Old 09-06-2014, 07:50 PM   #1093
haison
Drives: 2014 Subaru BRZ
I recall that changing camber through the plates will adjust the also. How much will toe change with negative 2 degree?
haison is offline   Reply With Quote
Old 09-06-2014, 08:07 PM   #1094
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Originally Posted by neurokinetik View Post
More than alright, DO IT NOW. Get yourself at least 2, and better 3 degrees up front.
-3 seems like a bit much, I'm currently awaiting back ordered camber plates and I am hoping to buy lca's in a month or two. My goal is -2 up front and -1.5 in the rear. Currently at -1.2 front and -2 in the rear...
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 09-07-2014, 08:05 AM   #1095
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Camber is determined by the tire you are running and how you drive it. There is no "magic number" that fits all cars.
Use camber to keep the tire temps even across the tire for the toe setting that feels best for you.
bimmer635csi is offline   Reply With Quote
Old 09-07-2014, 03:02 PM   #1096
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Running -3.2 front , -1.9 rear
I drive to events with it like that.. as long as your toe is good.. should be fine..
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
haison (10-02-2014)
Old 09-07-2014, 06:37 PM   #1097
Turkish
Serial Cone Killer
Turkish's Avatar
Bill
Good to know. Thanks!
... his name is...
C'THULHU
Old 09-07-2014, 08:56 PM   #1098
fstlane
fstlane's Avatar
Drives: BRZ Limited
To add another data point, I'm running -3.2f/-1.8r camber on my daily driven STX build. After 5000 miles, 80 autocross runs and (4) 20min tracks sessions, I still have nearly 5/32" of perfectly even tread wear remaining on my R-S3 v.2s. Some negative camber on these cars is necessary for maximum grip while maintaining good tread wear and driveability.
fstlane is offline   Reply With Quote
The Following 2 Users Say Thank You to fstlane For This Useful Post:
Mad_Mike (11-20-2014), Scooby South (09-07-2014)
Old 09-07-2014, 09:22 PM   #1099
Scooby South
Conedancer
agreed..
Bill
Old 09-07-2014, 09:48 PM   #1100
haison
Thanks guys. . . . I have some camber bolts on order and will get an alignment after it comes in.
The Following User Says Thank You to haison For This Useful Post:
fstlane (09-07-2014)
Old 09-08-2014, 04:52 PM   #1101
conedodging
conedodging's Avatar
Drives: '14 BRZ
Don't see rear top mounts being discussed much. Is there any known benefit to going with something like the Raceseng 1" or 2" versions, over a normal flat top mount (mooresport, etc) or is even re-using the stock rear tophat just fine? Would be with KW V3. Thanks!
conedodging is offline   Reply With Quote
Old 09-08-2014, 07:24 PM   #1102
Thorpedo
The SquadWhisperer
Interested in knowing some opinions as well. I run the whiteline ADK and don't get much dive/squat/roll so it doesn't feel necessary to me. I run the Feal 441s and have pretty limited droop in the rear. I sometimes have them float on the street if there are large bumps and I'm driving somewhat aggressively. In autocross and on track I have no issues though.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 09-20-2014, 04:43 PM   #1103
ksconekiller
Drives: Subaru BRZ
I recently purchased a BRZ and have a question for those of you who have STX-type coilovers. How is the ride on the street? The stock ride is plenty firm, but it seems like a lot of that is because the stock shocks don't have much rebound control. With a set of properly valved coilovers, is the ride on 7-8k springs really any worse? I've seen comments here and there suggesting it's not, but I thought I would try to get opinions from this group.
Thanks for any responses!
ksconekiller is offline   Reply With Quote
Old 09-22-2014, 01:25 PM   #1104
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I don't even have coilovers and the ride is shit.
I couldn't stand driving my car everyday so I parked it and bought something else, which turned out to be equally shitty in terms of ride quality.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 09-22-2014, 01:36 PM   #1105
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
I use ST coilovers. Almost identical to stock going straight but with more response while turning. I recommend them for DD and occasional Auto-x.
Thunderleg is offline   Reply With Quote
Old 09-22-2014, 03:37 PM   #1106
ksconekiller
Drives: Subaru BRZ
Mine won't be a daily driver, but it will get street driven on a regular basis by both me and my wife, so ride quality is a factor. When I had a Miata in STR, it had AST coilovers with springs about 4 times the stock rates, and it rode better than stock. That's the result I'm hoping for with the BRZ.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
