Old 09-09-2014, 07:39 PM   #15
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following 11 Users Say Thank You to phobos512 For This Useful Post:
Bach415 (09-11-2014), ciro (09-10-2014), drewbot (09-09-2014), Element Tuning (09-09-2014), jdcorbitt3 (09-09-2014), Jive Turkey (12-02-2014), Koa (12-29-2014), mfbmike (09-22-2014), number1Tango (11-27-2015), onefitz (09-10-2014), wparsons (09-09-2014)
Old 09-09-2014, 08:05 PM   #16
White64Goat
Shit must be getting serious now...........Formula 1 Tyres...............
The Following User Says Thank You to White64Goat For This Useful Post:
Element Tuning (09-10-2014)
Old 09-09-2014, 08:06 PM   #17
mike the snake
One of the main reasons I went with the Element Tuning Hydra Standalone and Hydramist meth injection was that Phil took the time to answer my questions thoroughly and was very knowledgeable on everything FA20.
I'm a very happy customer. I think more people should consider running the Hydra Standalone.
The Following User Says Thank You to mike the snake For This Useful Post:
Old 09-09-2014, 09:02 PM   #18
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by dwx View Post
I wish I could find evidence from more than just my memory but I vaguely remember hearing about this happening on a couple cars, even a stock one. Or maybe that was the rocker itself breaking, can't remember.
I know my dealer has seen broken valve springs and then broken valves which can spit the rocker out. I can see a case if using a factory valvetrain that you could float a vakve at 9k rpm and spit the rocker.
In my case the pin the roller rides on physically walked out. Our spring seat pressure really isn't very high in terms of a high performance engine so this isn't a case of too much of a good thing. Oiling was also good and no signs of galling or excessive heat.
Purely a case of a factory part fail in a high performance application. We'll address this on any new builds from here on regardless of this possibly being an isolated insident.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
Old 09-09-2014, 09:05 PM   #19
Element Tuning
Originally Posted by phobos512 View Post
I straight up can't help myself running the gears as this motor is downright nasty at 9k! We will make it reliable as it's just too good to resist.
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
hmong337 (12-30-2016), MINOCIN (09-09-2014)
Old 09-09-2014, 09:48 PM   #20
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
I haven't seen the pins walk out yet on the FA20 rockers but I have seen plenty of the FA20 rockers being shot out of their homes.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following User Says Thank You to AZFA20 For This Useful Post:
skye67 (09-02-2015)
Old 09-09-2014, 10:17 PM   #21
jdcorbitt3
jdcorbitt3's Avatar
Drives: 2013 red FR-S, OFT. 2000 Miata SE
I have heard of rotor bearings creeping, particularly in the 13,000rpm range on rotaries. this is due to hitting the resonant frequency of the rotor assembly. the fix was to drill and tap the bearing and rotor and run an allan screw in it.
i suspect you might be hitting harmonic resonance of a part in the rocker arm, like maybe the roller pin.
It is amazing to see all the component movement in a high pressure engine like yours. some aircraft engines like the BR710 have a regime where extended time in that regime will cause damage and ultimate failure.
john
2013 firestorm FR-S OFT, OFH, U-Haul Trailer Hitch
2007 Stormy Blue Mica PRHT GT NC Miata, OFT
jdcorbitt3 is offline   Reply With Quote
The Following User Says Thank You to jdcorbitt3 For This Useful Post:
cdrazic93 (09-10-2014)
Old 09-09-2014, 11:08 PM   #22
Calum
That Guy
Drives: 2013 asphalt FRS MT
With this type of valve train valve tip height is exceptionally important when you increase the redline. That said, as long as the valves are ground to the correct height when installed after cutting the seats and lapping, it shouldn't be an issue.
Old 09-09-2014, 11:15 PM   #23
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Its a pretty common issue with these motors.
Old 09-09-2014, 11:18 PM   #24
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I've seen them blow through the valve cover at high revs/power with stock springs, but never with upgraded springs
Old 09-09-2014, 11:19 PM   #25
Dipstik-sportech
Dipstik-sportech's Avatar
Did you find out if it damaged any internals yet?
Old 09-09-2014, 11:49 PM   #26
If the others stayed in place ...... maybe this one just wasn't pressed in correctly ... ??
Old 09-10-2014, 12:24 AM   #27
Dezoris
Dezoris's Avatar
Are those rollers swedged on both sides or just one? How much more valve spring pressure is on tbose stock rockers? At the level you are at could be a rocker issue with the higher rpm or just the rollers not pressed properly. ID want to see the other rollers as well.
Good luck regardless.
Old 09-10-2014, 12:26 AM   #28
SmsAlSuwaidi
Boosted
Dr. Destructo blows a rocker apart
Stock spring pressure is very very soft, to the point that opening them is easily done with a finger
Dented rocker panel daftpunk Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 49 08-15-2017 10:41 PM
Auto launch blows! feldy Engine, Exhaust, Transmission 83 04-14-2017 10:42 AM
Rusty Rocker Nassty Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-01-2014 07:47 PM
Right quarter and rocker - Ottawa Mgb_bj70 Exterior Parts (Aero, Lighting, Etc.) 0 01-01-2014 03:23 PM
This blows... finch1750 Electronics | Audio | NAV | Infotainment 19 06-21-2012 12:03 PM
