Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 08-28-2014, 04:40 AM   #99
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
"Toyota 86 GT 2.5"?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 08-28-2014, 04:52 AM   #100
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Originally Posted by WesleyG View Post
im really not a fan of the unicrap to be honest, most of the people i know end up having problems with it and eventually end up tossing it.
The unichip was for a time when car ecus where not clever and you couldnt flash them.
With software tuning its just a matter of a flash and you are good to go, no wiring needs to be cut or tapped into at all.
but thats my opinion.
Unichip is great.
That's my personal experience, not my opinion.
Fish Eagle is offline   Reply With Quote
Old 08-28-2014, 05:01 AM   #101
sav
sav's Avatar
Originally Posted by Fish Eagle View Post
Unichip is great.
Depends on what you're trying to get out of it I guess. It seems a bit limited compared to flash tuning.
I'm not a huge fan but it may also have something to do with me blowing a previous car's ECU trying to remove the stupid unichip.
95RON SAV Tuned
Old 08-28-2014, 05:08 AM   #102
TheGooseman
TheGooseman's Avatar
Drives: Toyota Runx TRD
Unichip is great.
Agree 110%...
a Product is also only as good as the person installing and tuning it...!
Much the same with flashing - put it in the wrong hands and it WILL be a mess...
TheGooseman is offline   Reply With Quote
Old 08-28-2014, 05:14 AM   #103
WesleyG
Drives: 2014 Satin White Pearl GTS auto
Unichip is great.
Of course, and the people that fit it and tune it make a massive difference, but to date, this year alone, I have removed 3 unichips for people, simply because the unichip malfunctioned
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 08-28-2014, 05:15 AM   #104
sav
sav's Avatar
Originally Posted by TheGooseman View Post
Agree 110%...
Absolutely.
But, put both in the right hands and flash tuning > unichip, it's probably just a case of more old school guys who know unichip and have been using it since noah's ark. People are often scared of things they don't know how to use.
95RON SAV Tuned
Old 08-28-2014, 06:18 AM   #105
s2d4
s2d4's Avatar
Unichip is great.
Great in comparison to what?
Old 08-28-2014, 06:19 AM   #106
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Interesting. I've heard nothing bad about Unichip, and my experience is all positive, but who knows - YMMV
Originally Posted by sav View Post
Absolutely.
Are you insinuating that I'm an old fart and that I resist change?
OK, you're right...
Old 08-28-2014, 06:27 AM   #107
WesleyG
What im trying to get across is, if the option of doing a software change is available, why not just do that? tuning is tuning, whether its the chip or the actual software in the car? no cutting and splicing of wires etc.
Old 08-28-2014, 06:41 AM   #108
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Chuckle... this debate is as old as the hills. I still contend it's down to the economics - why just sell a tune, when you can sell a tune and hardware (on which you make a margin). But technically, flash tune will always be superior to piggyback - I only need to point to a post in this thread to prove the point:
Originally Posted by African View Post
On exhaust. ECU goes crazy if cats are removed. TNT did the rear box with twin pipes for me and fitted a hi-flow cat.
It's trivial to deal with this problem using opensource (or other flashing solutions) - disable the P0420 (and other rear O2 related) DTC, and zero out the AF3 and rear O2 compensation. Click click, reflash, and you're done in 5 minutes without a hardware solution. I could run vuvuzela as an exhaust for all the ecu cared, and it wouldn't complain
Just a compliment to everyone - this discussion is always so vitriolic wherever I've seen it online - everybody's been very civil here. Maybe we're all old bullets...
Td-d is offline   Reply With Quote
The Following 2 Users Say Thank You to Td-d For This Useful Post:
JouMaSeHoes (09-01-2014), WesleyG (08-28-2014)
Old 08-28-2014, 06:47 AM   #109
WesleyG
nope i can be classified as what people call a 'lighty'
2014 37J 86 Auto
Old 08-28-2014, 06:48 AM   #110
Die$eL
Die$eL's Avatar
Drives: Toyota MR2 Spyder Turbo
I agree. Why add/remove hardware if you can just flash the existing ECU?
Unichip has its place. On cars where the ecu flashes itself back to stock after a while. Like my Tuna where you have to use actual hardware. (The Unichip has since given up and i removed it...)
Die$eL is offline   Reply With Quote
Old 08-28-2014, 07:55 AM   #111
African
Drives: 2013 Toyota GT 86
Originally Posted by Dammod View Post
I dont mean to hijack your thread either, but I too was just pointing out that there is "life before FI" lol.
Not once did anyone claim those gains by simply "fiddling with the ECU" and nothing else:
(By the way, to "fiddle" with the ECU you need to "flash" it regardless. Just mentioning this because in you first paragraph you referring to "tweaking" then in the second you use the word "flash" as if it adds more power. Any "tweaks" you do needs to be "flashed to the ECU.)
Not sure what you are trying to "compare" either??
You mean +-170 kw....not 185. 170kw - 175kw is VERY believable considering I got 165 with less mods and base tune on a dyno that just a few weeks earlier had an 86 dyno day with 86's doing between 135 - 155 kw ranging from stock to stage 1. None of them with a tune though as far as I know.
Your ECU stores your data on an EPROM or EEPROM. Tweaking any data is modifying it. Flashing the ECU is the term used to load this modification to your ECU. So I do undertand the difference and it was used in correct context
As for these gains, be so kind and supply a SABS calibration certificate on dyno in questions, less than 6 months old. That is engineering standard for measuring anything. You are measuring something ...... but you are not measuring actual kW output. For a start, you are adjusting reading for loss in transmission train ......The reason why the dyno ask for model and make of vehicle ...they have a base of what the output should be and they use that. The gain is relative to you original input.
As for volumetric efficiency ...... you cannot change that by anything but getting more air and fuel into the cylinder. FI is one option, gas flowing, better air filtration flow and xhaust with better scavenging and even cams ...can and will change volumetric efficiency at a specific rpm.
Volumetric efficiency is a physics term and is constrained by physic laws ...not some ECU code unless it affects air volume intake on each cycle with additional fuel ....... like turbo boost
Thump your chest all you want, get indignant ...bottom line no evidence of any claims apart from uncalibrated dyno graphs are given as fact Just engineering background ... I do believe you all ..... now just give me verifiable data.
Thanx for pointing out I should use dyno ....fat fingers and a slow mind
African is offline   Reply With Quote
Old 08-28-2014, 08:06 AM   #112
Razzle
Razzle's Avatar
Drives: Toyota 86 (High) - White
Ermmm.. it's 'dyno' not 'dyna'
Razzle is offline   Reply With Quote
ROH Evolution R 18x8 +40 Sinclap2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-23-2014 02:20 PM
Lancer Evolution XI (Resurface) Whitigir Other Vehicles & General Automotive Discussions 9 03-14-2014 07:36 PM
my scion evolution Cooper911 Member's Car Journals 2 08-04-2013 10:13 PM
FS: Mitsubishi Evolution 1 GSR FT86Katsu Cars for Sale/Trade 11 06-15-2012 12:31 PM
Evo x the last evolution 4agze Other Vehicles & General Automotive Discussions 15 03-05-2011 07:15 PM
