#99 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
"Toyota 86 GT 2.5"?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#100 | |
Platinum Member
Drives: Toyota 86 Vortech SC
That's my personal experience, not my opinion.
#101 | |
I'm not a huge fan but it may also have something to do with me blowing a previous car's ECU trying to remove the stupid unichip.
95RON SAV Tuned |
#102 |
Drives: Toyota Runx TRD
#103 |
Drives: 2014 Satin White Pearl GTS auto
Of course, and the people that fit it and tune it make a massive difference, but to date, this year alone, I have removed 3 unichips for people, simply because the unichip malfunctioned
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto |
#104 | |
But, put both in the right hands and flash tuning > unichip, it's probably just a case of more old school guys who know unichip and have been using it since noah's ark. People are often scared of things they don't know how to use.
95RON SAV Tuned |
#105 |
Great in comparison to what?
#106 | ||
Platinum Member
![]() Quote:
![]() OK, you're right...
#107 |
What im trying to get across is, if the option of doing a software change is available, why not just do that? tuning is tuning, whether its the chip or the actual software in the car? no cutting and splicing of wires etc.
#108 | |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Chuckle... this debate is as old as the hills. I still contend it's down to the economics - why just sell a tune, when you can sell a tune and hardware (on which you make a margin). But technically, flash tune will always be superior to piggyback - I only need to point to a post in this thread to prove the point:
![]() Just a compliment to everyone - this discussion is always so vitriolic wherever I've seen it online - everybody's been very civil here. Maybe we're all old bullets... |
| The Following 2 Users Say Thank You to Td-d For This Useful Post: | JouMaSeHoes (09-01-2014), WesleyG (08-28-2014) |
#109 |
nope i can be classified as what people call a 'lighty'
2014 37J 86 Auto |
#110 |
Drives: Toyota MR2 Spyder Turbo
I agree. Why add/remove hardware if you can just flash the existing ECU?
Unichip has its place. On cars where the ecu flashes itself back to stock after a while. Like my Tuna where you have to use actual hardware. (The Unichip has since given up and i removed it...)
#111 | |
Drives: 2013 Toyota GT 86
Your ECU stores your data on an EPROM or EEPROM. Tweaking any data is modifying it. Flashing the ECU is the term used to load this modification to your ECU. So I do undertand the difference and it was used in correct context As for these gains, be so kind and supply a SABS calibration certificate on dyno in questions, less than 6 months old. That is engineering standard for measuring anything. You are measuring something ...... but you are not measuring actual kW output. For a start, you are adjusting reading for loss in transmission train ......The reason why the dyno ask for model and make of vehicle ...they have a base of what the output should be and they use that. The gain is relative to you original input. As for volumetric efficiency ...... you cannot change that by anything but getting more air and fuel into the cylinder. FI is one option, gas flowing, better air filtration flow and xhaust with better scavenging and even cams ...can and will change volumetric efficiency at a specific rpm. Volumetric efficiency is a physics term and is constrained by physic laws ...not some ECU code unless it affects air volume intake on each cycle with additional fuel ....... like turbo boost Thump your chest all you want, get indignant ...bottom line no evidence of any claims apart from uncalibrated dyno graphs are given as fact Just engineering background ... I do believe you all ..... now just give me verifiable data.Thanx for pointing out I should use dyno ....fat fingers and a slow mind
#112 |
Drives: Toyota 86 (High) - White
Ermmm.. it's 'dyno' not 'dyna'
| ROH Evolution R 18x8 +40 | Sinclap2 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 06-23-2014 02:20 PM |
| Lancer Evolution XI (Resurface) | Whitigir | Other Vehicles & General Automotive Discussions | 9 | 03-14-2014 07:36 PM |
| my scion evolution | Cooper911 | Member's Car Journals | 2 | 08-04-2013 10:13 PM |
| FS: Mitsubishi Evolution 1 GSR | FT86Katsu | Cars for Sale/Trade | 11 | 06-15-2012 12:31 PM |
| Evo x the last evolution | 4agze | Other Vehicles & General Automotive Discussions | 15 | 03-05-2011 07:15 PM |
