Old 09-03-2014, 02:14 PM   #113
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
A friend with his NC Miata and fellow member @Lunatic in his FRS good times
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
eric6 (09-03-2014)
Old 09-03-2014, 02:27 PM   #114
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by glamcem View Post
a video taken at the last ORP club event (2014-8-30) I was able to improve my best lap time by 4 seconds!! thanks to Raybestos ST43 pads and the new Z214s..
It started soon after my second session and never stopped :/ next time, I should be able to squeeze another second or two
Special thanks to @KraftWerks @moto-mike
I gotta ask. Have you experimented with not going down to 2nd gear? In my racing experience I have found that if you are changing up a gear at or just after track out, then it would have been better to avoid that extra gear change and just use the higher gear.
Old 09-03-2014, 02:39 PM   #115
glamcem
glamcem's Avatar
I sure did and pretty much at every corner so in some corners I shift down and lose some time (a few tenths) but I gain better exit speeds ..
as you may know, the Centrifugal type Superchargers make the most of the power up top and TQ keeps climbing so you have to keep the car in high rev range otherwise it will feel like it bogs ..
However, I am still not certain about a few corners where I shift down to 3rd like the main straightaway where the finish line is or some corners when I keep the maintenance throttle and gradually opens turns(no advantage of having more TQ) .. I think both 3rd and 4th gear yield the same overall time in those types of turns
I think I also can apply trailbraking a bit easier with the shorter gear since throttle/brake transition is a bit easier
Old 09-04-2014, 01:32 AM   #116
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
This fills my heart with joy.
It's time to think about a trailer and a tow vehicle. It just so happens I may have my trailer for sale real soon.
When I get more time I'll watch your videos with the sounds on and see if I can offer any advice about shifting. Sometimes, it just works out there is no good option. You can shift or not-shift and may be the same speed. That's where data comes in.
PRO86 | WTCC | STL
Old 09-04-2014, 02:42 AM   #117
glamcem
glamcem's Avatar
Yes, there are so many factors also..I personally don't like to shift unless it's really necessary but the type of the supercharger I have kinda mandates that
When I had the Vette it was only couple shifts between 2nd-3rd-4th gear that's it
Old 09-05-2014, 05:56 PM   #118
GotMunchies?
Drives: '14 WRB BRZ 6MT Limited
Just watched your video at ORP - that looks like a really fun, technical track! That series of on-camber sweepers is a trip!
I think I might have to make a trip down there for an HPDE next year.
Question - on your hard up-shifts, I keep hearing a wee pop. Is that a back-fire or am I hearing drivetrain abuse?
GotMunchies? is offline   Reply With Quote
The Following User Says Thank You to GotMunchies? For This Useful Post:
glamcem (09-06-2014)
Old 09-06-2014, 12:51 PM   #119
jflogerzi
jflogerzi's Avatar
Great thread. Love the detail pictures and insight.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 09-06-2014, 05:11 PM   #120
glamcem
glamcem's Avatar
Exactly, I'm glad you liked it .. ORP is without a doubt the best track in NW region in my opinion, I would suggest you to contact with the ORP club since becoming a member has its perks , you get the most seat time with them and cheaper if you become a member
that pop is back fire as you guessed, it started doing that after the catless header
Old 09-06-2014, 05:11 PM   #121
glamcem
glamcem's Avatar
Thanks, glad you liked it
Old 09-12-2014, 06:18 AM   #122
peebking
Drives: BRZ limited
I am finally run on ridge this week, with my na powerrrrrr, about 2:03-2:05, shake away some sti with r888
peebking is offline   Reply With Quote
Old 09-12-2014, 12:21 PM   #123
glamcem
glamcem's Avatar
Ridge is fun
Old 09-12-2014, 09:01 PM   #124
glamcem
glamcem's Avatar
some footage from the last ORP event
fellow member @Lunatic (with No: 24 stickers on his FRS) also made it to the event
[ame="http://youtu.be/KU8oWMgWlj4?t=1m47s"]http://youtu.be/KU8oWMgWlj4?t=1m47s[/ame]
Old 09-17-2014, 02:00 PM   #125
glamcem
glamcem's Avatar
Talking Day 45 They still think I'm a Camaro 1LE
Ganthrithor (11-22-2014)
Old 09-29-2014, 05:22 PM   #126
Lee
Drives: GT86
This is my favourite 'sensible' build on this forum, much how I intend mine to turn out before it inevitably gets silly.
What do you use camera / data overlay wise?
Lee is offline   Reply With Quote
The Following User Says Thank You to Lee For This Useful Post:
glamcem (10-12-2014)
Supercharger Comparison: Innovate, Jackson, Kraftwerks, Vortech *Updated March 9 2014 CSG Mike Forced Induction 281 02-25-2021 04:14 AM
Pneubs HKS Supercharged BRZ Build Thread Pneub Member's Car Journals 62 03-30-2016 09:47 AM
Dezoris | FR-S Build | Supercharged & More Dezoris Member's Car Journals 329 03-21-2016 04:48 PM
Morpheus, Scion dream Build. Supercharged FR-S by TuneCast scionsalesjay Member's Car Journals 51 07-07-2014 12:05 PM
Supercharged Rocket Bunny Widebody Conversion Build Thread RWDRIFT Member's Car Journals 278 01-06-2014 12:12 AM
