#15 |
Drives: 2014 FR-S 6MT Whiteout
| The Following 11 Users Say Thank You to phobos512 For This Useful Post: | Bach415 (09-11-2014), ciro (09-10-2014), drewbot (09-09-2014), Element Tuning (09-09-2014), jdcorbitt3 (09-09-2014), Jive Turkey (12-02-2014), Koa (12-29-2014), mfbmike (09-22-2014), number1Tango (11-27-2015), onefitz (09-10-2014), wparsons (09-09-2014) |
#16 |
Shit must be getting serious now...........Formula 1 Tyres...............
| The Following User Says Thank You to White64Goat For This Useful Post: | Element Tuning (09-10-2014) |
#17 |
One of the main reasons I went with the Element Tuning Hydra Standalone and Hydramist meth injection was that Phil took the time to answer my questions thoroughly and was very knowledgeable on everything FA20.
I'm a very happy customer. I think more people should consider running the Hydra Standalone. |
| The Following User Says Thank You to mike the snake For This Useful Post: | Element Tuning (09-10-2014) |
#18 | |
Drives: Hydra EMS Powered FRS Raven Black
In my case the pin the roller rides on physically walked out. Our spring seat pressure really isn't very high in terms of a high performance engine so this isn't a case of too much of a good thing. Oiling was also good and no signs of galling or excessive heat. Purely a case of a factory part fail in a high performance application. We'll address this on any new builds from here on regardless of this possibly being an isolated insident. Thanks, Phil Grabow |
#19 |
#20 |
Automotive Connoisseur
Drives: too many cars
I haven't seen the pins walk out yet on the FA20 rockers but I have seen plenty of the FA20 rockers being shot out of their homes.
LSx Powered 86/ASE Master Certified Automotive Technician
| The Following User Says Thank You to AZFA20 For This Useful Post: | skye67 (09-02-2015) |
#21 |
Drives: 2013 red FR-S, OFT. 2000 Miata SE
I have heard of rotor bearings creeping, particularly in the 13,000rpm range on rotaries. this is due to hitting the resonant frequency of the rotor assembly. the fix was to drill and tap the bearing and rotor and run an allan screw in it.
i suspect you might be hitting harmonic resonance of a part in the rocker arm, like maybe the roller pin. It is amazing to see all the component movement in a high pressure engine like yours. some aircraft engines like the BR710 have a regime where extended time in that regime will cause damage and ultimate failure. john
2013 firestorm FR-S OFT, OFH, U-Haul Trailer Hitch
2007 Stormy Blue Mica PRHT GT NC Miata, OFT |
| The Following User Says Thank You to jdcorbitt3 For This Useful Post: | cdrazic93 (09-10-2014) |
#22 |
That Guy
Drives: 2013 asphalt FRS MT
With this type of valve train valve tip height is exceptionally important when you increase the redline. That said, as long as the valves are ground to the correct height when installed after cutting the seats and lapping, it shouldn't be an issue.
#23 |
Boosted
Drives: Not a supra....yet
Its a pretty common issue with these motors.
#24 |
Drives: 2JZ FRS
I've seen them blow through the valve cover at high revs/power with stock springs, but never with upgraded springs
#25 |
Did you find out if it damaged any internals yet?
#26 |
If the others stayed in place ...... maybe this one just wasn't pressed in correctly ... ??
humfrz |
#27 |
Are those rollers swedged on both sides or just one? How much more valve spring pressure is on tbose stock rockers? At the level you are at could be a rocker issue with the higher rpm or just the rollers not pressed properly. ID want to see the other rollers as well.
Good luck regardless.
#28 | |
Boosted
Dr. Destructo blows a rocker apart
Stock spring pressure is very very soft, to the point that opening them is easily done with a finger Sent from my iPhone using Tapatalk
| Dented rocker panel | daftpunk | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 49 | 08-15-2017 10:41 PM |
| Auto launch blows! | feldy | Engine, Exhaust, Transmission | 83 | 04-14-2017 10:42 AM |
| Rusty Rocker | Nassty | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 04-01-2014 07:47 PM |
| Right quarter and rocker - Ottawa | Mgb_bj70 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 01-01-2014 03:23 PM |
| This blows... | finch1750 | Electronics | Audio | NAV | Infotainment | 19 | 06-21-2012 12:03 PM |
