-28-2012, 09:07 AM   #13
Klinn
Klinn's Avatar
Drives: '20 Pure Red BRZ, '20 Torch Red C8
Yeah, I definitely prefer the arrangement shown in Scion FR-S's post.
If anyone gets a chance to carefully examine the front bumper area, look under the blacked-out portion to see if there are any existing bolts or screws underneath. If so, a flat aluminum bar (or preferably two connected in an 'H' pattern) could be attached using the same bolts and extend forward through the plastic grille mesh with a 90-degree bend to provide attachment points for the plate.
My current summer toy has basically that arrangement. A little wobbly/springy since it's cantilevered out about 10" and the existing bolt locations it uses go into a semi-flexible piece, but it works.
I wouldn't be surprised if somebody comes out with a kit to do this.
Edit: Hmmm, another idea: depending on the vertical angle of the mesh, if a single flat bar can be slipped in behind it then use long bolts from the plate through the mesh to the flat bar. Basically clamping the plate to the plastic mesh with the plate on one side and the flat bar on the other.
Klinn is offline   Reply With Quote
Old 04-28-2012, 09:46 AM   #14
MTD
Drives: Hyundai
Personally, I dont think the offset plate looks good on any car. It ruins the symmetry of the front. Id run no plate or cover it with a dark tinted cover before an offset kit
MTD is offline   Reply With Quote
License plate ideas Laika Off-Topic Lounge [WARNING: NO POLITICS] 142 06-13-2015 08:17 PM
License plate mounting ideas? csaba Scion FR-S / Toyota 86 GT86 General Forum 1 04-15-2012 09:58 PM
Delete driver01 Scion FR-S / Toyota 86 GT86 General Forum 17 03-28-2012 12:32 PM
Authenticity plate for the 86 armythug Scion FR-S / Toyota 86 GT86 General Forum 13 11-29-2011 01:06 PM
Do you live in a one plate or two plate state? SCIONIZED Scion FR-S / Toyota 86 GT86 General Forum 36 05-04-2011 04:13 AM
