Old 09-02-2014, 10:28 PM   #2045
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Originally Posted by Squishy View Post
I am about the same running 0w30 Amsoil SS and get about 24-25 mpg if I am cautious. I think I would get closer to 28-30 if I went back to 0w20.
But the Texas heat and track days says I can put up with little less mpg.
What's your average temp. running around town? Mine gets all the way to 234 @ about 70-60 mph and 220 to 228 in City.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 09-03-2014, 04:02 AM   #2046
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
a little update, I've installed the new belt (it's fairly easy if know someone who can help holding the bracket and the supercharger)..
It held up just fine at the last event...too bad I could only drive for couple sessions since it started raining really bad
@KraftWerks @moto-mike
[ame="http://youtu.be/hIgpo7q_6GI?"]http://youtu.be/hIgpo7q_6GI?[/ame]
glamcem is offline   Reply With Quote
Old 09-03-2014, 07:46 AM   #2047
Squishy
Drives: 2013 WRB BRZ
No idea yet as I am still waiting on my dual gauge cluster pod to install my oil temp and pressure gauge into. The sensors are installed and wires routed but the gauges are not connected yet. I will let you know as soon as I get a couple things sorted out (1. leaky drain plug on my radiator due to galvanic corrosion so I have to tap that out to replace it. 2. the cluster pod to actually put up my gauges I have sitting on my living room floor).
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
Old 09-03-2014, 09:22 AM   #2048
Model Citizen
Lacking brains
Drives: frz
It was pretty easy to do alone also, what i did was loosen all the mounting points enough to get some play on the plate, then pull the bolts back from one area (lower left iirc) and slip the belt through. Then retighten.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 09-03-2014, 09:31 PM   #2049
zoth
zoth's Avatar
@KraftWerks Oil cooler sandwich plate and oil filter mounted.
Old 09-04-2014, 06:43 PM   #2050
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Beautiful!
Let us know if you need anything further!
KraftWerks is offline   Reply With Quote
Old 09-04-2014, 08:05 PM   #2051
DrWill
DrWill's Avatar
Drives: whiteout FR-S
Does any one know the highest numbers that have been put up on the c38 kit on pump and e85?
DrWill is offline   Reply With Quote
Old 09-04-2014, 09:00 PM   #2052
SPCorBUST
SPCorBUST's Avatar
Probably mine, but I had stock everything and was the first tune all other Delicious tuned c38s are based on. I'd say to expect 385whp on a dynojet with e85 on an otherwise stock motor normally, you won't care about pump after being on that, lol.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 09-04-2014, 09:01 PM   #2053
SPCorBUST
SPCorBUST's Avatar
Maybe someone pegged more after me with some other mods on top of the kit and a revised tune.
Old 09-05-2014, 12:54 AM   #2054
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Got my kit today.. Finally.. C38 black, smaller pulley, church is tunning next Thursday here in Vegas. We lose a couple lbs of pressure due to elevation so right now unsure what the actual PSI will be. 900cc deatschwerks injectors walbro 255 pump. 91 map and E85 map. Running MXP UEL headers over pipe, and catless front pipe, greddy EVO3 cat back. I'll post up numbers next Thursday, I'm installing the kit on Sunday, Monday the injectors will be in.. After installing these in other guys cars, selling them to others it finally my turn to get one..
Gixxersixxerman is offline   Reply With Quote
Old 09-05-2014, 02:18 AM   #2055
SPCorBUST
SPCorBUST's Avatar
900 is huge! Small pulley, injectors, corn and revved out a little longer plus all the exhaust mods... Maybe optimistic, but maybe you could see 430 wheel, that would be crazy
Old 09-05-2014, 03:14 AM   #2056
Gixxersixxerman
We'll KW said I have to drop the revs to 7300.... But... Well we will see.. Shawn expects 380-400 up here.. I really wanted 8k on the rev limit, but won't happen on the C38.. The injectors will flow 1050 at 51 psi fuel pressure I think, and I've been told they see around 50 so it should be more then 900cc.. I didn't want to run that big, but I guess it's better to run slightly bigger then to small,..
Old 09-05-2014, 04:14 AM   #2057
CSG Mike
CSG Mike's Avatar
If this is the Shawn I'm thinking, you're in great hands!
Old 09-05-2014, 12:55 PM   #2058
Gixxersixxerman
Shawn church??? I hope so lol, I really wanted to go through with bill at delicious, but we refuses to answer emails, text or calls, and we can't use him for the business any more.. The tune he did for the other car is really bad, he won't fix it, so we had to look else where.. Moto east was my next choice, but seeing as church comes here every other Thursday I decided to go that route.. So we will see how it goes
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
