go_a_way1
Old 09-05-2014, 03:37 AM   #2493
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
Originally Posted by K-NoMs View Post
Will a set of Enkei T6S 18x9.5 with +45 offset and 1 inch drop fit? I apologize of this has been asked before, searching through 100 pages on my phone is a little hard.
+1!!!
Looking for the same answer! I'm dropped on springs, ~1.25".
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
Old 09-05-2014, 09:46 AM   #2494
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by Neokolzia View Post
I'm on Stock Wheels (Limited Aozora so STI rims), but my father has some 205/45R17's that are good quality, picking up my car tomorrow, and wondering if I should even bother putting these on? They are decent quality ZR's compared to the original, I know they'll fit but just wondering if its remotely a good idea or should I consider trading them for a better pair?
Should be fine. Slightly smaller than OEM in width and therefore also diameter.
Why switching out the stock tires though? They're not as bad as you think they are. For all the trouble switching tires, not sure you'll see a difference. What make/model of tire?
I'd recommend saving the $$ for other mods.
Slick is offline   Reply With Quote
Old 09-05-2014, 09:55 AM   #2495
Slick
Slick's Avatar
Sorry guys, unless you're on coilovers or stock suspension, nope. They will fit on the rear but not up front unless you add a spacer.
Check the wheel directory and have a look at others here:
http://www.ft86club.com/forums/showthread.php?t=35463
http://www.ft86club.com/forums/showthread.php?t=63268
Either run staggered F8.5 +45/R9.5 +45
or
go square with an offset closer to +35 to +38
or
add 10mm spacers to the front
or
go with another wheel option
Old 09-05-2014, 12:17 PM   #2496
K-NoMs
Drives: 2015 BRZ Series.Blue in WRB
Im on RSR sporti coils, still a no go for fitment?
or
or
or
K-NoMs is offline   Reply With Quote
Old 09-05-2014, 12:31 PM   #2497
Slick
Slick's Avatar
If you're on coils (lowering springs), not coilovers, will NOT fit.
You could add spacers to gain clearance, but always better to run without.
Old 09-05-2014, 05:29 PM   #2498
ModalSoul37
ModalSoul37's Avatar
Drives: 2014 Limited WR Blue Brz
Forgive me if this has been asked before, but I couldn't find anyone on this particular thread with the STi lowering springs...will either 17x9 +35 or 18x8.5 +38 fit on stock suspension with STi lowering springs?
ModalSoul37 is offline   Reply With Quote
Old 09-05-2014, 05:42 PM   #2499
Slick
Slick's Avatar
Not sure on lowering specs for the STi springs, but you should be fine with that setup!
The Following User Says Thank You to Slick For This Useful Post:
ModalSoul37 (09-05-2014)
Old 09-05-2014, 06:29 PM   #2500
K-NoMs
My apologizes i ment Sporti coilovers.
Old 09-05-2014, 08:46 PM   #2501
ModalSoul37
Sorry, I should've specified The STi spring specs, they only drop the car about 0.5 inch, will I still be good?
Old 09-05-2014, 09:05 PM   #2502
Slick
Slick's Avatar
Yup, all good.
Old 09-06-2014, 06:47 PM   #2503
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Hey guys - I'm thinking of purchasing some wheels that are 17x8 Offset 42. I am going to be lowered on the RCE springs (~.8" drop). Will I have any issues clearing the spring perch or any other rubbing issues? Thanks for the input.
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 09-06-2014, 06:54 PM   #2504
Slick
Slick's Avatar
That's a good offset for that wheel, no issues at all with inside or outside clearance.
Old 09-07-2014, 12:17 PM   #2505
ap5512
ap5512's Avatar
Thanks, Slick - much appreciated.
Old 09-16-2014, 05:52 AM   #2506
jn86
Drives: white gt86
Hey guys, I've searched this thread quite a bit and gotten a vague idea of an answer but just want to be sure:
Looking to go 18x9 et38 XD9s all round and I’m currently on a 1” drop from Eibach pro kit springs. Now due to the laws in Australia I can’t poke out any further than the stock fenders (correct me if my wording is a bit off).
With 235/40/18 or 245/35/18, would this be fine to avoid rubbing as well as poking in order to stay legal?
Perfect flushness isn’t that much of a concern, just want to avoid being defected!
Daily driving use btw.
Much appreciated.
jn86 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
