#29 | |
Drives: Scion FR-S 2013 Raven
For sure, go to the dealer, the problem is not linked with your tint anyway...
o= FR-S =o |
| The Following User Says Thank You to Mikepage For This Useful Post: | jmelgar23 (08-27-2014) |
#30 |
Scratches on Outside of Driver's Window
My window, where they replaced the parts, started to cry when raining now... Do you have an idea why? Do you suggest to go back to the dealer?
o= FR-S =o |
#32 | |
Go back and try again or check with an another dealer.... They are wrong and they told me the same thing before replacing everything in the door... You can also show them the thread here.
o= FR-S =o Last edited by Mikepage; 10-14-2014 at 04:52 PM. |
| The Following User Says Thank You to Mikepage For This Useful Post: | Flako (08-30-2014) |
#33 |
Drives: '13 BRZ
had my TSB done today...they replaced my windows but would not replace the tint that they sold the car to me with....so now I have to pay tint out of my pocket
| The Following User Says Thank You to tinma For This Useful Post: | Dipstik-sportech (10-20-2014) |
#34 |
Drives: 2013 SWP BRZ Limited
#35 |
Drives: 2013 BRZ Sport-tech WRB
I'm excited to see that Subaru Canada has the TSB out. I'll head to the dealer this week. I always see TSBs but usually don't get confirmation that its (a) Subaru, and (b) Canada.
#36 |
Drives: 2013 Scion FRS in white out
Had both of my windows replaced under warranty due to the belt molds scratching them all to pieces. Dealer covered tint as well...probably due to the fact we were in progress of buying a new venza for the wife.
#37 |
Drives: '13 BRZ
after getting the TSB done...my window now makes a horrible screeching noise when wet (worse than before the TSB)...will be letting the dealership know sometime this week
#38 | |
I got that trouble also after dealer installed new windows... I know how to fix it like the dealer fix it for me in 5 minutes... You just need to put some grease into the new rail. Exempt for the driver side, If you remove the door trim, on the left side into the door you will see the rail, where a little wheel roll when you move the window up and down...add some grease on both rails, the upper and the lower...Problem fixed!
o= FR-S =o Last edited by Mikepage; 10-22-2014 at 09:04 AM. |
| The Following User Says Thank You to Mikepage For This Useful Post: | tinma (10-22-2014) |
#39 |
Drives: Evo X
Anyone with 2015+ FRS/BRZ/86 have this issue?
#40 |
Do you have them? It should not be an issue with the updated weather stripping and guides
#41 | |
Drives: Evo X
#42 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | BaatLuk (10-30-2017) |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Anyone with an auto, have scratches on the | Liquidsnake | Cosmetic Modification (Interior/Exterior/Lighting) | 26 | 03-31-2013 12:17 PM |
| minor scratches..... | jazztennor | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 10 | 02-06-2013 12:01 AM |
| scratches - best way to handle them | Vladror | AFRICA | 6 | 02-03-2013 04:05 PM |
| Scratches on my Cluster. | Superhatch | BRZ First-Gen (2012+) — General Topics | 5 | 08-21-2012 07:50 AM |
