Old 09-09-2014, 12:49 AM   #15
The Sentinel
Project BRZ-Boosted Autos
The Sentinel's Avatar
Drives: MY14 BRZ
Originally Posted by d1ck View Post
Why didn't you burp the air from the coolant system?
We did. This video is an install guide for the product, not an instructional guide for how to bleed the coolant system.
Check out my ProjectBRZ YouTube Channel and Facebook Page for the latest reviews, guides and information.
The Sentinel is offline   Reply With Quote
Old 09-09-2014, 04:08 PM   #16
2013GTRNate
2013GTRNate's Avatar
To the OP TY for this posting. This seems like a better way to install over the other options out there.
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
Old 09-09-2014, 08:47 PM   #17
The Sentinel
Drives: MY14 BRZ
You're welcome
Old 09-09-2014, 09:24 PM   #18
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Why not T into that line so the TB still gets coolant? I have to wonder if your IAT's went up.
post_break is offline   Reply With Quote
Old 09-10-2014, 10:52 PM   #19
TheBatman
TheBatman's Avatar
Drives: Scion FR-S 10 Series
wow. wish I had seen this sooner. bought all the stuff to do it the other way (http://www.ft86club.com/forums/showthread.php?t=50427)
Going to set it up this way, seems much simpler. Maybe I can return all the unused bits...
TheBatman is offline   Reply With Quote
Old 09-10-2014, 11:55 PM   #20
The Sentinel
Drives: MY14 BRZ
The throttle body still gets coolant. The oil cooler is connected in series with the TB.
Old 09-11-2014, 01:04 AM   #21
Panman
Panman's Avatar
Drives: 86 GTS
Originally Posted by Fizz View Post
When connecting the hoses to the TB, does it matter which hose goes to the top and which goes to the bottom?
@The Sentinel - can you clarify which hose goes where or if it matters?
Panman is offline   Reply With Quote
Old 09-11-2014, 01:52 AM   #22
The Sentinel
Drives: MY14 BRZ
Doesn't matter which way around you put them. All it does is invert the direction of flown through the cooler.
Old 09-13-2014, 01:04 PM   #23
TheBatman
TheBatman's Avatar
also, out of curiosity, whats the order of the series? As in, which gets cold coolant first, TB or cooler?
What are the lengths of those hoses?
Old 09-13-2014, 06:38 PM   #24
TheBatman
TheBatman's Avatar
also upon further inspection I've found that one of the oil cooler barbs is a 1/2" while both of the throttle body fittings are 3/8". Does the kit include a step down fitting? Doesn't look like it... just shoving a 3/8" hose on the 1/2" barb?
Old 09-15-2014, 02:12 AM   #25
The Sentinel
Drives: MY14 BRZ
I didn't measure the hose lengths exactly, but all up about 2 meters of hose is required.
As for the barbs, the kit comes supplied with high quality staleness hose clamps, so the slight size difference isn't an issue. We figured that adding additional joints increases the risk of future leaks.
The Following User Says Thank You to The Sentinel For This Useful Post:
FLYFISHR (09-15-2014)
Old 03-07-2015, 01:30 PM   #26
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
This seems so much simpler compared to the directions on the other Forester FA20 DIT thread mentioned above. I may consider doing a complete coolant drain before doing the install to minimize the amount of coolant lost.
mit_peid is offline   Reply With Quote
Old 03-11-2015, 04:15 PM   #27
jfg5067
Can someone post the link to the website that the kit can be found at? I tried from the link previously provided and get no oil cooler kits
jfg5067 is offline   Reply With Quote
Old 03-12-2015, 05:27 AM   #28
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
http://www.nedautoparts.com/collecti...oem-subaru-brz
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
forged performance, oem, oil, oil cooler, temp
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install The Sentinel Engine, Exhaust, Transmission 92 03-09-2015 05:20 PM
Install guide for Cusco Dif Brace? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-01-2014 05:11 PM
Is there a guide to install oem armrest? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-11-2014 11:06 PM
DIY 6000K HID Kit Installation(Scion FR-S ONLY) - Video Guide Alex DIY (Do-It-Yourself) Guides 10 07-09-2013 07:38 AM
Seat belt guide install BRZranger BRZ First-Gen (2012+) — General Topics 28 06-09-2012 09:51 PM
