Old 03-25-2012, 11:57 AM   #1
driver01
Drives: brz 13
Delete
Delete
driver01 is offline   Reply With Quote
Old 03-25-2012, 03:31 PM   #2
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Yep, we will have you covered! Make sure to reiterate to your dealer that you DONT want them to drill into your new baby.
It is fully adjustable(up/down, left/right, AND angle)
Will be just like this one
http://www.grimmspeed.com/catalog/pr...roducts_id=218
Group buys are sweet...I'll start one right away when the product is ready for you guys.
Justin
GrimmSpeed is offline   Reply With Quote
Old 03-25-2012, 03:56 PM   #3
Canibuz
Canibuz's Avatar
Drives: BRZ SOON!
Justin
<3
The member of the BRZerhood formerly known as Reypt
How to spot a troll
Canibuz is offline   Reply With Quote
Old 03-25-2012, 04:20 PM   #4
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
i thought about this the other day, but i think i'll pass because i want to keep my front end as clean as possible, and not having front plates makes a huge difference...
i will be using a few suction cups and sticking mine in the corner of my front windshield [i know, it's ricey], but it doesn't look bad if you do it right... trust.
zAnSh1n is offline   Reply With Quote
Old 03-25-2012, 04:28 PM   #5
oldskule
oldskule's Avatar
Drives: Mazda
I'm currently considering one of two options, either using the tow hook method as GrimmSpeed mentioned, or zip tying it to the grille of the FRS. Is there any downside to zip tying it? ie. restricts air flow to the engine?
oldskule is offline   Reply With Quote
Old 03-25-2012, 04:32 PM   #6
tachi1247
tachi1247's Avatar
Drives: 04 BMW 330i & 03 Mazdaspeed Protege
In most states that require a front plate what you are talking about is illegal since it is not mounted at the proper height. At that point I would rather not have a front plate at all, which is what I have run on my car for the last 10 years.
tachi1247 is offline   Reply With Quote
Old 03-25-2012, 04:37 PM   #7
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
just checked, < 60" in california...
Old 03-25-2012, 05:02 PM   #8
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
?? I'm confused??
poormans_LFA is offline   Reply With Quote
Old 03-25-2012, 07:29 PM   #9
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
Originally Posted by poormans_LFA View Post
?? I'm confused??
as long as the front plates are mounted [safely/securely/facing forward/right-side up] 60" or lower, you are fine in CA...
i'm sure the location in question, the bottom corner of front windshield, is less than 60" when measured from the ground
Old 03-25-2012, 07:34 PM   #10
#87
I usually post drunk
#87's Avatar
Pretty sure it is 60" from the ground and mounted vertically.
http://www.dmv.ca.gov/pubs/vctop/d03/vc5201.htm
5201. License plates shall at all times be securely fastened to the vehicle for which they are issued so as to prevent the plates from swinging, shall be mounted in a position so as to be clearly visible, and so that the characters are upright and display from left to right, and shall be maintained in a condition so as to be clearly legible. The rear license plate shall be mounted not less than 12 inches nor more than 60 inches from the ground, and the front license plate shall be mounted not more than 60 inches from the ground, except as follows:
http://www.merriam-webster.com/dictionary/upright
Definition of UPRIGHT
1
a : perpendicular, vertical b : erect in carriage or posture c : having the main axis or a main part perpendicular <upright freezer>
#87 is offline   Reply With Quote
Old 03-25-2012, 07:37 PM   #11
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
i'm just going to assume you were replying to poormans LFA...
Old 03-25-2012, 08:13 PM   #12
#87
#87's Avatar
I am just posting the front plate law for California, there seems to be some confusion.
Old 03-25-2012, 09:00 PM   #13
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
right... well, according to the CA law, i CAN mount my front license plate in the bottom corner of my windshield... it is less than 60" from the ground and will be mounted within the guidelines...
Old 03-26-2012, 04:12 PM   #14
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
No, according to State law you cannot. The windshield is not perpendicular to the ground so you can try to get away with this but you're not following the letter of the law so you'll probably get pulled.
Regardless power to you. Front plate requirements are retarded and I'm glad I live in a state that doesn't require such.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
License plate ideas Laika Off-Topic Lounge [WARNING: NO POLITICS] 142 06-13-2015 08:17 PM
Front License Plate Solution? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 72 03-16-2013 02:00 AM
Front License Plate Location Polish Person Scion FR-S / Toyota 86 GT86 General Forum 44 12-16-2011 11:04 AM
Authenticity plate for the 86 armythug Scion FR-S / Toyota 86 GT86 General Forum 13 11-29-2011 01:06 PM
Do you live in a one plate or two plate state? SCIONIZED Scion FR-S / Toyota 86 GT86 General Forum 36 05-04-2011 04:13 AM
