Old 09-02-2014, 10:57 PM   #1583
DriftHappens
Drives: '14 FRS White
Originally Posted by Slick View Post
Questions for the OpenFlash guys (@Shiv@Openflash):
1. I tried a right angle OBD extension cable and the tablet didn't power up at all. Is there a limit to the length of cable used, or can you not use any extension cable at all? I would like to run it to the other side of the dash for logging and also not have the cable pointing down from the port just above my right leg.
2. I have a OBD Bluetooth adapter that I was using with the Torque app. Since installing the OFT, it no longer connects to the ecu. Is that a common issue? Works fine in another FRS, non-OFT.
1. I use a right angle OBD adapter as well, and don't have an issue, double check the cable?
2. My BT obd adapter works fine also. I'm wonder if you don't have something a little wonky with your port.
Does the OFT plug in without the extension just fine? if so, try the extension with the bluetooth adapter in your car and another car.
DriftHappens is offline   Reply With Quote
Old 09-02-2014, 11:07 PM   #1584
steve99
Drives: FT86
Originally Posted by aristo View Post
Was doing some research before buying. I downloaded the pre-made flash files and opened the folder (OFT OTS v1_59\BINs\ZA1J___C ROMS (US 6MT)\Stage 2 UEL) and saw this:
Do each of those files stand for something seperate? Are they to customize the tune further? Because I thought the selection seemed a little sparse and unspecific if it's just 'stage 2 UEL'
Is there a customization for example, for someone who has just a UEL, intake tube and catback? or does it not get that specific?
Thanks for any help!
have a read of the OFT TIPS post below
intake tubes drop in filters ,cat backs dont effect tune required
its rearly only the header UEL or EL and removal of cats that change tune requirements
intake change ie a full CAI will effect maf scaling but you can do this youself see below, in most cases leave intake alone their is little to be gained over a drop in filter in standard intake and modify snorkel if your rearly keen.
aristo (09-02-2014)
Old 09-02-2014, 11:08 PM   #1585
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
What's the length of your cable? Mine is 4' long, perhaps too long to maintain the signal. Probably 2' would do.
Not sure on adapter. Connects to phone, just not reading ECU.
OFT connects without issue, reads fine without extender cable.
Slick is offline   Reply With Quote
Old 09-02-2014, 11:33 PM   #1586
Turdinator
Señor Member
Turdinator's Avatar
[IMG]
Those are for the different CAL IDs over the years. Stage 2 UEL, as steve99 mentioned, will cover any setup with a stock airbox. Shiv's OTS tunes should really be treated as basemaps in many ways and if you are getting large fuel trims you should look at scaling your MAF.
I have a 3' right angle cable and it works like a charm. I doubt your problem is the cable length. More likely a faulty cable.
1974 TA22 Celica
2013 86 GT
Old 09-03-2014, 12:09 AM   #1587
aristo
aristo's Avatar
Drives: BRZ SWP 14
Thanks for your help and input -- I did a quick search to try and understand what you meant exactly but no solid answers come up
but from what I can infer.. you are basically saying that the OFT tunes are Okay to unlock most of common setups potential power but need to be edited/calibrated after being checked against logged data to get the most performance. Is that right?
Before I scour this entire thread and forum, are there any guides or tutorials you could point me in the direction of (recognizing a large fuel trim, the average fuel trim levels, how to scale the MAF)?
thanks
edit: never mind I am going to read the entire romraider site first sry
also may seem silly but wouldn't it be a good idea for people to share their tunes of exact setups? there's probably trust issues or other problems involved I presume?
edit2: also I think it would be nice to know exactly what aftermarket parts were used to mold these 'basemap' tunes to the way they are, like say the OFT team decided to use: x header, y front pipe, z overpipe, x catback to create the "93 octane stage 2 UEL header tune" // or if they simply created the basemap while using just an aftermarket header and stock everything else etc.. (sorry if this is answered somewhere, just a thought)
aristo is offline   Reply With Quote
Old 09-03-2014, 12:47 AM   #1588
Turdinator
Señor Member
Turdinator's Avatar
thanks
steve99 has some great threads on DIY stuff with the OFT. It would be great if people did share their tunes but 95% of people just run the OTS tune.
The UEL tune is based of Shiv's own OFH but should work fine for other UELs. The EL tune was based off a prototype or custom EL that I haven't heard much about. I suspect the stg 2 EL tune could be optimised for different EL headers, particularly the cam timing but again I haven't read about anybody really messing with that.
Lots of info on the romraider site that is for sure.
1974 TA22 Celica
2013 86 GT
Old 09-03-2014, 01:00 AM   #1589
aristo
aristo's Avatar
Drives: BRZ SWP 14
Thanks man you the best. Seems like there is a lot to learn for semi-perfectionists like myself who won't be able to even sleep if their tune is off by a little.
Could you guys also enlighten me about the pros and cons of going with something like the Unichip instead? It seems to have a much deeper and specific library of pre-tested/pre-made maps while still allowing for user adjustments. Very curious about this
Old 09-03-2014, 05:07 AM   #1590
steve99
Drives: FT86
Once you have a flashable ECU and the tune tables are known like with the BRZ/86/FRZ then I cannot see the point of a device like a uni-chip.
You have to wire it in
It obvious to dealers
It is only "fooling" the external sensor inputs to make adjustments to the engine performance, very limited adjustments available.
I suspect this is why they have to offer so many different "tunes"
Great for ECU's where no flashing option available.
With a flash tune your changing the specific tables that the ECU uses
Much wider range of changes and adjustments available.
You not fooling anything your changing the actual values you want to change in the tables directly used by the ECU program
Their are hundreds of these tables available.
It virtually undetectable
Can be flashed back to stock spec in minutes. no wiring ect.
Most flashing devices/systems offer a means of logging your tune allowing you to see exactly whats going on in real time or storing logs for analysis.
you can update to later version ECU software released by manufacturer.
You can make adjustments based on this logging information.
Logs can be sent to professional tuner for analysis and adjustment.
Allows for additional features or functions such as Launch control , Flat Foot shifting.
aristo (09-03-2014)
Old 09-03-2014, 06:38 AM   #1591
steve99
Drives: FT86
Answer Edit 1 :People can share their tunes but you have to trust that the other guy is not a "wombat" and has produced something that is either rubbish or may in fact be dangerous to your engine and is suited to your mods and the ROM is compatible with your car.
Answer Edit 2 :
Talking Naturally Aspirated BRZ/86 and "bolt on mods"
Its fairly proven that Headers (generally catless) produce the most gain and hence require the most "tune changes". Changing the rest of the exhaust ie overpipe/resonator/catback , has little effect on the required tune or power/torque. After the header little hp to be gained it mostly change in noise/rasp level.
Intakes again appear to produce little gain and in general will require you to rescale (or calibrate) the mass air flow sensor to suite the intake . Most aftermarket intakes offer little benefit over just changing your stock filter for a quality drop in filter and maybe modifying snorkel and this wont upset MAF scaling.
Yes a dedicated Dyno tune for your specific mods and fuels may squeeze out a few more hp, but where I live thats about $1200-$1500 plus I pay for updates or changes and I leave with nothing but the "tune" in the car.
As opposed to an OFT and a "base" tune for $500 I get tune & updates thrown in I can change tunes as mods added or removed, E85 tunes are another bonus, I can flash to stock for dealer visits. I have a device to flash tunes and log engine parameters read/clear DTC/CEL codes and I can on-sell it if I move on to something else.
Probably 95% of gain for one third of the cost and I can on-sell it.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
aristo (09-03-2014), BirdTRD (09-03-2014), Triumphrider (09-03-2014)
Old 01-01-2015, 11:37 AM   #1592
rever5e
Originally Posted by R2 View Post
I'm having the exact same issues on two different PC's. I contacted them and am hoping for a quick solution as well.
Any idea what the solution was? I've tried on 3 PC's and i cannot get OpenFlash Tablet to connect to OpenFlash Manager
rever5e is offline   Reply With Quote
Old 01-01-2015, 01:47 PM   #1593
steve99
Drives: FT86
Make sure your Open flash manager is up to date, if its an old version may not connect to Tablet
download and install from here
make sure you update template files as well once you get connected
http://openflashtablet.com/Automotiv...ads/index.html
Old 01-01-2015, 02:48 PM   #1594
rever5e
Running the latest oft manager software still the same exact issue in three separate machines
Old 01-01-2015, 03:34 PM   #1595
coeurdencre
coeurdencre's Avatar
Drives: 2014 x ZC6 x 37J
I received my OFT this week and it worked without problem with OpenFlash Manager.
I got the "Cannot create a Tuning file." message after I read my ROM. I sent my stock ROM to Shiv and hope to get a quick reply
coeurdencre is offline   Reply With Quote
Old 01-01-2015, 10:42 PM   #1596
steve99
Drives: FT86
does not throw up any errr message ?
knd f out of ideas if its a rearly new pc maybe it does not like usb 3 ports, best contact the openfash guys.
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
