Old 09-16-2013, 02:51 PM   #15
wlfpck
Drives: 2015 GTI
From non-invasive options... Then yes, you would be limited to software. However, there really isn't much that is dependent on software.
For instance... on a DSG/DCT transmission... options from a hardware standpoint:
Transmission Oil Cooler
Upgraded Clutch material
Etc.
From a software standpoint... you have a variety of tunes. However all the tweaks tune is the following.
Launch control (where RPM it holds at)
Redline
Removing software safety (limp mode when certain amount of torque is detected).
Etc.
The firmness of the shifting is not really impacted by the tuning. Also keep in mind the type of transmission that you are used to dealing with (F-bodies and older mustangs). If I am not mistaken, those transmissions determined the firmness of the shifting due to hydraulic pressure. Tuning on those was done by "tricking" the ECU (or TCU if there was a separate computer) into increasing the hydraulic pressure of the fluid. Thus creating a faster shift. This is my understanding anyways.
This is a good source as this guy built something that tricks the hydraulic fluid pressure. It's may not be the same for the F-bodies and stuff you've built though. http://www.cb7tuner.com/vbb/showthread.php?t=177881
This is just my understanding though.
Also not sure of what you're looking for in a "tune" though. If you're looking for increased firmness in regular "drive" mode (the kind of shift firmness you get in manual mode), then yeah, that's a tune issue. If you are looking for shift firmness in manual mode, then I don't think a tune will do much. Again, tha'ts just from my understanding though which could be incorrect.
2013 GTI - Gone
2015 GTI
wlfpck is offline   Reply With Quote
Old 04-03-2014, 04:05 AM   #16
EZx2
Drives:
Sent from my SM-N9005 using Tapatalk 4
EZx2 is offline   Reply With Quote
Old 04-03-2014, 04:07 AM   #17
EZx2
Drives:
..I would expect hacking the shifting time response in manual mode (from 200ms today to <150ms )
Old 08-25-2014, 10:11 PM   #18
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
I am quite shocked that we haven't seen more requests for this, especially from those that are FI. Shift points need to be adjusted to avoid hitting rev limiter while in full auto or manual mode. While raising rev limit may help, that fixes an issue vs fixing the problem. Shorter shift duration and slightly lower shift point would be ideal.
pixel67 is offline   Reply With Quote
Old 08-30-2014, 05:59 PM   #19
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
I've been meditating about this question. There's a market for this as there are so many automatics. More importantly there there are enough of us who would spend the money to improve our automatics.
I remember there was some high end transmission shop in NY who was asking for sample cars about a year ago to help develop mods for our cars.
I think the real answer is there aren't enough of us who are asking for this, who have exceeded the capability of their existing units, or are willing to pay for the upgrades.
I do think that most of performance upgrades possible for planetary gear-set / torque converter based transmissions are mostly mechanical in nature (solenoids, pumps, clutch packs...). That being said there's a link between the transmission's control unit and the motors. In another thread there was some discussion about the complexity of the interaction being a barrier to tuning the automatic in the FT86 platform cars
There are a lot of companies who do high performance AT work for other platforms...
http://eng.kaps-transmissions.com/
http://sheptrans.com/
http://www.tciauto.com/
http://www.bmracing.com/
http://www.performanceautomatic.com/
...eventually someone will start working on developing upgrades for the Toyota AA60E / Aisin TL-60SN 6-speed. As I'm a betting man, i would probably guess that SOMEONE, somewhere has to be working on this.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 08-30-2014, 07:02 PM   #20
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
South Side Performance is pretty much the only ones so far to develop stuff for the Auto. Valve body and Torque converter upgrades are available now.
http://www.sspperformance.com/brz-fr...on-cooler.html
Right they are in the works for a stage 3 valve body and clutch pack upgrades coming out soon . I can't wait to see what else they will be doing for the future. As for tuning i wish more options were available. But i guess the mechanical upgrades will be the way to go.
@sspkris @Jason@DSG
JonAvalon is offline   Reply With Quote
Old 08-30-2014, 07:25 PM   #21
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@sspkris @Jason@DSG
That's just awesome. Finally this platform is starting to come into it's own.
Old 04-08-2016, 02:27 PM   #22
steve99
Drives: FT86
The moto-east and likely other ecutek guys may have some small tweaks, likely done in engine ecu but effects auto shifting, see towards end of linked post below
http://www.ft86club.com/forums/showthread.php?t=58425
Old 04-26-2016, 04:04 PM   #23
shr133
shr133's Avatar
Drives: 2013 FRS
Originally Posted by meadowz06 View Post
I have done a search and would like to know what kind of tuning can be done to the automatic FR-S. I am buying one and want to know what are my tuning options for the auto transmission.
Thanks
Other than a valve body or converter....
Keep the trans fluid fresh......
Change fluid every 20k - 30k....
You could add a trans cooler to keep the temps down and help the fluid to last....
I replaced the fluid with red line trans fluid, 6 qt of D6 and 2 qt of D4........
Just a touch thicker so firmer shifts and locks up harder and can resist more heat.........
Get a flash for an auto not stick....
Need to tune for more torque........
shr133 is offline   Reply With Quote
Old 03-03-2021, 09:39 AM   #24
pro_turbo
Drives:
I am using ssp TC and stage 3 + VB here
Good parts to hold boost more than 1 bar
pro_turbo is offline   Reply With Quote
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
Automatic Transmission :( Almighty Bob Southern California 14 11-06-2012 01:13 PM
Yes, the automatic transmission is that good Mburolla Member's Car Journals 4 07-30-2012 04:48 PM
FT-86, manual or automatic transmission??? luisjr Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 03:00 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
