Old 09-03-2014, 07:34 PM   #99
Originally Posted by Ubersuber View Post
It does seem pointless to continue this debate with you but what the hey.
I'm sure you have some theory or other explaining how a variable compression ratio can produce ANY extra power so please feel free to share it with us.
As for variable displacement only supercharging can achieve this so far, although the Stirling cycle engines do create this effect and no doubt you can explain how that happens also. Hint, when is a calculated CR not the true CR?
It is quite clear to anyone who understands these things that the SAAB engine developed its power and torque by supercharging and not by varying the compression ratio. The combustion chamber size was varied precisely to maintain the effective compression ratio more or less constant. The Stirling cycle engine pulls off much the same trick with a fixed CR and a fixed displacement. The Miller cycle version uses supercharging to better exploit the Stirling cycle (Mazda's new skyactiv gasoline engines can run such nominally high CR because they use the Stirling cycle as well as a carefully shaped combustion chamber in the piston head to allow lean burn. Mazda has a lot of experience with the Stirling cycle and the Miller cycle).
To assist you in more fully understanding why the SAAB variable compression ratio engine worked only because it was a very highly pressurized supercharged engine and for no other reason it may help you to recall the F1 engine rules which stated an equivalency between 4.5 litre naturally aspirated engines and 1.5 litre supercharged engines (when running the same fuel) which was a 3:1 equivalency, which later was reduced to a 2:1 equivalency which allowed the 1.5 turbos to literally blow the very successful 3.0 litre normally aspirated engine into the history books. Even 3.5 litre normally aspirated engines could not compete with 1.5 litre blown engines.
Rest assured that you are alone in failing to understand that variable effective displacement is very real. The current C)2 emissions regulations in Europe are pretty much requiring that all powerful engines be supercharged in some form or other.
Displacement on demand won't cut it and everybody in the industry knows it.
FOR GOD'S SAKE GIVE IT UP MAN!!!!!!
Mikem53 (09-03-2014), sklimo (09-03-2014)
Old 09-03-2014, 09:07 PM   #100
Dipstik-sportech
Dipstik-sportech's Avatar
All the new engines are going turbocharged not supercharged BTW.
Old 09-04-2014, 02:45 PM   #101
Ubersuber
Drives: BRZ Pearl White
Turbochargers are superchargers.
Ubersuber is offline   Reply With Quote
Old 09-04-2014, 02:45 PM   #102
Ubersuber
No need to shout.
Old 09-04-2014, 02:51 PM   #103
Dipstik-sportech
Ugh r we really going to debate this again like on the Subaru BRZ forum?
Old 09-04-2014, 03:07 PM   #104
CoupedUpSubie
Drives: 2013 BRZ Limited
UberSuber is actually right on this matter. A supercharger is a device which forces more air into an engine, keeping the intake pressure above atmospheric pressure. You have various types of super chargers. They can be belt, gear, electric, and even exhaust driven.
And there have been quite a few things that I do not agree with him on.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 09-04-2014, 03:26 PM   #105
No need to shout.
Would have been the same if it had been Mikem or one of the anti Ubersuber crowd believe me!
I don't profess to have anything more then the basest knowledge in modern engine technology so don't have a clue who is "right" or "wrong" on the subject matter. I think we all get that you have opposing view points and would like to convert the others to them. BUT... it reaches a point where any valuable info gets lost in the bickering and the rest of us actually come out poorer for the whole thing!
We all have our own reason's for being on the forum, be it to find info, give info or just to enjoy the social aspects. Of course with the diverse crowd that owns these cars opinions will vary, but you said yourself "it is pointless to continue this debate" then followed up with yet another chapter. Perhaps your adversaries and yourself would care to present your credentials that make you qualified to make the statements you do so those of us that are less informed can pick a side and support you as these arguments go on from thread to thread ad perpetuum!
I have little doubt many people on here find some of my mindless drivel and participation in random thread hijacking obnoxious but I like to have fun and enjoy the company of others that do as well.
And again BUT... I can also ask for and provide information without writing a 500 word dissertation that does not include any supporting references or material sources as evidence. I am not just talking about you but also the guys accusing you of this that do EXACTLY the same thing.
I will climb down off my soapbox and wander away now.
sklimo (09-04-2014)
Old 09-04-2014, 03:33 PM   #106
Dipstik-sportech
All thumbs are fingers but not all fingers are thumbs.
My debate wasn't whether one was the other. I said engine are going turbo ie exhaust driven now for fuel economy. 99.9% of people believe a supercharger is engine driven and a turbo is exhaust driven. Times change though and now they pretty much have their own classifications.
Turbochargers were originally known as turbosuperchargers*when all*forced induction devices were classified as superchargers. Nowadays the term "supercharger" is usually applied to only*mechanically*driven forced induction devices. The key difference between a turbocharger and a conventional supercharger*is that the latter is mechanically driven by the engine, often through a belt connected to the*crankshaft, whereas a turbocharger is powered by a turbine driven by the engine's*exhaust gas. Compared to a mechanically driven supercharger, turbochargers tend to be more efficient, but less responsive.*
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
chas3wba0 (09-04-2014)
Old 09-04-2014, 03:39 PM   #107
stonenewt
Drives: BMW 120d
saab svc engine concept promo 2000:
Show me one point in that video where they say increased effective displacement. You can throw around your theories all you want, in the end "effective displacement" is not a real thing. You're attempting to say that it makes the engine seem bigger due to the supercharger, that's nothing new bud. The only way to alter ACTUAL displacement it by increasing cylinder volume not combustion chamber volume. Also BMW did have the same free valve system in the works i just checked but it hasnt made it into production and that was back in 2001 i believe. Oh, FYI Saab did kill itself off GM cut them loose like other companies did before due to there no profitable design ideas.
An engine is basically a very complicated air pump with a net power gain. The more air, by weight, you can get to flow through the engine the more power you make. A high CR engine allows for a higher air mass to flow through the engine so you want to run the highest CR as you can get away. The problem is when you add forced induction, higher levels of boost require lower CR to counter pre-ignition which means when air isn't being forced into the cylinder it's sluggish.
Saab developed a system that allowed them to have a high CR N/A engine for good off-boost performance and a low CR for high boost forced induction. Net result is you have a low-lag, high throttle response big-boost engine. This variable CR technology seems to be only useful when combined with some kind of forced induction. Also this seems like it's been superseded by direct injection petrol engines which can run a higher CR without pre-ignition issues.
stonenewt is offline   Reply With Quote
The Following User Says Thank You to stonenewt For This Useful Post:
Dipstik-sportech (09-04-2014)
Old 09-04-2014, 03:44 PM   #108
Dipstik-sportech
Exactly ^ not effective displacement. Using his theory and engine that is boosted has higher effective displacement. Saab just designed that so they could as you said make more power without detonation.
Old 09-04-2014, 03:44 PM   #109
Credentials please!
Old 09-04-2014, 03:51 PM   #110
stonenewt
Drives: BMW 120d
I've read & appear to have fully understood Four-Stroke Performance Tuning & Force Induction Performance Tuning by A. Graham Bell as well as Street Turbocharging by Mark Warner. The first two might be considered fairly light bed time reading... along the lines of War & Peace
Old 09-04-2014, 03:52 PM   #111
sklimo
I can count to potato
The Following 4 Users Say Thank You to sklimo For This Useful Post:
chrisl (09-05-2014), Dipstik-sportech (09-04-2014), stonenewt (09-04-2014), trd_kid (09-05-2014)
Old 09-04-2014, 03:54 PM   #112
stonenewt
Drives: BMW 120d
You now owe me a new keyboard. This one is coffee coloured!
sklimo (09-04-2014)
uberstupid
Lug Nut Torque Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-30-2014 07:45 PM
Torque Pro sav AFRICA 33 08-27-2013 07:31 AM
500 hp & 550 lb/ft torque ? yes please LS13 Scion FR-S / Toyota 86 GT86 General Forum 3 06-17-2013 12:48 PM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 06:56 PM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
