| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2493 | |
Drives: 2014 FR-S Monogram, Whiteout 6MT
+1!!! Looking for the same answer! I'm dropped on springs, ~1.25".
2007 Honda CBR600RR-Pearl White/Silver - Totaled ![]() 2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build) φφκα |
#2494 | |
Drives: FR-S Firestorm 6MT
Why switching out the stock tires though? They're not as bad as you think they are. For all the trouble switching tires, not sure you'll see a difference. What make/model of tire? I'd recommend saving the $$ for other mods. |
#2495 | |
Check the wheel directory and have a look at others here: http://www.ft86club.com/forums/showthread.php?t=35463 http://www.ft86club.com/forums/showthread.php?t=63268 Either run staggered F8.5 +45/R9.5 +45 or go square with an offset closer to +35 to +38 or add 10mm spacers to the front or go with another wheel option |
#2496 | |
Drives: 2015 BRZ Series.Blue in WRB
#2497 |
#2498 |
Drives: 2014 Limited WR Blue Brz
Forgive me if this has been asked before, but I couldn't find anyone on this particular thread with the STi lowering springs...will either 17x9 +35 or 18x8.5 +38 fit on stock suspension with STi lowering springs?
#2499 |
Not sure on lowering specs for the STi springs, but you should be fine with that setup!
| The Following User Says Thank You to Slick For This Useful Post: | ModalSoul37 (09-05-2014) |
#2500 |
#2501 |
#2502 |
#2503 |
Drives: 2013 SWP BRZ
Hey guys - I'm thinking of purchasing some wheels that are 17x8 Offset 42. I am going to be lowered on the RCE springs (~.8" drop). Will I have any issues clearing the spring perch or any other rubbing issues? Thanks for the input.
"Don't be a don'ter, do be a doer" - Johnny Wu
#2504 |
That's a good offset for that wheel, no issues at all with inside or outside clearance.
#2505 |
Thanks, Slick - much appreciated.
#2506 |
Drives: white gt86
Hey guys, I've searched this thread quite a bit and gotten a vague idea of an answer but just want to be sure:
Looking to go 18x9 et38 XD9s all round and I’m currently on a 1” drop from Eibach pro kit springs. Now due to the laws in Australia I can’t poke out any further than the stock fenders (correct me if my wording is a bit off). With 235/40/18 or 245/35/18, would this be fine to avoid rubbing as well as poking in order to stay legal? Perfect flushness isn’t that much of a concern, just want to avoid being defected! Daily driving use btw. Much appreciated. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
